Raspberry with Bleutooth and eq-3 radiator thermostat
har0543
Domoticz version: 2022.2
Post by har0543 »
I would like to use a remote controlled radiator thermostat in my Domoticz Raspberry setup.
I found this:
http://www.eq-3.de/produkte/eqiva/bluet ... ostat.html
Is it an option to use it and if yes how. If no is there an other option?
Kind regrads.
Har
blackdog65
Re: Raspberry with Bleutooth and eq-3 radiator thermostat
Post by blackdog65 »
Not sure about the BT version but we have the wireless version pretty much cracked now. :D
See viewtopic.php?f=34&t=841
and https://www.domoticz.com/wiki/EQ3_MAX!
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
inzuno
Domoticz version: stable
Post by inzuno »
I found this: https://github.com/Heckie75/eQ-3-radiator-thermostat
I managed to pair with the bluetoothctl command :
pi@DomoticzRPi:~/eq3 $ bluetoothctl
[NEW] Controller 00:1A:7D:DA:71:11 DomoticzRPi [default]
[NEW] Device 00:1A:22:06:4B:9A CC-RT-BLE
[bluetooth]# connect 00:1A:22:06:4B:9A
Attempting to connect to 00:1A:22:06:4B:9A
Connection successful
[CHG] Device 00:1A:22:06:4B:9A Connected: no
[CHG] Device 00:1A:22:06:4B:9A Connected: yes
[bluetooth]# info 00:1A:22:06:4B:9A
        Alias: CC-RT-BLE
        Paired: yes
        Trusted: no
        Blocked: no
        Connected: yes
        LegacyPairing: no
        UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
        UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
        UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
        UUID: Vendor specific           (3e135142-654f-9090-134a-a6ff5bb77046)
        UUID: Vendor specific           (9e5d1e47-5c13-43a0-8635-82ad38a1386f)
But I cant't use the Heckie75's script...
pi@DomoticzRPi:~/eq3 $ ./eq3.exp 00:1A:22:06:4B:9A sync
Connection failed.
I'm on a Pi2 with jessie and a CSR4.0 bluetooth adapter.
I've seen it's possible to control this with Json, so you can add this to domoticz quite easily.
If anyone could help me...
"I never make the same mistake twice. I make it like five or six times, you know, just to be sure."
Prutsium
Post by Prutsium »
Dont connect but use PAIR first and put the EQ3 in Pairing mode (Long hold button/dial)
Got the same setup running here and works great (Now only looking to extend the range of BT from my Pi)
inzuno
Post by inzuno »
Thanks for the help but it is already paired, I did it just before connect...
What else am I doing wrong? Is it because I use BT adapter?
Prutsium
Post by Prutsium »
How did you pair? i used: bluetoothctl
inzuno
Post by inzuno »
Yes bluetoothctl and then pair 00:1A:22:06:4B:9A
It's in the paired devices:
[bluetooth]# paired-devices
inzuno
Post by inzuno »
I figured it out!
After pairing the device was autoconnected. But apparently it needed to be disconnected before using script...
[bluetooth]# disconnect 00:1A:22:06:4B:9A
Attempting to disconnect from 00:1A:22:06:4B:9A
Successful disconnected
[bluetooth]# quit
[DEL] Controller 00:1A:7D:DA:71:11 DomoticzRPi [default]
Temperature:                    9.5°C
Valve:                          0%
Mode:                           manual locked dst
Vacation mode:                  off
So now it's working, how can I put it in domoticz? :roll:
Edit:
I also found this script: https://github.com/mpex/EQ3-Thermostat
But I don't know how to use it...
arnoudjan
Post by arnoudjan »
Hi, any luck with the connection to Domoticz?
With the help of this post I managed to control the radiator thermostate with the raspberry, but how to add this to domotics, I don't know.
So did you manage to solve it?
inzuno
Post by inzuno »
I made a specific topic here: viewtopic.php?f=34&t=25544&p=196355#p196355
Have fun!
