Fibaro FGMS001 Motion Sensor - Temperature Not Showing
geoffnewnham
Post by geoffnewnham »
have added a Fibaro FGMS001 Motion Sensor to my Domoticz, V2.2121, all sensors added and showing ok except the Temperature sensor, Any ideas on how I can get Temp Sensor to show up? :shock:
Best Regards
Geoff
willie-p
Re: Fibaro FGMS001 Motion Sensor - Temperature Not Showing
Post by willie-p »
Geoff,
I got my Fibaro FGMS-001version 2.6 yesterday and had the same problem.
After a while all the sensors came visible.
If the problem still exists perhaps re-include will work?
Cheers,
Will
micha_pr
Post by micha_pr »
Should work.
Try to reinclude (include again, then will be the ID the same) or wakeup the device again after reinclude.
Please check the settings (parameters) - hers can be a big delta for reporting (standard 1 degree). You could change it for a reporting time frame - but remember about battery...
A good idea is to modify the LED "light show" - if you want to save battery. I have switched it off - do not need it at every place ;)
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
nay
Post by nay »
I found for reliable operation you need the FGMS001 to have version 2.6 of the firmware otherwise temp/lux does not report reliably.
booster
Post by booster »
I was thinking about buying the FGMS001, but accurate temp/lux is important....
If I get one with an older firmware, can this be updated?
Connected to:
-Pi3; Aeon Labs Z-Stick; Fibaro Switches, Roller Shutter and Motion Sensors; Qubino Dimmers; P1 Port + Youless, MiLight; HUE Bridge; Forest shuttle Z-Wave; RFLink + KAKU; Voltcraft CO20; Everspring floodsensors; GreenWave PN-6; NEO Sensors
elgarne
Post by elgarne »
In my case, I have two FGMS001 and see both of them as a Sensor of type Lightning 2, cf. attached image.
In the logs, I see
2014-12-30 05:00:05 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2014-12-30 05:00:05 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
Any idea how I can fix that?
Thanks.
JDD
Post by JDD »
Hello
I have also the same problem, but with the Lux.
This information is not showed in domoticz, but I can see it in the zwave me interface.
I run an instance of Jeedom for test and it has the lux from the same zwaveme.
And zaweme tells me that the firmware is 2.6
Any idea?
Scones
Post by Scones »
Hi folks,
I'm in the same boat. It took me ages to get the Fibaro to appear at all.
I now have the sensor appearing as a node in setup->Hardware->Z-Wave USB -> Setup.
If I click on the Fibaro sensor node, I see all of the settings, including PIR, tamper, and temperature.
In Setup->Devices I have two sensors, one being the motion sensor and I think the other being the tamper. However, I cannot get a temperature sensor in Domoticz
I have tried adjusting the values to make the sensor report the LUX and temperature more often.
Any suggestions on what to try next?
Scones
Post by Scones »
Adding this here to help people in future. As I've put elsewhere on the forum, I managed to fix this by going into Setup->Hardware->USB Z-Wave->Setup and edited the Fibaro node settings.
Once I'd updated the node settings to report temperature and LUX levels, it was a case of waiting a while and then Domoticz created the devices as required.
gomsoo
Post by gomsoo »
I have actually the same issue.
I had hard reset my usb-zwave stick, reinclude each device, which works fine.
But my Fibaro Eye (Motion Sensor) isn't listet in my device list (for all my 3 eyes).
Before the resetting , I hadn't any issues about that.
I'm exclude, include the device, reboot the systems multiple times, set and change the configuration in the nodes (that works).
Any other suggestions on that topic?
Domoticz Version: 4.10826
