Camera screenshot on doorbell
Basssment
Domoticz version: 4.9700
Post by Basssment »
Hi all
i'm trying to get a screenshot of my camera in a popup on dashticz when the doorbel is on
I do get a pop up but the field would not show an image. (chrome)
If i try the url directly in chrome i do see an image in the browser.
When i use it on my pc on firefox it does work but not on chrome, my kioskbrowser on my tablet is working on chrome where it should work finaly.
I tried adding the link to the domoticz url of the camera but then all i get is an download of the image.
Who can help me figure out what i am doing wrong
my config.js :
// Scene deurbel aan
blocks[scene_deurbel_aan] = {}
blocks[scene_deurbel_aan]['title'] = 'Bel'
blocks[scene_deurbel_aan]['width'] = 2;
blocks[scene_deurbel_aan]['hide_data'] = true;
blocks[scene_deurbel_aan]['playsound'] = 'sounds/ping.mp3';
blocks[scene_deurbel_aan]['openpopup'] = {}
blocks[scene_deurbel_aan]['openpopup']['url'] = 'http://user:password@[my cam ip]:80/ISAPI/Streaming/channels/101/picture?user=user&pwd=password';
blocks[scene_deurbel_aan]['openpopup']['auto_close'] = 8; //seconds
Bas
Lokonli
Re: Camera screenshot on doorbell
Post by Lokonli »
Basssment wrote: Wednesday 02 December 2020 21:49 Hi all
my config.js :
Bas
Maybe Chrome doesn't like to show an image directly, but expects a HTML page.
To test, create a file image.html in for instance the custom folder:
<image src="http://user:password@[my cam ip]:80/ISAPI/Streaming/channels/101/picture?user=user&pwd=password"></image>
and use in CONFIG.js:
blocks[scene_deurbel_aan]['openpopup']['url'] = 'custom/image.html'
It can also be a cross origin issue. In that case you can see an error on the network tab of DevTools (F12 to open)
You can fix that by using the cors proxy as url. Use the following url for your image:
./vendor/dashticz/cors.php?http://user:password@[my cam ip]:80/ISAPI/Streaming/channels/101/picture?user=user&pwd=password
./vendor/
Basssment
Post by Basssment »
./vendor/
Thank you Lokonli!
The image url did not work but the Cors proxy did!
Now only have to figure out how to make the image fit the popup :)
edit:
was a bit to soon :(
it works most of the times but when trying several times in 10% of the popups i get the following error
Warning: file_get_contents(http://[email protected]:80/ISAPI/Streaming/c ... d=password): failed to open stream: HTTP request failed! HTTP/1.0 500 Internal Server Error in /var/www/html/vendor/dashticz/cors.php on line 28
Warning: Cannot modify header information - headers already sent by (output started at /var/www/html/vendor/dashticz/cors.php:28) in /var/www/html/vendor/dashticz/cors.php on line 33
Bas
Lokonli
Post by Lokonli »
Probably you can combine both suggestions.
