iterate through a number of devices  [Solved]
MeAlbert
Domoticz version: 2020.1
Post by MeAlbert »
I have a number of device of which I want to push data to influx every minute.
I think I should use "domoticz.devices().forEach(function(device)"
But how do I get this function to perform for instance on device 3, 6 and 10?
devices = 3,6,10
Or domoticz.devices(3,6,10).forEach(function(device)
And do I understand it correctly that when I use the correct function the execute(dz,device) is not needed anymore?
To push to influx I want to use this code
	local function pushToInfluxdb(idx , nValue, rawData )
            local sValue = table.concat(rawData,';')
            local nValue = nValue or 0
            local url = dz.settings['Domoticz url'] ..  '/json.htm?type=command&param=udevice&idx=' .. idx  ..
                        '&nvalue=' .. nValue ..
                        '&svalue=' .. sValue
            dz.openURL(url)
            pushToInfluxdb( item.idx, 0, item.rawData )
            dz.log('Device ' .. item.name ..  item.rawData[1], dz.LOG_DEBUG)
Re: iterate over a number of devices
MeAlbert wrote: Thursday 12 November 2020 16:34 I have a number of device of which I want to push data to influx every minute.
forEach is one part but you need to filter first. See below script.
return
    on =
        timer =
            'every minute' ,
    logging =
        level = domoticz.LOG_ERROR, -- change to domoticz.LOG_DEBUG when not working as expected
        marker = 'forcePushToInfluxdb with filter Example',
    execute = function(dz)
        local myInfluxDevices =
            3,6,10,
        local function forcePushToInfluxdb(dv)
            dz.log('Forcing push to influxDb of ' .. dv.name, dz.LOG_FORCE)
            local url = dz.settings['Domoticz url'] ..  '/json.htm?type=command&param=udevice&idx=' .. dv.idx  ..
                    '&nvalue=' .. ( dv.nValue or 0  ) ..
                    '&svalue=' .. ( dv.sValue or '' )
            dz.openURL(url)
        dz.devices().filter(myInfluxDevices).forEach(function(dv)
        end)
No. In a dzVents script you always need the execute function. That function is called by the dzVents framework when one or more of the conditions in the on = section evaluate to true. The 2nd and 3rd parameters of the execute function are optional and not needed here.
MeAlbert
Re: iterate through a number of devices  [Solved]
Post by MeAlbert »
Thanks for the help.
Getting the devices through filtering I could not have come to that. But now the iteration process is clear to me.
Hope other people also benefit from it. It works like a charm.
