monitoring and alert Domoticz
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
I have two Raspberry's. Both with Domoticz. One as master and one as slave configured.
They do communicate with each other.
Now I want to make a switch on both of them, that will tricker when the other domoticz is offline/online.
I had a look at Http/https poller, but I do no understand how this would work for me.
Has anyone creates such a switch? And how do I configure this?
azonneveld
Domoticz version: 2024.4
Re: monitoring and alert Domoticz
Post by azonneveld »
Share a sensor to each other that is updated regularly, f.i. the cpu load.
Then create a notification on that sensor when last update is greater than x minutes.
Or in case you would like to have a separate switch, test for the last update and trigger the switch from script.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
AllesVanZelf
That is a good solution.
I will try that out
