Door sensor connect to GPIO
runy
Post by runy »
Hi mates,
I would like to connect a sensor door like this (https://es.aliexpress.com/item/32255861 ... 63c0iBdn8C) to my raspberry's GPIO.
Using SYSFS option I set the port with the following steps:
sudo echo 18 > /sys/class/gpio/export
sudo echo in > /sys/class/gpio/gpio18/direction
sudo echo 1 > /sys/class/gpio/gpio18/active_low
but when I try to check the status with
cat /sys/class/gpio/gpio18/value
the value is always 0
What am i forgetting?
runy
Re: Door sensor connect to GPIO (SOLVED)
Post by runy »
I have changed the GPIO for the GPIO4 a now it's working well.
