I like to connect the max6675 temperature sensor ( for my stove) to a wemos D1 mini and then together to Domoticz.
Has anyone an idea how to do that.
I am a beginner, thank you very much,
Piet
Wemos D1 mini V3 and Max6675
pietje1951
willem9136
Re: Wemos D1 mini V3 and Max6675
I think I can help you.
Is the max6675 already running on the wemos?
That’s the first step younhqve to take.
And is Domoticz up and running?
- erem
- Domoticz version: 2021.1
look into espeasy on the wemos
it supports domoticz out of the box and has support for max6675 temperature sensor
https://www.letscontrolit.com/wiki/index.php/ESPEasy
Regards,
Rob
Rob
twoenter
- Domoticz version: 4.10
Hi pietje,
At my blog I wrote a dutch guide how to build a wifi thermometer with a wemos d1 mini and a dht22. I think it will be quite the same for other temp sensors.
https://www.twoenter.nl/blog/domotica/w ... s-d1-mini/
And
https://www.twoenter.nl/blog/arduino-es ... z-espeasy/
And
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
