changing hardwaretype
eddieb
Post by eddieb »
I want to relocate my RPI with domoticz closer to my p1meter.
I am running p1meter over a network relay now thru "P1 Smart Meter with LAN interface" which is type 5 in the domoticz.db.
I want to change it to "P1 Smart Meter USB" to connect the usb cable directly to my RPI.
Can I change the type in domoticz or do I need to change the record in the database ?
Where can I find the hardwaretype id for "P1 Smart Meter USB" ?
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Re: changing hardwaretype
eddieb wrote: Thursday 05 November 2020 11:16 Can I change the type in domoticz or do I need to change the record in the database ?
Don't know where to find it but it is 4.
As far as I know there is no defined process for changing a hardware type of devices so you will have to experiment (after ensuring you have a working and tested backup)
eddieb
Post by eddieb »
waaren wrote: Thursday 05 November 2020 13:32
tnx @waaren, I'll just try it, create an aextra backup of the DB and than change the type ... plug the usb cable over and see what happens, I will let you know ;-)
eddieb
Post by eddieb »
It worked ...
- made extra backup of the .db
- moved p1 usb cable to domoticz rpi
- changed the hardware type in domoticz
changed the speed to 115200
- rebooted
no history lost ;-)
