Sonoff Zigbee Bridge?
doh
Post by doh »
Has anyone managed to get the Sonoff Zigbee Bridge working with Domoticz at all (or via NodeRED, etc)?
I've got one and re-flashed it with the tasmota-zbbridge firmware and that's all working, but I really don't fancy trying to code everything in NodeRED to read and update the devices.
I've looked at the Domoticz plugin for sonoff tasmota and that doesn't look like it will do the job as it seems to assume that the sonoff device just has one or two switches, whereas the bridge presents many devices, which also means the tasmota built-in domoticz integrations won't work either.
Thoughts?
Kruu
Re: Sonoff Zigbee Bridge?
Post by Kruu »
Did anyone managed to get it working without reflashing it?
JRRDomoticz
Post by JRRDomoticz »
Good afternoon:
Have you somehow managed it without NODORed?
With a Snifer MQTT I see the plot:
tele/zigbeeBrigge/SENSOR = {"ZbReceived":{"0x09CC":{"Device":"0x09CC","Temperature":22.75,"Humidity":81.97,"Endpoint":1,"LinkQuality":47}}}
tele/zigbeeBridge/SENSOR = {"ZbReceived":{"0x6DB4":{"Device":"0x6DB4","Temperature":22.75,"Humidity":81.97,"Endpoint":1,"LinkQuality":47}}}
I've seen in another thread that you can create a rule in Tasmota console, but it doesn't do anything ...
Rule1 ON ZbReceived#0x6DB4#Occupancy=1 DO publish domoticz/in {"idx":23, "nvalue":1} ENDON
Rule1 1
Rule2 ON ZbReceived#0x09CC#Occupancy=1 DO publish domoticz/in {"idx":24, "nvalue":1} ENDON
Rulle2 1
Thanks in advance
JRRDomoticz
JRRDomoticz wrote: Sunday 08 November 2020 19:19 Good afternoon:
Rule1 1
Rulle2 1
Thanks in advance
Solved:
Tasmota(Zigbee Bridge) To Domoticz
ZbName (SetOption83 0)
Rule1 ON ZbReceived#0x6DB4#Temperature DO var1 %value% ENDON ON ZbReceived#0x6DB4#Humidity DO publish domoticz/in {"idx":24,"svalue":"%var1%;%value%;1"} ENDON
Rule2 ON ZbReceived#0x09CC#Temperature DO var2 %value% ENDON ON ZbReceived#0x09CC#Humidity DO publish domoticz/in {"idx":23,"svalue":"%var2%;%value%;1"} ENDON
kabal
Post by kabal »
I have tried the same with no luck.
That is my ZIGbee Xiaomi Aquara temp sensor:
zigbee2mqtt/SENSOR = {"ZbReceived":{"0x021A":{"Device":"0x021A","Name":"Temp_Salon","Temperature":21.99,"Humidity":43.48,"Pressure":1003,"PressureScale":-1,"PressureScaledValue":10032,"SeaPressure":1003,"Endpoint":1,"LinkQuality":181}}}
10:00:48 ZIG: ZbZCLRawReceived: {"0x021A":{"0403/0000":1003,"0403/0014":-1,"0403/0010":10032,"Endpoint":1,"LinkQuality":181}}
On Sonoff ZbBridge cmd ->
Rule1 ON ZbReceived#0x021A#Temperature DO var1 %value% ENDON ON ZbReceived#0x021A#Humidity DO publish domoticz/in {"idx":63,"svalue":"%var1%;%value%;1"} ENDON
*idx 63 is my Domoticz temp&hum sensor.
When i check mosquitto_sub -h localhost -v -t domoticz/in I don't have any message from zigbee bridge and I don't have any message in tasmota console for zbrige neither.
But if I run the mosquitto_sub -h localhost -v -t zigbee2mqtt/SENSOR on Raspberry I can see the message without any problem.
So the problem is as if RULE 1 doesnt convert the message from 0x021A device to domoticz/in.
kabal
Post by kabal »
Problem solved! I did not see that Rule1 = OFF so at the end of line I have added "Rule1 1"
Rule1 ON ZbReceived#0x021A#Temperature DO var1 %value% ENDON ON ZbReceived#0x021A#Humidity DO publish domoticz/in {"idx":63,"svalue":"%var1%;%value%;1"} ENDON Rule1 1
HarleyK
Post by HarleyK »
Ok, i solved problem for myself:
If got Mijia Light Sensor ZigBee 3.0 + SONOFF ZBBridge (Tasmota)
Console gives me:
11:35:25.492 MQT: tele/ZbBridge/SENSOR = {"ZbReceived":{"0xC5F2":{"Device":"0xC5F2","Name":"Illumination_sensor","Illuminance":29996,"Endpoint":1,"LinkQuality":123}}}
I write this rule:
Rule1 ON ZbReceived#0xC5F2#Illuminance DO publish domoticz/in {"idx":69,"nvalue":0,"svalue":"%value%"} ENDON
Rule1 1
Console answers:
RUL: ZBRECEIVED#0XC5F2#ILLUMINANCE performs "publish domoticz/in {"idx":69,"nvalue":0,"svalue":"29996"}"
MQT: domoticz/in = {"idx":69,"nvalue":0,"svalue":"29996"}
Domoticz log shows:
MQTT: Topic: domoticz/in, Message: {"idx":69,"nvalue":0,"svalue":"29996"}
Later i'll try this for Temperature/Humidity sensor
pedemo
Domoticz version: V 2020.2
Post by pedemo »
HarleyK thanks for this info I finally got my Miija Light Sensor working.
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
my console show this:
tele/ZbBridge/SENSOR = {"ZbReceived":{"0x7EFB":{"Device":"0x7EFB","Temperature":23.66,"Endpoint":1,"LinkQuality":40}}}
tele/ZbBridge/SENSOR = {"ZbReceived":{"0x7EFB":{"Device":"0x7EFB","Humidity":95.82,"Endpoint":1,"LinkQuality":40}}}
it's about a SNZB-02 SONOFF TEMP/HUM senzor.
i'm not able to make the rule.
cand somebody help me?
i use this :
Rule1 ON ZbReceived#0x7EFB#Occupancy=1 DO publish domoticz/in {"idx":98, "nvalue":1} ENDON
Rule1 1
but no succes.
