PLEX status (dzVents)  [SOLVED]
Number8
Domoticz version: 2022.1
Re: PLEX status (dzVents)
Post by Number8 »
I consider it as a failure of the RFC! I'm not responsible if a French word contains such a character ;)
First option is not possible since a placeholder is used in the app emitting the webhook.
So remains 2nd option that I will test. Thanks a lot for the tip.
Just FYI, the same remote app offers to send messages to a telegram bot and telegram displays correctly the single quote in the received message. You might consider not applying strictly the RFC.
Debian buster on NUC and three RPi with buster.
Number8
Post by Number8 »
I can't get it working because as soon as it enters the code, dzVents throw the error and code execution is stopped. It just have the time to log item.data and then the exception is thrown. As you see, item.data reports correctly the single quote
2020-06-06 11:42:50.286 Status: dzVents: Info: plex script: ------ Start external script: plex.lua: Custom event: "plex"
2020-06-06 11:42:50.286 Status: dzVents: Info: plex script: item data is: {"action": "resume", "titre": "L'Arnaque"}
2020-06-06 11:42:50.286 Status: dzVents: Info: plex script: ------ Finished plex.lua
2020-06-06 11:42:50.286 Error: dzVents: Error: (3.0.9) plex script: Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:1234: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:808: expected comma or '}' at byte 34 of: {"action": "resume", "titre": "L"Arnaque"}
Number8 wrote: Saturday 06 June 2020 11:48 I can't get it working because as soon as it enters the code, dzVents throw the error and code execution is stopped.
Can you show me the script as this should not happen and in fact in one of your previous posted log you already proved that the script will not abort when the JSON conversion fails. (it showed the dump)
Number8
Post by Number8 »
waaren wrote: Saturday 06 June 2020 12:00
Sure. Even if I comment everything starting at "if item.isCustomEvent then" the exception is thrown
	active = true, -- optional
		customEvents = {"plex"}
--	data = {
--		sid = { initial = "" }
	logging = {
		level = domoticz.LOG_INFO,
		marker = "plex script"
	execute = function(dz, item)
		local _u = dz.utils
		local _h = dz.helpers
		local _d = dz.data
		local _ = dz.utils._
			if item.trigger == "plex" then
				dz.log ("item data is: " .. item.data)
				if not(item.json) then
					dz.log ('JSON KO')
				  	local data  = dz.utils.fromJSON(item.data:gsub("@","\\u0027"))
					local data = item.json
				dz.log ("data after processing: " .. data)
Number8 wrote: Saturday 06 June 2020 12:33 I can't get it working because as soon as it enters the code, dzVents throw the error and code execution is stopped.
I left a wrong char in my code snippet. That was probably the reason you did not get the expected result.
If I send this curl
#curl -d '{"action": "resume", "titre": "L'\''Arnaque"}' "http://nuc:8084/json.htm?type=command&param=customevent&event=plex"
to this script
return
    on =
        customEvents =
            'plex'
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'plex script'
        if item.isCustomEvent and item.trigger == "plex" then
            dz.utils.dumpTable(item)
                dz.log('Extra conversion needed.....' ,dz.LOG_DEBUG)
                  item.json = dz.utils.fromJSON(item.data:gsub("'","\\u0027"))
                  item.isJON = item.json ~= nil
            dz.utils.dumpTable(item.json)
I get this in the log
2020-06-06 13:41:36.125  Status: dzVents: Info: plex script: ------ Start internal script: 20200606 dz customEvent single quote: Custom event: "plex"
2020-06-06 13:41:36.125  Error: dzVents: Error: (3.0.9) plex script: Error parsing json to LUA table: /opt/domoticz/scripts/dzVents/../lua/JSON.lua:1234: /opt/domoticz/scripts/dzVents/../lua/JSON.lua:808: expected comma or '}' at byte 34 of: {"action": "resume", "titre": "L"Arnaque"}
2020-06-06 13:41:36.125  Status: dzVents: > isVariable: false
2020-06-06 13:41:36.126  Status: dzVents: > isScene: false
2020-06-06 13:41:36.126  Status: dzVents: > isDevice: false
2020-06-06 13:41:36.126  Status: dzVents: > isXML: false
2020-06-06 13:41:36.126  Status: dzVents: > status: info
2020-06-06 13:41:36.126  Status: dzVents: > dump()
2020-06-06 13:41:36.126  Status: dzVents: > isTimer: false
2020-06-06 13:41:36.126  Status: dzVents: > isHTTPResponse: false
2020-06-06 13:41:36.126  Status: dzVents: > type: customEvent
2020-06-06 13:41:36.126  Status: dzVents: > isGroup: false
2020-06-06 13:41:36.126  Status: dzVents: > isSecurity: false
2020-06-06 13:41:36.126  Status: dzVents: > isSystem: false
2020-06-06 13:41:36.126  Status: dzVents: > isCustomEvent: true
2020-06-06 13:41:36.126  Status: dzVents: > customEvent: plex
2020-06-06 13:41:36.126  Status: dzVents: > isHardware: false
2020-06-06 13:41:36.126  Status: dzVents: > isJSON: false
2020-06-06 13:41:36.126  Status: dzVents: > data: {"action": "resume", "titre": "L'Arnaque"}
2020-06-06 13:41:36.126  Status: dzVents: > message:
2020-06-06 13:41:36.126  Status: dzVents: > trigger: plex
2020-06-06 13:41:36.126  Status: dzVents: Debug: plex script: Extra conversion needed.....
2020-06-06 13:41:36.126  Status: dzVents: > action: resume
2020-06-06 13:41:36.126  Status: dzVents: > titre: L'Arnaque
2020-06-06 13:41:36.127  Status: dzVents: Info: plex script: ------ Finished 20200606 dz customEvent single quote
Number8
Post by Number8 »
With this new code, the exception is still thrown just after the dump table instruction. Same exception even if all the code is commented. I copied/pasted your last code, a typo error has been corrected (item.isJSON = item.json ~= nil)
Here is the log.
2020-06-06 16:11:18.128 Status: dzVents: Info: plex script: ------ Start external script: plex.lua: Custom event: "plex"
2020-06-06 16:11:18.128 Status: dzVents: > isDevice: false
2020-06-06 16:11:18.128 Status: dzVents: > isSystem: false
2020-06-06 16:11:18.128 Status: dzVents: > isGroup: false
2020-06-06 16:11:18.128 Status: dzVents: > isCustomEvent: true
2020-06-06 16:11:18.128 Status: dzVents: > customEvent: plex
2020-06-06 16:11:18.128 Status: dzVents: > data: {"action": "pause", "titre": "L'Arnaque"}
2020-06-06 16:11:18.128 Status: dzVents: > dump()
2020-06-06 16:11:18.128 Status: dzVents: > trigger: plex
2020-06-06 16:11:18.128 Status: dzVents: > isHTTPResponse: false
2020-06-06 16:11:18.128 Status: dzVents: > status: info
2020-06-06 16:11:18.128 Status: dzVents: > message:
2020-06-06 16:11:18.128 Status: dzVents: > isScene: false
2020-06-06 16:11:18.128 Status: dzVents: > type: customEvent
2020-06-06 16:11:18.128 Status: dzVents: > isXML: false
2020-06-06 16:11:18.128 Status: dzVents: > isVariable: false
2020-06-06 16:11:18.128 Status: dzVents: > isSecurity: false
2020-06-06 16:11:18.128 Status: dzVents: > isTimer: false
2020-06-06 16:11:18.128 Status: dzVents: > isJSON: false
2020-06-06 16:11:18.128 Status: dzVents: > isHardware: false
2020-06-06 16:11:18.128 Status: dzVents: Debug: plex script: Extra conversion needed.....
2020-06-06 16:11:18.128 Status: dzVents: > action: pause
2020-06-06 16:11:18.128 Status: dzVents: > titre: L'Arnaque
2020-06-06 16:11:18.128 Status: dzVents: Info: plex script: ------ Finished plex.lua
2020-06-06 16:11:18.128 Error: dzVents: Error: (3.0.9) plex script: Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:1234: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:808: expected comma or '}' at byte 33 of: {"action": "pause", "titre": "L"Arnaque"}
Number8 wrote: Saturday 06 June 2020 16:22 With this new code, the exception is still thrown just after the dump table instruction. Same exception even if all the code is commented. I copied/pasted your last code, a typo error has been corrected (item.isJSON = item.json ~= nil)
The point that I wanted to emphasize with this example script is that the error message you see does not stop the execution of the script.
The error message is correct and expected because a JSON string with a single quote in it is invalid. But this does not stop the script.
What you see as a typo is in fact a valid Lua statement. item.isJSON will be set to true if item.json is unequal to nil.
Number8
Post by Number8 »
Go it
Go it as well. I was puzzled by this error and thought mistakenly that execution was stopped, which is indeed wrong. Thanks to your tip, it is working as expected.
Again, thanks a lot for the support of POST and your very kind support.
simon_rb
Post by simon_rb »
This is just what I’ve been looking for, I’ve just set it up and getting this error? Anything obvious that I’ve done wrong?
Thank you
 TTPResponse: " plex woonkamer release: v1.3: 20200306 getPlexInfo"
2020-11-11 18:24:01.597 Status: dzVents: Info: plex woonkamer release: v1.3: 20200306 : ------ Finished Plex.lua
2020-11-11 18:24:01.433 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_sqhomepod_volume.lua: ...pi/domoticz/scripts/lua/script_time_sqhomepod_volume.lua:10: attempt to index a nil value (global 'deviceinfo')
2020-11-11 18:24:01.596 Error: dzVents: Error: (3.0.16) plex woonkamer release: v1.3: 20200306 : HTTP/1.1 response: 404 ==>> Not Found
2020-11-11 18:24:01.596 Error: dzVents: Error: (3.0.16) plex woonkamer release: v1.3: 20200306 : Error parsing json to LUA table: (invalid json string) <!DOCTYPE html PUBLIC
2020-11-11 18:24:01.596 "-//W3C//DTD XHTML 1.0 Transitional//EN"
2020-11-11 18:24:01.596 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2020-11-11 18:24:01.596 <html>
2020-11-11 18:24:01.596 <head>
2020-11-11 18:24:01.596 <meta http-equiv="Content-Type" content="text/html; charset=utf-8"></meta>
2020-11-11 18:24:01.596 <title>404 Not Found</title>
2020-11-11 18:24:01.596 <style type="text/css">
2020-11-11 18:24:01.596 #powered_by {
2020-11-11 18:24:01.596 margin-top: 20px;
2020-11-11 18:24:01.596 border-top: 2px solid black;
2020-11-11 18:24:01.596 font-style: italic;
2020-11-11 18:24:01.596 }
2020-11-11 18:24:01.596 #traceback {
2020-11-11 18:24:01.596 color: red;
2020-11-11 18:24:01.596 </style>
2020-11-11 18:24:01.596 </head>
2020-11-11 18:24:01.596 <body>
2020-11-11 18:24:01.596 <h2>404 Not Found</h2>
2020-11-11 18:24:01.596 <p>The path '/v2' was not found.</p>
2020-11-11 18:24:01.596 <pre id="traceback"></pre>
2020-11-11 18:24:01.596 <div id="powered_by">
2020-11-11 18:24:01.596 <span>
2020-11-11 18:24:01.596 Powered by <a href="http://www.cherrypy.org">CherryPy unknown</a>
2020-11-11 18:24:01.596 </span>
2020-11-11 18:24:01.596 </div>
2020-11-11 18:24:01.596 </body>
2020-11-11 18:24:01.596 </html>
Number8
Post by Number8 »
What version of dzVents are you running?
simon_rb
Post by simon_rb »
Number8 wrote: Wednesday 11 November 2020 19:33 What version of dzVents are you running?
3.0.16
Number8
Post by Number8 »
Sorry version was in your last post. But what is your code. I share mine
-- Tautulli webhook will be triggered only if player is HTPC (Plex media player or Plex player) or Shield
-- See Webhooks setup in Tautulli
	logging = {
		local _u = dz.utils
		local _d = dz.data
		local Time = require('Time')
	 	local currentTime = Time()
--         dz.utils.dumpTable(item)
			dz.log("plex event")
			-- dz.log ("item data is: " .. item.data)
-- Single quote in a JSON string is not supported. This will NOT prevent the LUA exception.
--			dz.log (item.json.title,dz.LOG_DEBUG)
				if item.json.action == "resume" then
					dz.log ("resumed")
					dz.devices(258).switchOff().checkFirst()  -- switch off Oeuf
				elseif item.json.action == "play" then
					dz.log ("play")
					dz.devices(65).switchOff() -- switch off all lights
				elseif item.json.action == "stop" then
					dz.log ("stopped")
					if (currentTime.matchesRule("between 1 minutes after civiltwilightend and 1 minutes before civiltwilightstart")) then
						dz.devices(44).dimTo(50) -- switch on Lustre
						dz.devices(314).switchOn().checkFirst()  -- switch on lampadaire
					-- dz.devices(258).switchOn().checkFirst()  -- switch on Oeuf
				elseif item.json.action == "pause" then
					dz.log ("just paused")
					if (currentTime.matchesRule("between 1 minutes after sunset and 1 minutes before sunrise")) then
				elseif item.json.action == "endOfShow" then
					dz.log ("Temps restant : " .. item.json.remainingTime)
--					if (currentTime.matchesRule("between 1 minutes after civiltwilightend and 1 minutes before civiltwilightstart")) then
					if (currentTime.matchesRule("between civiltwilightend and civiltwilightstart")) then
			-- end
simon_rb
Post by simon_rb »
This is my Plex.lua file
 local scriptVersion = ' release: v1.3: 20200306 '
		local scriptVar = ' plex woonkamer ' .. scriptVersion
	--<[ 				      dzVents: Plex status 2 Domoticz   			    ]>--
		local tautulli_ip = '127.0.0.1:8181'	-- tautulli ip:port
		local tautulli_api = '92d29923e8be4757ab9ed9bf010112c5'	-- tautulli api key
		local plex_player	= 'Living Room' 		-- the plex player you want the status off
		local dz_plex_player 	= 1253				-- IDX number plex media player device
	return
			on = { 	customEvents 	= { 'plex_woonkamer',},		-- if you change the webhook URL make sure this match
				timer		= { 'every minute'  		-- this only runs when a movie is playing on selected player
	       		httpResponses 		= { scriptVar .. '*', },
			logging	 		= { level 	= domoticz.LOG_DEBUG,	-- set to LOG_ERROR when testen and ok.
						    marker 	= scriptVar,
			data 			= { plex	= { initial = {}, },
	execute = function(dz, item, triggerInfo)
		local jsonPlexInfo = {}
		local callback = scriptVar .. 'getPlexInfo'
		-- make sure timer only trigger script when pms is active
			dz.data.plex.active = 'true'
		if dz.data.plex.active == 'true' then
			if item.isCustomEvent or item.isTimerer then
		-- get plex information	trough tautulli api
			local function getPlexInfo( target, json, callback)
            local url = 'http://' .. target .. '/' .. json
            dz.openURL
               			url = url,
				method = 'GET',
				callback = callback,
		if item.isCustomEvent or item.isTimer then
		getPlexInfo( tautulli_ip, '/api/v2?apikey=' .. tautulli_api .. '&cmd=get_activity', callback )
			return
		 if item.isHTTPResponse then
		jsonPlexInfo = dz.utils.fromJSON(item.data)
            	if not(jsonPlexInfo) then return end
            		dz.log('Unexpected result from API ',dz.LOG_ERROR )
		dz.data.initialize('plex')
		-- find match in player name (api showing more players when more streams are active)
		for _, record in ipairs(jsonPlexInfo.response.data.sessions) do
			if record.player:match(plex_player) then
					dz.data.plex.active = ('true')
					dz.data.plex.state 	= (record.state)
					dz.data.plex.title	= (record.full_title)
					dz.data.plex.progress = (record.progress_percent)
		-- Change json output for updating device
		if dz.data.plex.state == 'playing' then player_state = 7
			elseif dz.data.plex.state == 'buffering' then player_state = 7
			elseif dz.data.plex.state == 'paused' then player_state = 2
		-- updating device
		dz.devices(dz_plex_player).update(player_state, dz.data.plex.title .. ' : ' .. dz.data.plex.progress .. ' %').silent()
		dz.devices(dz_plex_player).update(0, 'no media playing').silent()
DarkG
Domoticz version: 4.10076
Post by DarkG »
OedzesG wrote: Sunday 08 March 2020 22:36
Please share.
oke EdwinK... here we go..
The script uses the Tautulli api.. so first you need to install Tautulli..
https://github.com/Tautulli/Tautulli-Wiki/wiki/Installation
Once tautulli is instaled you can go to settings and navigate to Notification Agents and create a "webhook'
* webhook url :
http://<domoticzURL + port>/json.htm?type=command&param=customevent&event=plex_woonkamer
( you can change: woonkamer to something else, but then in the script you need to change the custom event in exactly the same name)
(becouse we use an customEvent, you need to be on dzVents: 3:0:0!!)
* Webhook Method: post
* description: what ever you want
on the page: Triggers select:
* Playback Start
* Playback Stop
* Playback Pause
* Playback Resume
On the page: Conditions:
* Parameter: Player
* Operator: is
* Value: (Here you have to search in Plex for youre plex player name (in my case: SHIELD Android TV)
Then save the webhook.
We also need the API Key from tautulli, you can find it: settings/Web Interface, scrol down en note the API. Also make sure API is enabled.
Now were done in Tautulli.
In Domoticz you have to create a dummy device... first switch and then change it to: media player in Domoticz UI.
The script whit some final instructions.
		local tautulli_ip = 'xxx'	-- tautulli ip:port
		local tautulli_api = 'xx'	-- tautulli api key
		local plex_player	= 'SHIELD Android TV' 		-- the plex player you want the status off
		local dz_plex_player 	= 26				-- IDX number plex media player device
	return
						    marker 	= scriptVar,
            dz.openURL
               			url = url,
				method = 'GET',
			return
		-- updating device
There is a syntax error at get plex info. one slash too much before api. must be
getPlexInfo( tautulli_ip, 'api/v2?apikey=' .. tautulli_api .. '&cmd=get_activity', callback )
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
simon_rb
Post by simon_rb »
DarkG wrote: Thursday 12 November 2020 0:32 There is a syntax error at get plex info. one slash too much before api. must be
Thank you! Also noticed a space with my api key. All working now
Thanks again!
simon_rb
Post by simon_rb »
Has anyone managed to get the newly created Plex Switch to control lights when state changes between Playing and Paused? I’ve tried LUA and blocky and the scripts run fine but the light switches don’t change.
OedzesG
Post by OedzesG »
    local mediaPlayerStates =
    		Off = 0,
    		On = 1,
    		Paused = 2,
    		Stopped = 3,
    		Video = 4,
    		Audio = 5,
    		Photo = 6,
    		Playing = 7,
    		Disconnected = 8,
    		Sleeping = 9,
    		Unknown = 10,
Sarcas
Domoticz version: 2022.1ß
Post by Sarcas »
Finally got it working, but not until I changed
to
if record.player == plex_player then
I'm glad it works, but can't stand not knowing what is wrong. Does anyone know?
My player:
local plex_player	= 'LG OLED55E7N-Z'
Thx!
Domoticz on rPi4 - RFXCOM RFXtrx433 USB - ZW090 Z-Stick Gen5 EU - IKEA Tradfri - Philips HUE - YouLess meter - SolarEdge
