morning routine not working [not authorised]  [Solved]
Ultimato
Post by Ultimato »
I have a timer script to turn on some lights when I need to leave early for work.
Yesterday the script ran without any issue but this morning I got errors.
I just tested again and got these error:
2020-11-04 21:30:00.206 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=com ... %3A29%3A00
2020-11-04 21:30:00.284 Error: dzVents: Error: (3.0.16) HTTP/1.1 response: 401 ==>> Unauthorized
2020-11-04 21:30:00.300 Error: dzVents: Error: (3.0.16) An error occurred when calling event handler Wekker
2020-11-04 21:30:00.300 Error: dzVents: Error: (3.0.16) ...pi/domoticz/scripts/dzVents/generated_scripts/Wekker.lua:42: attempt to call a nil value (field 'aftermin')
The script is below.
Does anyone have a clue what I'm doing wrong?
-- Alarm clock [ dzVents >= 2.4 ]
scriptVar = '20191030 Alarmclock'
return
{ active = true,
    on =
        timer = { 'every minute' },    -- hourly run once to pick up target time
        httpResponses = { scriptVar }, -- Trigger the handle Json part
--    logging = { level = domoticz.LOG_DEBUG },
    execute = function(dz, item)
        local alarmTime = dz.devices('Wekker').levelName
        if alarmTime ~= 'Off' then
            local minutesIn24Hours = 24 * 60
            local now = dz.time                             -- Get current time into time object
            local Time = require('Time')
            local targetTime = Time(dz.time.rawDate .. ' '  .. alarmTime .. ':00') -- Create target time object
            local function triggerAlarm(delay)
               local message = 'alarmclock ringing now. Was set on '.. dz.time.rawDate .. ', at ' .. dz.time.rawTime
                local url = dz.settings['Domoticz url'] .. "/json.htm?type=command&param=addlogmessage&message=" .. dz.utils.urlEncode(message)
                dz.openURL({ url = url, callback = scriptVar }).afterMin(math.floor(delay))
            if not(item.isHTTPResponse) then
                dz.log('Alarm time is set at : ' .. alarmTime)
                local deltaMinutes = math.floor(now.compare(targetTime).minutes)
                if now.compare(targetTime).compare < 1 then -- targetTime is in future
                    deltaMinutes = minutesIn24Hours - deltaMinutes
                dz.log('Alarmactions will be triggered in ' .. deltaMinutes .. ' minutes' ,dz.LOG_DEBUG)
                triggerAlarm(deltaMinutes)
                -- do wakeup actions.. here
                dz.log('wake up actions here....'  ,dz.LOG_DEBUG)
                dz.devices('Schuurverlichting 1').switchOn().aftermin(10)
                dz.devices('Schuurverlichting 1').switchOff().afterMin(25)
                dz.devices('Buitenlamp').switchOn().aftermin(10)
                dz.devices('Buitenlamp').switchOff().afterMin(30)
                dz.notify('Wekker','Over 10 minuten moet je weg!', dz.PRIORITY_LOW, dz.SOUND_DEFAULT,nil, dz.NSS_TELEGRAM)
I'm Running domoticz beta on a Rpi 4
Re: morning routine not working [not authorised]  [Solved]
Ultimato wrote: Wednesday 04 November 2020 21:36 I have a timer script to turn on some lights when I need to leave early for work.
There are two separate errors you get here.
The first one is that you have not set 127.0.0.1 to not need a password as described in the wiki
The second one are the aftermin() options. These are case sensitive so you must use afterMin()
