Windows Compiling
Lubovic59
Domoticz version: 2022.1
Windows Compiling
Post by Lubovic59 »
To work nice with aeotec zwa021, I want to try to modify the openzwave that is bundled with the domoticz installation windows.
So I installed Visual Studio 2019, all the dependencies etc, but I have a problem with the includes in some files :
Severity Code Description Project File Line Suppression State
Error (active) E1696 cannot open source file "mosquitto.h" domoticz C:\Users\Ludovic\source\repos\domoticz\main\mosquitto_helper.h 10
Error (active) E1696 cannot open source file "minizip/unzip.h" domoticz C:\Users\Ludovic\source\repos\domoticz\webserver\request_handler.hpp 17
Error (active) E1696 cannot open source file "iowin32.h" domoticz C:\Users\Ludovic\source\repos\domoticz\webserver\request_handler.hpp 19
I installed boost and some other package using vcpkg.
Can you help me in compiling this please ?
Dnpwwo
Re: Windows Compiling
Post by Dnpwwo »
@Lubovic59,
You need to follow these instructions: https://www.domoticz.com/wiki/Windows#Compiling and use the libraries and includes from https://github.com/domoticz/win32-libra ... braries.7z
Lubovic59
Post by Lubovic59 »
Dnpwwo wrote: Saturday 31 October 2020 2:11 @Lubovic59,
Hi Dnpwwo and thanks for your answer,
That's exactly that I did, and Visual Studo was missing a lot of package with this method ( boost, json, cereal etc . )
So I installed some package but the error message that I showed in my first page are still here.
Dnpwwo
Post by Dnpwwo »
Personally I had to add some additional include directories under C/C++ General but I wasn't sure if that was just an issue for me.
  • ./Windows Libraries/Boost
  • ./Windows Libraries/openssl
  • ./Windows Libraries/Curl
  • ./Windows Libraries/pthread
Lubovic59
Post by Lubovic59 »
Dnpwwo wrote: Monday 02 November 2020 1:31 Personally I had to add some additional include directories under C/C++ General but I wasn't sure if that was just an issue for me.
Okay it's clear now.
I installed all the missing package one by one, and it's working.
I'm sorry but I thought it was problematic because in the windows compiling tutorial they never said to install addtionnnal package.
Now if I want to update my version of domoticz with my modification, I just need to copy the new domoticz.exe into my domoticz folder ?
Thanks,
Dnpwwo
Post by Dnpwwo »
You can to that but then you won't be able to debug it.
In the Debugging Properties I just set the Working Directory to '..' then you can run/debug it from within Visual Studio itself. Not sure what other do.
Maybe you should update the Wiki with the process you used?
Lubovic59
Post by Lubovic59 »
Cool I will try to update the wiki !
Oh and I have another problem :( since I installed my own compiled version of Domoticz, it dosent recognise python on my windows computer...
Everything worked fine with the official exe.
2020-11-02 22:53:31.400 Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
However python is still here :
>python --version
Python 3.8.6
and it's a x86 version. Is there something I'm missing ?
EDIT : I was using the debug version. So it was searching for the debug python. Swhitched to realese fixed the problem.
Dnpwwo
Post by Dnpwwo »
If you want to run the debug version you can put the 'python3x_d.dll' (and optionally, the associated .pdb file) in the folder where your domoticz.exe is built
