You can have only one remote per group, but here is what I would do
Create one groupe with one bulb an one remote
Create a second group with an other bulb and the second remote.
Now add all bulb to each group, you will get 2 groups will all bulb.
Finally add the corresponding remote to its group and add the remote.
1 group of bulb managed by 2 zigate groups managed by 2 remotes
Tradfri E14 LED 470m no colortemp adjustment in Domoticz (704.243.12)
TonkaNL
Re: Tradfri E14 LED 470m no colortemp adjustment in Domoticz (704.243.12)
Yes, I tried that. But Zigate wouldn’t add the same devices to two groups. They would disappear again. But I will try again later.
Thanks again so much for your input!
1/ pair one remote with one LED
2/ par second remote with a second LED
scan the groups
You should get 2 groups
Add Zigate to each groups
Add Remote to the correspond group
Add ALL Led to each groups
This should work
A Led can be member of several groups
Zigate can be member of several groups (limit is 4)
scan the groups
This should work
