I have domoticz, latest stable, and just acquired a nodo-shop opentherm gateway with LAN interface.
All works as expected. I can send commands through the hárdware menu and have 28 devices
Is it possible to programmatically send commands like SW=65 to the gateway with lan interface?
like for example im dzvents, lua, http or other?
Send opentherm gateway command
- Domoticz version: 2022.1
Version 3.9639
Platform: Jessie lite
Hardware: Raspberry pi 3B; RFXCOM; Weather Underground; Dummy; OpenZwave USB; Fritzbox Callmonitor via LAN interface; System Alive Checker (Ping); Philips Hue Bridge; Atag One Thermostat
Re: Send opentherm gateway command
Hello Ries,...check out this using a virtual sensor and a selector switch. This works....
https://domoticz.com/forum/viewtopic.php?f=26&t=34506
____________________________________________________________________
Raspberry PI 3 Model B with USB stick, Domoticz Stable, OTGW LAN with ESP wifi-bridge and Isense Thermostat using the Outside Temp from Buienradar via Domoticz, Milight Ibox-2(V6)
