Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee) Topic is solved
Thorgal789
Re: Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee)
Post by Thorgal789 »
You have them just before ^^
I don't use it, because I know weel the API, but with it you can easier :
- change setting
- delete/rename device (even if this one is not visible in phoscon
- retreive information on device
- list them by sensor/light/group
marsbuck
Post by marsbuck »
Hello
Maybe you can help this newbee. I have tried to install the conbee USB stick to use it in domoticz. I followed this instruction: https://www.robbshop.nl/blog/conbee-usb ... leren.html successfully. I have added some sensors. I am able to start the application at my raspberry and see the conBee II.
Then I started Domoticz and allowed to find for new hardware but I didn't find the deconz bridge.
This evening I looked at it again and couldn't create an api key anymore: Connection error : [Errno 111] Connection refused , but I don't think this was my initial problem in not finding the conbee stick in domoticz.
Any hints in where and how to find the error are welcome, thanks!
Thorgal789
Hello, ok so phoscon is working but not the connexion between deconz and domoticz ?
Can you show the hardware configuration in domoticz ?
Are you sure for ip and port ? you can find them here https://phoscon.de/discover
If you can't see them on this link deconz is probably off ATM (and phoscon have probably stopped working too).
If you have succed to create an api key, you can keep the same, they are memorised.
Plantje
Post by Plantje »
Thorgal is always here to help! Great!
marsbuck
Post by marsbuck »
@Thorgal. Thank you for your help. I checked what you suggested and found that everything was in order. My mistake was that I didn't manually add the deconz plugin in Domoticz. I expected it to appear automatically. sorry to have bothered you with this. Hope you all have a great day
bitjeverkeerd
Post by bitjeverkeerd »
Since I updated Deconz to version 2.05.88 (coming from version 2.05.84) my Ikea remote controls (the version with 5 buttons) no longer work in Domoticz.
The remote controls are visible but no longer respond when a button is pressed. They still work when I use them through phoscon.
And are also still visible in the graphic environment of Deconz. Hence, I think the problem is in the REST api or plugin.
are there more people with this problem?
Plantje
Post by Plantje »
Thorgal789 wrote: Monday 02 November 2020 17:06 You have them just before ^^
- change setting
So, with this you basically have something like with the Z-Wave node overview?
I should test it...if I have some time left :)
Thorgal789
bitjeverkeerd wrote: Friday 20 November 2020 13:58 Since I updated Deconz to version 2.05.88 (coming from version 2.05.84) my Ikea remote controls (the version with 5 buttons) no longer work in Domoticz.
Hello, If they works in deconz but not domoticz, yes the problem was in the plugin, they are using both same API.
Can you enable better log, in hardware "debug" > "debug info only", then press "update"
It will restart the plugin, after that can you shwo me the log you have when pressing a button pls ?
bitjeverkeerd
Thorgal789 wrote: Friday 20 November 2020 17:11
Hello Thorgal789
I have created a log file in my test system (a small system with 2 remote controls and 3 lamps).
The strange thing is that the remote controls no longer work after a reboot of the system (also not visible in the log file that something happened).
When I wait about 3 hours, the remote controls work again.
So maybe there is no error in the plugin, but something went wrong went wrong while updating deConz?
2020-11-23 11:12:31.652 Status: Incoming connection from: 192.168.51.58
2020-11-23 11:12:34.047 (ConBee) onHeartbeat called
2020-11-23 11:12:44.063 (ConBee) onHeartbeat called
2020-11-23 11:12:46.267 (ConBee) onMessage called
2020-11-23 11:12:46.268 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '2', 'r': 'sensors', 'state': {'buttonevent': 1002, 'lastupdated': '2020-11-23T10:12:46.238'}, 't': 'event', 'uniqueid': '90:fd:9f:ff:fe:13:73:35-01-1000'}
2020-11-23 11:12:46.268 (ConBee) ### Update device (ConBee - DenE AB2) : {'nValue': 10, 'sValue': '10'}
2020-11-23 11:12:46.305 (Dummy) Light/Switch (Lampjes GU10)
2020-11-23 11:12:46.383 (ConBee) onCommand called for Unit 3: Parameter 'Set Level', Level: 1, Hue:
2020-11-23 11:12:46.383 (ConBee) Send Command /api/2135F90D23/lights/4/state with {'on': True, 'bri': 3} (0 in buffer)
2020-11-23 11:12:46.384 (ConBee) Making Request : http://127.0.0.1:80/api/2135F90D23/lights/4/state with params {'on': True, 'bri': 3}
2020-11-23 11:12:46.404 (ConBee) Request Return : [{"success":{"/lights/4/state/on":true}},{"success":{"/lights/4/state/bri":3}}]
2020-11-23 11:12:46.404 (ConBee) Classic Data : [{'success': {'/lights/4/state/on': True}}, {'success': {'/lights/4/state/bri': 3}}]
2020-11-23 11:12:46.405 (ConBee) onCommand called for Unit 2: Parameter 'Set Level', Level: 1, Hue:
2020-11-23 11:12:46.405 (ConBee) Send Command /api/2135F90D23/lights/3/state with {'on': True, 'bri': 3} (0 in buffer)
2020-11-23 11:12:46.405 (ConBee) Making Request : http://127.0.0.1:80/api/2135F90D23/lights/3/state with params {'on': True, 'bri': 3}
2020-11-23 11:12:46.423 (ConBee) Request Return : [{"success":{"/lights/3/state/on":true}},{"success":{"/lights/3/state/bri":3}}]
2020-11-23 11:12:46.424 (ConBee) Classic Data : [{'success': {'/lights/3/state/on': True}}, {'success': {'/lights/3/state/bri': 3}}]
2020-11-23 11:12:46.424 (ConBee) onCommand called for Unit 1: Parameter 'Set Level', Level: 1, Hue:
2020-11-23 11:12:46.424 (ConBee) Send Command /api/2135F90D23/lights/2/state with {'on': True, 'bri': 3} (0 in buffer)
2020-11-23 11:12:46.425 (ConBee) Making Request : http://127.0.0.1:80/api/2135F90D23/lights/2/state with params {'on': True, 'bri': 3}
2020-11-23 11:12:46.443 (ConBee) Request Return : [{"success":{"/lights/2/state/on":true}},{"success":{"/lights/2/state/bri":3}}]
2020-11-23 11:12:46.443 (ConBee) Classic Data : [{'success': {'/lights/2/state/on': True}}, {'success': {'/lights/2/state/bri': 3}}]
2020-11-23 11:12:46.494 (ConBee) onMessage called
2020-11-23 11:12:46.494 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '4', 'r': 'lights', 'state': {'alert': None, 'bri': 3, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '58:8e:81:ff:fe:0e:73:19-01'}
2020-11-23 11:12:46.496 (ConBee) ### Update device (ConBee - Lamp GU10 Nieuw) : {'nValue': 1, 'sValue': '1'}
2020-11-23 11:12:46.512 (ConBee) onMessage called
2020-11-23 11:12:46.513 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '65520', 'r': 'groups', 'state': {'all_on': False, 'any_on': True}, 't': 'event'}
2020-11-23 11:12:46.514 (ConBee) ### Update device (ConBee - All) : {'nValue': 1, 'sValue': 'on'}
2020-11-23 11:12:46.525 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '1', 'r': 'groups', 'state': {'all_on': False, 'any_on': True}, 't': 'event'}
2020-11-23 11:12:46.525 (ConBee) ### Update device (ConBee - DenE) : {'nValue': 1, 'sValue': 'on'}
2020-11-23 11:12:46.541 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '3', 'r': 'lights', 'state': {'alert': None, 'bri': 3, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '00:0b:57:ff:fe:d8:3b:01-01'}
2020-11-23 11:12:46.543 (ConBee) ### Update device (ConBee - Lamp GU10) : {'nValue': 1, 'sValue': '1'}
2020-11-23 11:12:46.564 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '2', 'r': 'lights', 'state': {'alert': None, 'bri': 3, 'colormode': 'ct', 'ct': 370, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '14:b4:57:ff:fe:44:3e:d7-01'}
2020-11-23 11:12:46.566 (ConBee) ### Update device (ConBee - Lamp GU10 Kleur) : {'nValue': 1, 'sValue': '1', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":201,"ww":201,"cw":54}'}
2020-11-23 11:12:46.590 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '65520', 'r': 'groups', 'state': {'all_on': True, 'any_on': True}, 't': 'event'}
2020-11-23 11:12:46.592 (ConBee) ### Update device (ConBee - All) : {'nValue': 1, 'sValue': 'on'}, IGNORED , no changes !
2020-11-23 11:12:46.592 (ConBee) onMessage called
2020-11-23 11:12:46.592 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '1', 'r': 'groups', 'state': {'all_on': True, 'any_on': True}, 't': 'event'}
2020-11-23 11:12:46.594 (ConBee) ### Update device (ConBee - DenE) : {'nValue': 1, 'sValue': 'on'}, IGNORED , no changes !
2020-11-23 11:12:46.594 (ConBee) onMessage called
2020-11-23 11:12:46.594 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '4', 'r': 'lights', 'state': {'alert': None, 'bri': 2, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '58:8e:81:ff:fe:0e:73:19-01'}
2020-11-23 11:12:46.595 (ConBee) ### Update device (ConBee - Lamp GU10 Nieuw) : {'nValue': 1, 'sValue': '0'}
2020-11-23 11:12:46.662 (ConBee) onMessage called
2020-11-23 11:12:46.663 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '2', 'r': 'lights', 'state': {'alert': None, 'bri': 2, 'colormode': 'ct', 'ct': 370, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '14:b4:57:ff:fe:44:3e:d7-01'}
2020-11-23 11:12:46.663 (ConBee) ### Update device (ConBee - Lamp GU10 Kleur) : {'nValue': 1, 'sValue': '0', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":201,"ww":201,"cw":54}'}
2020-11-23 11:12:46.287 Status: LUA: ConBee - DenE AB2 - Toggle On/Off
2020-11-23 11:12:46.288 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_ConBee - DenE AB2.lua
2020-11-23 11:12:46.322 Status: LUA: Lampjes GU10 1%
2020-11-23 11:12:46.324 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Lampjes GU10.lua
2020-11-23 11:12:51.531 (ConBee) onMessage called
2020-11-23 11:12:51.532 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '4', 'r': 'lights', 'state': {'alert': None, 'bri': 3, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '58:8e:81:ff:fe:0e:73:19-01'}
2020-11-23 11:12:51.533 (ConBee) ### Update device (ConBee - Lamp GU10 Nieuw) : {'nValue': 1, 'sValue': '1'}
2020-11-23 11:12:51.598 (ConBee) onMessage called
2020-11-23 11:12:51.598 (ConBee) ### WebSocket Data : {'e': 'changed', 'id': '2', 'r': 'lights', 'state': {'alert': None, 'bri': 3, 'colormode': 'ct', 'ct': 370, 'on': True, 'reachable': True}, 't': 'event', 'uniqueid': '14:b4:57:ff:fe:44:3e:d7-01'}
2020-11-23 11:12:51.599 (ConBee) ### Update device (ConBee - Lamp GU10 Kleur) : {'nValue': 1, 'sValue': '1', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":201,"ww":201,"cw":54}'}
2020-11-23 11:12:54.119 (ConBee) onHeartbeat called
2020-11-23 11:12:54.119 (ConBee) ### Update device (ConBee - DenE AB2) : {'nValue': 0, 'sValue': 'Off'}
2020-11-23 11:13:00.028 Status: LUA: evaluating ConBee zigbee gateway
2020-11-23 11:13:03.744 (ConBee) onMessage called
2020-11-23 11:13:03.744 (ConBee) ### WebSocket Data : {'attr': {'colorcapabilities': 0, 'ctmax': 65279, 'ctmin': 0, 'id': '2', 'lastannounced': '2020-11-17T06:32:41Z', 'lastseen': '2020-11-23T10:13Z', 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb GU10 WS 400lm', 'name': 'Lamp GU10 Kleur', 'swversion': '2.0.029', 'type': 'Color temperature light', 'uniqueid': '14:b4:57:ff:fe:44:3e:d7-01'}, 'e': 'changed', 'id': '2', 'r': 'lights', 't': 'event', 'uniqueid': '14:b4:57:ff:fe:44:3e:d7-01'}
2020-11-23 11:13:04.145 (ConBee) onHeartbeat called
2020-11-23 11:13:08.503 (ConBee) onMessage called
2020-11-23 11:13:08.503 (ConBee) ### WebSocket Data : {'attr': {'id': '3', 'lastannounced': '2020-11-18T03:11:11Z', 'lastseen': '2020-11-23T10:13Z', 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb GU10 W 400lm', 'name': 'Lamp GU10', 'swversion': '1.2.214', 'type': 'Dimmable light', 'uniqueid': '00:0b:57:ff:fe:d8:3b:01-01'}, 'e': 'changed', 'id': '3', 'r': 'lights', 't': 'event', 'uniqueid': '00:0b:57:ff:fe:d8:3b:01-01'}
2020-11-23 11:13:10.907 (ConBee) onMessage called
2020-11-23 11:13:10.907 (ConBee) ### WebSocket Data : {'attr': {'id': '4', 'lastannounced': '2020-08-20T13:35:43Z', 'lastseen': '2020-11-23T10:13Z', 'manufacturername': 'IKEA of Sweden', 'modelid': 'TRADFRI bulb GU10 WW 400lm', 'name': 'Lamp GU10 Nieuw', 'swversion': '2.3.050', 'type': 'Dimmable light', 'uniqueid': '58:8e:81:ff:fe:0e:73:19-01'}, 'e': 'changed', 'id': '4', 'r': 'lights', 't': 'event', 'uniqueid': '58:8e:81:ff:fe:0e:73:19-01'}
2020-11-23 11:13:14.162 (ConBee) onHeartbeat called
2020-11-23 11:13:14.263 (ConBee) onMessage called
2020-11-23 11:13:14.263 (ConBee) ### WebSocket Data : {'attr': {'id': '1', 'lastannounced': None, 'lastseen': '2020-11-23T10:13Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'swversion': '0x26580700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:04:8b:6c-01'}, 'e': 'changed', 'id': '1', 'r': 'lights', 't': 'event', 'uniqueid': '00:21:2e:ff:ff:04:8b:6c-01'}
2020-11-23 11:13:14.264 (ConBee) Banned/Ignored device > 1 (lights)
2020-11-23 11:13:24.132 (ConBee) onHeartbeat called
Thorgal789
I don't see something special in the log.
You say nothing is visible in log when the device don't work, but it s still working in phoscon ? And yes can be from zigbee side, but the network don't need 3h to be operationnal.
Spam problem ? there is lot of commands in a few interval, you can use zigbee group (group are creating a new widget), and put the id 1/2/3/4 inside, like that you can send only 1 command instead of 4
bitjeverkeerd
Thorgal789 wrote: Monday 23 November 2020 17:11 I don't see something special in the log.
Hi Thorgal789,
I did some more tests. I have reinstalled my test system several times.
I have always used the sd-card images of Dresden with pre-installed deconz software as a basis.
Until the deConz version 2_05_84 stable everything works fine.
With higher versions (2_05_87_stable, 2_05_88_stable and the latest beta) the Ikea remote controls only work after a few hours in domoticz.
In phoscon they work immediately after starting deconz.
I am using a Raspberry 3B and a Conbee 2 usb and Domoticz 2020.2.11995 stable.
I have updated the firmware of the Conbee 2 usb to firmware 26680700. This made no difference.
Thorgal789
the Ikea remote controls only work after a few hours in domoticz. In phoscon they work immediately after starting deconz.
So it s seem it s from the plugin, but we are using same API.
You don't use "direct bind" or scenario in phoscon ?
How you can the remote is working in phoscon, I haven't button event displayed on my side.
But when it don't work, at start, on domoticz, there is no websockets return on domoticz logs ? If it work on phoscon in same time, as we are using same api, you will probably can see something usefull on logs.
It s possible too looking on deconz log on deconz itself with selecting "http" but there is so much informations ...
bitjeverkeerd
Thorgal789 wrote: Wednesday 02 December 2020 17:13
I have no direct connections between remote controls and lamps.
I have connected a remote control via the switch editer in phoscon to a group of lamps. I don't normally do this
only now to test whether the remote control still works in phoscon. And he does.
Nothing happens in the domoticz log when I press a button on the remote control. Controlling the lamps from domoticz does work.
The temperature humidity sensor also works normally. After a few hours, the remote controls also work normally again.
How can I log into deCONZ?
Thorgal789
It's ok if you have added the switch to a bulb group, it s not direct bind.
But it still working in phoscon in same time ?
I realy don't understand what happen, phoscon use the same websocket than domoticz, I don't see why phoscon can receive websocket information and not domoticz.
And it s not the plugin fault, else you will receive malformed or bad websocket return, and you haven't websocket return at all.
Do you have the GUI, if yes, you have logging in "help","http" will print you all websocket but too much talkative, info_L2 and error_L2 will be enought
Else if you are using headless, the better way is launching deconz in debug mode https://github.com/dresden-elektronik/d ... ebug-flags
You can too use a websocket client on your browser, to spy them. But as domoticz display all websocket logs, it's not possible phoscon receive websocket notifications that domoticz don't receive. You will see exaclty same notifications than in domoticz.
Plantje
Post by Plantje »
I am not an expert, but my 2 cents: the plugin in Domoticz doesn't talk to deCONZ/Phoscon. Most likely reinstalling the plugin or reconfiguring it will help
Thorgal789
Yep it doesn't talk to phoscon, but phoscon and domotic are listening the same websocket server, so I don't understand how something can work on one and not the other ...
Perhaps a bad synthax on websocket notification.
bitjeverkeerd
Thorgal789 wrote: Thursday 03 December 2020 16:39 Yep it doesn't talk to phoscon, but phoscon and domotic are listening the same websocket server, so I don't understand how something can work on one and not the other ...
I have probably found the solution. When I set the correct time zone in phoscon (same time as domoticz) then the remote controls work immediately after a restart of the system (rpi3).
It remains strange that this was apparently not an issue until deConz version 2_05_84.
Thorgal789
Ha ?
Lol, yeah realy curious, I will ask to devs if it s something normal ...
Thorgal789
So no reaction yet about your strange bug, but perhaps someone will make a try too to reproduce it. But I don't understand why you are alone with it yet.
BTW I will soon upload a new plugin version, so if someone want to test the beta version before ...
- Correction to support Ally thermostat (@johnsprogs)
- Now the Xiaomi sensor return the 3 angles (@flopp999)
- The xiaomi cube can give complete information (@kispalsz )
- Color correction for devices that don't support XY
- The frontend (@JayPearlman)
- Support of the Lidl Melinera Smart XMAS LED string lights (@sonar98)
So this device will create 2 widgets, a color widget and a selector switch
There is some hidden options, to set them use the description for the last device and type for exemple
effectSpeed=7
effectColours=[[255,0,0],[0,255,0],[0,0,255]]
Last edited by Thorgal789 on Sunday 13 December 2020 10:35, edited 1 time in total.
Plantje
Post by Plantje »
Nice!
Will that new version also include forwarding a non RGBWWZ phoscon group as non RGBWWZ rather than the default RGBWWZ?
