Countdown timer Topic is solved
Patricen
Domoticz version: Beta rel
Countdown timer
Post by Patricen »
Is there a way using a dummy device to make a countdown timer that I can set the duration with GUI ?
The idea would be to be able setting the heating setpoints to 16° while I'm out for a weekend for example (1 day, 2 days, 1 week) and change the timerplan back to comfort mode.
Any idea is warmly welcome!
Patrice
Re: Countdown timer
Patricen wrote: Monday 02 November 2020 22:27 Is there a way using a dummy device to make a countdown timer that I can set the duration with GUI ?
The method to set an Alarm time as posted here could be modified without much effort to create such a countdown.
Patricen
Re: Countdown timer
Post by Patricen »
Thanks a lot waaren,
I'll try this, it could be interesting having this kind of object native in Domoticz!
Patrice
Re: Countdown timer
Patricen wrote: Tuesday 03 November 2020 6:58 Thanks a lot waaren,
Patrice
Can you try this proof of concept?
            dzvents script to use a selector type switch to set and start a countdown
            selector levels must be set and named to:
            0    Off
            10   add 1 week
            20   add 3 days
            30   add 1 day
            40   add 4 hours
            50   add 1 hour
            60   add 10 minutes
            70   add 1 minute
            80   reset to now
            90   start Countdown
            100  set idle
            110  Choose
            Off level must be set to "hided" and for lay-out purposes best to set Selector Style to "select Menu"
            The name of the selector switch should initially be set to: "Countdown"
            History:
            20201102 Start coding
            20201103 first proof of concept
            todo:
            -- Allow multiple Countdown selectors
local scriptVar = 'Countdown'
return
    on =
        devices =
             700,  -- id of your selector type switch with initial name "Countdown"
        system =
            'start', -- Needed in case domoticz was restarted (the customEvent need to be emitted again)
        customEvents =
            scriptVar, -- This will come back once the countdown "reaches zero"
    logging =
        level = domoticz.LOG_DEBUG, -- set to domotiocz.LOG_ERROR when all OK
        marker =  scriptVar,
    data =
        countdown =
            initial = 0,
    execute = function(dz, item)
        local datePattern = '(%d%d%d%d)-(%d%d)-(%d%d)%s(%d+):(%d%d+)' -- this will catch "yyyy-mm-dd hh:mm"
        local minutesTable =
           ["add 1 week"] = 10080,
           ["add 3 days"] = 4320,
           ["add 1 day"] = 1440,
           ["add 4 hours"] = 240,
           ["add 1 hour"] = 60,
           ["add 10 minutes"] = 10,
           ["add 1 minute"] = 1,
           ["reset to now"] = 0,
           ["start Countdown"] = 0,
           ["set idle"] = 0,
           ["Choose"] = 0,
        local function date2Timestamp(str)-- Assuming a date pattern like: yyyy-mm-dd hh:mm
            dz.log(str)
            local year, month, day, hour, minute = str:match(datePattern)
            return os.time({year = year, month = month, day = day, hour = hour, min = minute})
        local function timeStamp2dateString(timestamp)
            return os.date('%Y-%m-%d %H:%M',( timestamp or os.time() ) )
        local function resetLevel()
            if item.isDevice then
                item.switchSelector('Choose').afterSec(1).silent() -- force display of new name
        local function closeEnough()
            return os.time() > dz.data.countdown - 5 and os.time() < dz.data.countdown + 5
        local function emitCountdown()
            if dz.data.countdown > os.time() then
                dz.emitEvent(scriptVar).afterSec(dz.data.countdown - os.time())
                dz.log('Countdown set for ' .. ( dz.data.countdown - os.time() ) .. ' seconds.' .. '('.. timeStamp2dateString(dz.data.countdown) ..')', dz.LOG_DEBUG)
                dz.log('Countdown target is not in the future', dz.LOG_DEBUG)
            resetLevel()
        local function setName(timestamp)
            dz.data.countdown = 0
            if item.levelName == 'reset to now'  then
                item.rename('Countdown: ' .. timeStamp2dateString())
            elseif item.levelName == 'set idle'  then
                item.rename('Countdown off')
                item.rename('Countdown: ' .. timeStamp2dateString(timestamp))
                dz.data.countdown = timestamp
            resetLevel()
        -- main code
        if item.isDevice and item.levelName == 'set idle' then
            setName(0)
        elseif item.isDevice and item.levelName == 'start Countdown' then
            emitCountdown()
        elseif item.isDevice and item.levelName ~='Choose' then
            -- get Multiplier
            local multiplier = minutesTable[item.levelName] or 0
            -- current timestamp
            local currentTimestamp = os.time()
            local startStr, endStr = item.name:find(datePattern)
            if startStr then
                currentTimestamp = date2Timestamp(item.name:sub(startStr, endStr))
                if currentTimestamp < os.time() then currentTimestamp = os.time() end
            local newTimestamp = currentTimestamp + multiplier * 60
            setName(newTimestamp)
        elseif item.isCustomEvent then
            if closeEnough() then
                dz.log('Put your required actions for countdown ended here', dz.LOG_DEBUG)
                dz.log('This is not the customEvent we are looking for', dz.LOG_DEBUG)
        elseif item.isSystemEvent and dz.data.countdown ~= 0 then
                dz.log('domoticz was restarted ==>> rescheduling the countdown', dz.LOG_DEBUG)
                emitCountdown()
                dz.log('Countdown time already passed. Check if rescheduling is needed', dz.LOG_FORCE)
Patricen
Re: Countdown timer
Post by Patricen »
Tried, Working pretty well!
