Domoticz-Google-Assistant (dzga) Topic is solved
Alexa, Google Home and Siri
tezzlicious
Re: Domoticz-Google-Assistant (dzga)
Post by tezzlicious »
For many months I didn't have any issues, but lately I noticed that some of my lamps/switches didn't get their state correctly via in the home app. After looking into the log I noticed the following:
2020-12-04 17:24:13 - ERROR - 400 Client Error: Bad Request for url: https://homegraph.googleapis.com/v1/devices:reportStateAndNotification
2020-12-04 17:24:13 - ERROR - Error handling message {'inputs': [{'intent': 'action.devices.QUERY', 'payload': {'devices': [{'id': 'PushButton2373'}, {'id': 'ColorSwitch1093'}, {'id': 'Light1583'}, {'id': 'Light2259'}, {'id': 'Light952'}, {'id': 'ColorSwitch2672'}, {'id': 'Light889'}, {'id': 'PushButton2737'}, {'id': 'Selector3019'}, {'id': 'Light224'}, {'id': 'Selector2952'}, {'id': 'Outlet2604'}, {'id': 'Light2795'}, {'id': 'PushButton2733'}, {'id': 'Switch2796'}, {'id': 'ColorSwitch1096'}, {'id': 'Selector2956'}, {'id': 'Light1899'}, {'id': 'PushButton1220'}, {'id': 'Switch1445'}, {'id': 'Light2752'}, {'id': 'PushButton2724'}, {'id': 'Light2955'}, {'id': 'Light2837'}, {'id': 'PushButton2732'}, {'id': 'Light2818'}, {'id': 'ColorSwitch2708'}, {'id': 'Light2548'}, {'id': 'Light2692'}, {'id': 'ColorSwitch2695'}, {'id': 'PushButton2615'}, {'id': 'Light2661'}, {'id': 'ColorSwitch1138'}, {'id': 'PushButton2736'}, {'id': 'ColorSwitch2707'}, {'id': 'Switch1718'}, {'id': 'Light2543'}, {'id': 'Light1500'}, {'id': 'ColorSwitch1094'}, {'id': 'ColorSwitch1684'}, {'id': 'Light2562'}, {'id': 'ColorSwitch1137'}, {'id': 'ColorSwitch1134'}, {'id': 'ColorSwitch1136'}, {'id': 'Light1503'}, {'id': 'Light1039'}, {'id': 'Switch1441'}, {'id': 'ColorSwitch2709'}, {'id': 'Light2126'}, {'id': 'Switch2586'}, {'id': 'Light2751'}, {'id': 'ColorSwitch2671'}, {'id': 'Light2931'}, {'id': 'ColorSwitch1095'}]}}], 'requestId': '91921993758447447'}: {'errorCode': 'unknownError'}
Switching and dimming is working. Also for the devices reported in the log above.
Things I already tried:
- Sync devices
- Completely disconnect and reconnect the account from the Google Home app
- Generate a new JSON (new service account) from the cloud console
- Set report_state: false for these devices and also every selector device (was reading that could cause issues).
I don't know exactly when this started, I use docker and the container updates automatically to the :latest.
Hope someone can help me out. Thanks.
Nielsch
Post by Nielsch »
tezzlicious wrote: Friday 04 December 2020 17:35 For many months I didn't have any issues, but lately I noticed that some of my lamps/switches didn't get their state correctly via in the home app. After looking into the log I noticed the following:
- Sync devices
Same problem here, do you have Shelly dimmers?
tezzlicious
Nielsch wrote: Friday 04 December 2020 17:46
- Sync devices
No Shelly dimmers here.
hanryz
Domoticz version: 3.5837
Post by hanryz »
Guys, I have question concerning running DZGA behind Apache proxy, maybe somebody can help... I have setup the following in the apache conf:
<Location /projects/dzga/>
ProxyPass http://127.0.0.1:3030/
ProxyPassReverse http://127.0.0.1:3030/
</Location>
And I can access the login page and I can also login and setup domoticz IP etc. However, the number of connected Domoticz devices is always 0 although the DZGA tells me at startup that it is connected to Domoticz under 127.0.0.1:8080.
On the other hand, when I connect to DZGA directly via http://127.0.0.1:3030/settings and login, I see that the number of Domoticz devices is not zero, as it should be, and everything seems fine. In the apache log I can see the following:
AH00128: File does not exist: F:/NetworkIntranet/WEBSERVER/htdocs/log, referer: http://192.168.0.15/projects/dzga/setti ... =undefined
Herein "F:/NetworkIntranet/WEBSERVER/htdocs/log" is a directory under DocumentRoot "F:/NetworkIntranet/WEBSERVER/htdocs/" set in the Apache config.
Obviously, Apache cannot find the" F:/NetworkIntranet/WEBSERVER/htdocs/log" directory under the DocumentRoot. The question is why it is instructed to look there if there is a correct proxy setting?
Maybe somebody can provide a hint?
DewGew
Domoticz version: V4.10618
Post by DewGew »
tezzlicious wrote: Friday 04 December 2020 17:54
- Sync devices
400 error is usually missing string somewhere. Check if there is a special character or something missing in a device voicecontrol tag or in device_config in config.yaml
spawnol
Post by spawnol »
Nielsch wrote: Sunday 29 November 2020 22:02 Since my issue with Shelly Dimmer 2 is still there I thought it would be good to update the dimmers' firmwares and update dzga and try again. However. after updating dzga it doesn't work anymore. Tried uninstalling and installing both master and development. This is the error I get when starting manually:
  File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "Domoticz-Google-Assistant/__main__.py", line 4, in <module>
    from server import *
  File "Domoticz-Google-Assistant/server.py", line 6, in <module>
    from helpers import FILE_DIR
  File "Domoticz-Google-Assistant/helpers.py", line 13, in <module>
    import yaml
ModuleNotFoundError: No module named 'yaml'
How can I solve this?
I have exactly the same issue but nothing work for me..
How did you solve it ?
My DZGa service works when i put the SSL option to false..
Thanks !
Nielsch
Post by Nielsch »
spawnol wrote: Sunday 06 December 2020 11:58
    import yaml
Thanks !
I didn't solve it (yet)...
spawnol
Post by spawnol »
Nielsch wrote: Sunday 06 December 2020 12:32
    import yaml
Thanks !
So, you cannot synchronise your device with google ? or you are using NGROK ?
DewGew
Post by DewGew »
    import yaml
Thanks !
Try update with the install script:
bash <(curl -s https://raw.githubusercontent.com/DewGe ... install.sh)
spawnol
Post by spawnol »
DewGew wrote: Sunday 06 December 2020 14:07
Thanks !
Already tried... :'(
DewGew
Post by DewGew »
spawnol wrote: Sunday 06 December 2020 16:50
Running with reverse proxy or nginx
Nielsch
Post by Nielsch »
    import yaml
Thanks !
Apologies,I thought you meant another issue I have. Did you try this?: viewtopic.php?p=262461#p262461 . There should be a space before 'activate'
spawnol
Post by spawnol »
Nielsch wrote: Sunday 06 December 2020 19:54
    import yaml
Thanks !
Yes, it doesn't work.
With this configuration in the config.yaml :
use_ssl: true
ssl_key: # /etc/letsencrypt/live/xxxxx.duckdns.org/privkey.pem
ssl_cert: # /etc/letsencrypt/live/xxxxxx.duckdns.org/fullchain.pem
It seems to work but the result of the command : #python Domoticz-Google-Assistant
Connecting to Domoticz on http://XXX.X.X.X:XXXX
ssl_key and ssl_cert options are mandatory if use_ssl is True
When i take off the #, nothing works.
I have also an issue with the display when i tried to connect to Domoticz or DZGA with : https://....duckdns.org/Domoticz-Google-Assistant-settings
Do you know why ?
Capture d’écran 2020-12-06 à 23.39.14.png (38.39 KiB) Viewed 3860 times
DewGew
Post by DewGew »
    import yaml
Do the following to fix on Rpi within CLI:
type:
source Domoticz-Google-Assistant/env/bin/activate
then type:
pip3 install pyYAML
then type:
deactivate
Then type:
sudo service dzga restart
DewGew
Post by DewGew »
spawnol wrote: Sunday 06 December 2020 23:47
Thanks !
use_ssl: true
Do you know why ?
I try to reproduce this with ssl.
DewGew
Post by DewGew »
Thanks !
use_ssl: true
Do you know why ?
Try with ngrok, mybe you can get it to work with that
spawnol
Post by spawnol »
DewGew wrote: Monday 07 December 2020 8:56
use_ssl: true
Do you know why ?
But it worked with Nginx.. I used it... It didn't work since the update of Dzga...
I am disappointed...
spawnol
Post by spawnol »
Do you have any idea for this ? I have an issue with the display with http://toto.duckdns.org/Domoticz-Google ... t/settings
It works with http://localhost:3030/settings.
Capture d’écran 2020-12-07 201924.png (387.38 KiB) Viewed 3818 times
spawnol
Post by spawnol »
I reinstalled DZGA and nginx.. but when i tried with SSL (nginx)
pi@raspberrypi:~ $ python3 Domoticz-Google-Assistant/
Loading configuration...
Connecting to Domoticz on http://192.168.1.21:8080
Using SSL connection
File "Domoticz-Google-Assistant/__main__.py", line 109, in <module>
startServer()
File "Domoticz-Google-Assistant/__main__.py", line 52, in startServer
secure(server)
File "Domoticz-Google-Assistant/__main__.py", line 26, in secure
server.socket = ssl.wrap_socket (server.socket, keyfile=key, certfile=cert, server_side=True, ssl_version=ssl.PROTOCOL_TLSv1_2)
File "/usr/lib/python3.7/ssl.py", line 1216, in wrap_socket
context.load_cert_chain(certfile, keyfile)
PermissionError: [Errno 13] Permission denied
DewGew
Post by DewGew »
spawnol wrote: Monday 07 December 2020 21:28 I reinstalled DZGA and nginx.. but when i tried with SSL (nginx)
startServer()
secure(server)
You cant use ssl with ngrok. Set ssl to false. Ngrok has already ssl enabled
