SMA Sunny Boy 1.5
fdemees
Domoticz version: 2024.7
Re: SMA Sunny Boy 1.5
Post by fdemees »
If your SMA can be reached without SSL, please give it a try. (e.g. http on port 80)
If your Syno is really too old, it is possible that its openssl libraries do not support the underlying more recent TLS versions.
Domoticz on Rpi 3B+, ZigbeeforDomoticz, Sonoff Zigbee coordinator, several Sonoff/ESPEasy/Tasmota, IPX800, several Zigbee things, Ksenia Lares, HomeWizard batteries
Huff002
Post by Huff002 »
I I can only reach my SMA via https, I can't find a setting to disable https. (Tripower 4.0 with firmware 3.10.10.R).
My Synology is a RS812+ with DSM 6.2.3-25426 Update 2
fdemees
Post by fdemees »
SSL can be tricky.
Old protocols are e.g. SSLv3, TLS1.0
Newer include TLS1.2, 1.3.
There must be a matching protocol between the client and the server, and then a matching cipher.
The user manual https://manuals.sma.de/SBxx-1VL-40/en-U ... 30027.html seems to indicate that http is supported.
This means connecting directly to the IP address of your inverter, not the sunnyportal.com website.
Huff002
Post by Huff002 »
192.168.0.4 redirects to https://192.168.0.4 if I open the webpage in a browser.
I searched within the settings of the SMA but can't find any settings, not for security, SSL, TLS, 443, ...
rklomp
Post by rklomp »
Could you make a tcpdump and share this?
Would be something like:
tcpdump -i any -w capture.pcap host 192.168.0.4
Let it run for a minute and than stop with ctrl-c so it has captured at least one try by the plugin to connect to the sma. Share the generated file called capture.pcap.
You can share it in a private message if you prefer that.
Huff002
Post by Huff002 »
I can't get tcpdump to do anything (i'm trying with windump).
What do you expect to see?
Is is something that I can get with Wireshark?
rklomp
Post by rklomp »
You should run it on the synology device you run domoticz on. I want to see the ssl handshake process of the plugin with the sma device.
Huff002
Post by Huff002 »
Zipped the pcap file.
capture.zip
(3.74 KiB) Downloaded 291 times
rklomp
Post by rklomp »
In the log I do not see a SSL handshake, but I see it tries to setup the connection via HTTP port 80. What is you current configuration? Have configured it to use HTTPS? Can you share a screenshot?
artstam
Post by artstam »
I switched from synology (did not work) to raspberry pi. I installed python, git and pip and i can add the hardware. I see 2 devices but no data.
The error log is:
2020-12-02 13:16:52.186 (Zonnepanelen) No valid response from SMA inverter on 192.168.178.49; {'err': 404}
2020-12-02 13:16:52.703 Error: (Zonnepanelen) Failed to retrieve data from 192.168.178.49, cancelling...
2020-12-02 13:16:56.206 (Zonnepanelen) Pushing 'onHeartbeatCallback' on to queue
2020-12-02 13:16:56.211 (Zonnepanelen) Processing 'onHeartbeatCallback' message
2020-12-02 13:16:56.211 (Zonnepanelen) Calling message handler 'onHeartbeat'.
2020-12-02 13:16:56.211 (Zonnepanelen) onHeartbeat called 7
Any idea?
Thomas
rklomp
Post by rklomp »
Can you provide de full debug log of the plugin including initialization?
Go to hardware, select the SMA Sunny Boy Solar Inverter and press update. This will trigger a reload of the plugin.
Than go to log and copy the full log output.
Huff002
Post by Huff002 »
rklomp wrote: Tuesday 01 December 2020 15:15 In the log I do not see a SSL handshake, but I see it tries to setup the connection via HTTP port 80. What is you current configuration? Have configured it to use HTTPS? Can you share a screenshot?
New log and printscreen of settings attached.
capture.zip
(830 Bytes) Downloaded 311 times
rklomp
Post by rklomp »
Huff002 wrote: Wednesday 02 December 2020 14:56 New log and printscreen of settings attached.
Thanks, For some reason I do not see the SSL traffic. Can you try with -s 65535 added to the command?
tcpdump -i any -s 65535 -w capture.pcap host 192.168.0.4
Huff002
Post by Huff002 »
I let it run longer and did a update on the hardware in Domotics while running.
New log attached, it looks the same for me 8-)
capture.zip
(1.57 KiB) Downloaded 268 times
artstam
Post by artstam »
rklomp wrote: Wednesday 02 December 2020 14:37 Can you provide de full debug log of the plugin including initialization?
Changed to https and now the kwh is visible!
2020-12-02 15:36:04.747 Status: (Zonnepanelen) Stop directive received.
2020-12-02 15:36:04.747 Status: (Zonnepanelen) Exiting work loop.
2020-12-02 15:36:04.775 Status: (Zonnepanelen) Closing session to SMA inverter on 192.168.178.49
2020-12-02 15:36:05.788 (Zonnepanelen) Debug logging mask set to: NONE
2020-12-02 15:36:05.448 Status: (Zonnepanelen) Stopping threads.
2020-12-02 15:36:05.448 Status: (Zonnepanelen) Stopped.
2020-12-02 15:36:05.448 Status: (Zonnepanelen) Started.
2020-12-02 15:36:05.787 Status: (Zonnepanelen) Entering work loop.
2020-12-02 15:36:05.787 Status: (Zonnepanelen) Initialized version 1.0.4, author 'rklomp'
2020-12-02 15:36:06.195 Status: (Zonnepanelen) Successfully logged in to SMA inverter on 192.168.178.49
Huff002
Post by Huff002 »
artstam wrote: Wednesday 02 December 2020 14:30 I switched from synology (did not work) to raspberry pi. I installed python, git and pip and i can add the hardware. I see 2 devices but no data.
What Synology and what DSM version did you used?
rklomp
Post by rklomp »
Huff002 wrote: Wednesday 02 December 2020 15:11 I let it run longer and did a update on the hardware in Domotics while running.
Strange. I would expect something like this:
artstam
Post by artstam »
Huff002 wrote: Wednesday 02 December 2020 15:42
Synology 211+ en 6.2 hardware
Huff002
Post by Huff002 »
That is the same software version as my Synology.
Maybe @rklomp is right and it is caused by the openssl libraries.
If I do a Google search on openssl tls synology I only find information about the ssl certificate on the Synology itself, nothing about SSL connection to another device. Is there any way to make sure this is the problem?
artstam
Post by artstam »
Huff002 wrote: Wednesday 02 December 2020 18:23 That is the same software version as my Synology.
I think my problem is that i couldn't install a recent domoticz version (like node-mydomoathome-0.2.39.spk) because my hardware did not allow me to install node.js_v4!
But it is now working great on my raspberry pi!
