Trigger script at specific value
Enz0jacco
Post by Enz0jacco »
Hey guys
I would like to turn of my tv plug when there is no usage.
I wrote a script and it’s working but the script checks every 10sec or so because the plug sends its usage every 10sec.
Is there a way to trigger the script only when the usage value is below let’s say 20 Watts?
Thnx Jacco
Sent from my iPad using Tapatalk
Re: Trigger script at specific value
Enz0jacco wrote: Wednesday 25 November 2020 21:39 Is there a way to trigger the script only when the usage value is below let’s say 20 Watts?
Yes. If you share the script I can show you how.
Can you also please state the domoticz / dzVents version you use?
Enz0jacco
Post by Enz0jacco »
thnx for answering.
Version: 2020.2 (build 12494)
dzVents Version: 3.0.15
here is the script
		variables = {17},
		devices = {237},
	execute = function(dz, item)
	    local STEKKER = dz.devices(238)
        local TVverbruik = dz.devices(237).actualWatt
        local TVstatusvariable = dz.variables(17)
                if  item.isDevice                                   and
                    TVverbruik < 20                                 and
                    TVstatusvariable.value ~= 'Off'                 then
                        dz.openURL('http://127.0.0.1:8084/json.htm?type=command&param=updateuservariable&idx=17&vname=TV&vtype=2&vvalue=Off').afterSec(30)
                        dz.log('TV gaat uit over 30 sec')
                elseif  item.isDevice                               and
                        TVverbruik > 20                             and
                        TVstatusvariable.value ~= 'On'              then
                            TVstatusvariable.set('On')
                            cancelQueuedCommands()
                            dz.log('TV is AAN')
                elseif  item.isVariable                             and
                        TVstatusvariable.value == 'Off'             then
                            STEKKER.switchOff().checkFirst()
                            dz.log('Stroom TV uit')
Enz0jacco wrote: Wednesday 25 November 2020 23:57 Version: 2020.2 (build 12494) / dzVents Version: 3.0.15
Below script should do it. Don't know if you use the TVstatusvariable elsewhere so I left it in but script can do the same without it
using
STEKKER.switchOff().afterSec(delay)
return
    active = function(domoticz)
                return domoticz.devices(237).actualWatt < 20
            end,
    on =
        variables =
            17,
        devices =
            237,
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
        marker = 'TV control',
        local delay = 30
        if  item.isDevice and TVstatusvariable.value ~= 'Off' then
            local offTime = dz.time.addSeconds(delay).rawTime
            TVstatusvariable.set('Scheduled for Off at ' .. offTime)
            TVstatusvariable.set('Off').afterSec(delay)
            dz.log('TV gaat uit over ' .. delay .. ' seconden (' .. offTime .. ').', dz.LOG_DEBUG )
        elseif item.isVariable and TVstatusvariable.value == 'Off' then
            dz.log('Stroom TV uit', dz.LOG_DEBUG )
Enz0jacco
Post by Enz0jacco »
thnx for the quick reply Waaren!
it is working but now when the tv is off and thus the usage is less than 20W the script is still triggered every 10sec.
is it possible that the script just triggers once and then finished until tv is back on/off again?
Enz0jacco wrote: Thursday 26 November 2020 9:51 thnx for the quick reply Waaren!
Yes, Change line 4 to
return domoticz.devices(238).active and domoticz.devices(237).actualWatt < 20
Enz0jacco
Post by Enz0jacco »
working perfect Waaren thank u so much!
never used the active line before in dzvent but defenitively gonna do it some more!
Enz0jacco wrote: Thursday 26 November 2020 14:42 ... but definitively gonna do it some more!
It's there to help you but please be aware that the function code used in the active segment is executed every minute and at every device change in the system so best to limit yourself and don't put a lot of logic in that function.
