I just would like to know if the following 3 IDs (Ampere per phase) being part of P1 Smart Meter could be integrated within Domoticz as per the following post: viewtopic.php?f=14&t=34255
1-0:31.7.0(003.58*A)
1-0:51.7.0(004.85*A)
1-0:71.7.0(003.93*A)
Ideally, Ampere for each phase could be integrated as separated graphs and also within a single graph.
3-phase Ampere devices P1 Smart Meter
- FireWizard
Re: 3-phase Ampere devices P1 Smart Meter
@giton,
Obviously the current in Belgium is presented with 2 digits after the decimal point, since some time.
However this is not compliant with the DSMR 5.0.2 specification. See: https://www.netbeheernederland.nl/_uplo ... fce1f1.pdf. On page 21 of 28 you will find:
So it is still in A resolution.
As far as I know, the specification is still valid and not succeeded by a newer version. Also a check of my P1 Smart Meter, did not indicate otherwise.Instantaneous current L1 in A resolution
giton
@FireWizard
When looking here below on page 9 and 10 (https://energieverbrauchimblick.be/rail ... attachment)
--> 'Note 4' related to 1-0:31.7.0*255, 1-0:51.7.0*255 & 1-0:71.7.0*255 states this:
Note 4: In deviation to the DSMR P1, the resolution for the instantaneous currents (1‐0:x1.7.0*255 with x
=3, 5, 7) is improved from F3(0,0) to F5 (2,2)
Meaning that 2 digits are available. Honestly, I don't know who is managing this standard but I clearly have those information available with my T211 3-phase device and would have it integrated as devices in Domoticz when adding my HW:
pi@raspberrypi:/home/giton $ cat /dev/ttyUSB0
/FLU5\253769484_A
0-0:96.1.4(50214)
0-0:96.1.1(3153414733313030303733363338)
0-0:1.0.0(201103121009W)
1-0:1.8.1(000760.864*kWh)
1-0:1.8.2(001065.055*kWh)
1-0:2.8.1(001036.195*kWh)
1-0:2.8.2(000380.702*kWh)
0-0:96.14.0(0001)
1-0:1.7.0(00.000*kW)
1-0:2.7.0(00.906*kW)
1-0:32.7.0(233.9*V)
1-0:52.7.0(232.8*V)
1-0:72.7.0(232.4*V)
1-0:31.7.0(000.98*A)
1-0:51.7.0(002.53*A)
1-0:71.7.0(002.45*A)
0-0:96.3.10(1)
0-0:17.0.0(999.9*kW)
1-0:31.4.0(999*A)
0-0:96.13.0()
!1A98
/FLU5\253769484_A
0-0:96.1.4(50214)
0-0:96.14.0(0001)
1-0:32.7.0(233.9*V)
1-0:52.7.0(232.8*V)
1-0:72.7.0(232.4*V)
0-0:96.3.10(1)
1-0:31.4.0(999*A)
0-0:96.13.0()
!1A98
- FireWizard
Hi @giton,
Thanks for the information and the document.
As this is not implemented in NL, it is only valid in B.
So perhaps a PR?
So perhaps a PR?
giton
An issue has been opened in GitHub to cover this enhancement: https://github.com/domoticz/domoticz/issues/4433
