For the purpose of the plugin and to integrate a specific device, I need to get the end user entering a Code . Do we have any Widget type which allow the end user entering Digits/Chars ?
I have in parallel asked for UserVariables from the Python Plugin Framework but I had a look to teh source code, and got confirmation that there is nothing native ! ( viewtopic.php?f=65&t=34481)
Input device
Thorgal789
- Target OS: -
Re: Input device
I m searching the same thing, an input widget, you have found a workaround on your side ?
Re: Input device
Unfortunately not with Domoticz. I just enhanced the plugin Web UI that we have developed.Thorgal789 wrote: Saturday 28 November 2020 18:49 I m searching the same thing, an input widget, you have found a workaround on your side ?
timmpo
Re: Input device
I ended up with this
viewtopic.php?p=293175#p293175
Re: Input device
You can use the device description to get inputs from user
Thorgal789
- Target OS: -
Re: Input device
Ha yes, right I m using too device description, but your "edit widget" is so nice for other thing.
