Is it possible to read data from log into a script
abdolhamednik
Domoticz version: 4.9700
Post by abdolhamednik »
Hello everyone ;)
Imagine when a sensor is out of order and you want to use its data from past days right at this time...
Is it possible to read data from log into a lua script? :?: :!:
i.e. log of 'sensors/switches'
Re: Is it possible to read data from log into a script
abdolhamednik wrote: Wednesday 28 October 2020 13:30 Is it possible to read data from log into a lua script? :?: :!:
Yes, that is possible with both classic Lua (via an OS curl) command and with dzVents openURL().
In both methods you call one of these API entries
abdolhamednik
very nice :P
thank u waaren
but now 2 questions:
1.how to fetch data for an exact time? it is not mentioned here the exact time:
/json.htm?type=graph&sensor=temp&idx=IDX&range=day
it only gave me last 6 5-min data, like this:
   "result" : [
         "d" : "2020-10-29 09:50",
         "te" : 23.0
         "d" : "2020-10-29 09:55",
         "te" : 23.0
         "d" : "2020-10-29 10:00",
         "te" : 23.0
         "d" : "2020-10-29 10:05",
         "te" : 23.0
         "d" : "2020-10-29 10:10",
         "te" : 23.0
         "d" : "2020-10-29 10:15",
         "te" : 23.0
   "status" : "OK",
   "title" : "Graph temp day"
and
2.how to use it in lua? for example if i want temp of 2020-10-27 10:00
abdolhamednik wrote: Thursday 29 October 2020 7:52 1.how to fetch data for an exact time?
You cannot get the individual datapoints from the API. You collect all and select what's needed in your script .
2.how to use it in Lua? for example if i want temp of 2020-10-27 10:00
Fot the 5 minute granularity you can only go back for a limited number of days (as set in [Log History] Short Log Sensors number of days:)
For day values you can go back to when you started to collect the data.
Most code needed in Lua to do this, is already part of dzVents (100 % Lua) and I don't think it makes sense to redo this work. So If dzVents is ok for you I can get you an example.
abdolhamednik
that's very good. i would be thankful
abdolhamednik wrote: Thursday 29 October 2020 9:10
Example data retrieval (temperature sensor) from short- and long log
-- getDataPoints
local scriptVar = 'getDataPoints'
return
    on =
        timer =
            'at 7:30'  -- Your preferred time
        devices =
            scriptVar, -- just for test can be ignored
        httpResponses =
            scriptVar .. '*',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        -- ****************************** Your settings below this line ***************************************************
        local sensorIDX = 3 -- device id of a temperature sensor
        -- ****************************** No changes required below this line *********************************************
        local function getData(id, range, delay)
            local range = range or 'year'
            local actYear = ''
            if range == 'year' then
                actYear = dz.time.year
            local URLString = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=temp&range=' .. range .. '&idx=' .. id .. '&actyear=' .. actYear
            dz.openURL(
                url = URLString,
                callback = scriptVar .. '_' .. range
            }).afterSec(delay or 0)
        -- Main
        if item.isTimer or item.isDevice then
            getData(sensorIDX)
            getData(sensorIDX, 'day')
        elseif item.isJSON and #item.json.result > 0 then -- statusCode = OK and JSON contains enough records
            history = item.json.result
            if item.trigger:find('day') then -- short log history
                dz.log('First record in short log: ' .. history[1].d .. '; temperature: ' .. history[1].te, dz.LOG_FORCE )
                dz.log('Last record in short log: ' .. history[#history].d .. '; temperature: ' .. history[#history].te, dz.LOG_FORCE )
                dz.log('Number of records in short log: ' .. #history, dz.LOG_FORCE )
                lastYearHistory = item.json.resultprev
                dz.log('first record in return: ' .. lastYearHistory[1].d .. '; temperatures: ' .. lastYearHistory[1].te .. ' ((high), '  .. lastYearHistory[1].tm .. ' (low), ' .. lastYearHistory[1].ta .. ' (average)', dz.LOG_FORCE )
                dz.log('last record in return: ' .. history[#history].d .. '; temperatures: ' .. history[#history].te .. ' ((high), '  .. history[#history].tm .. ' ((low), ' .. history[#history].ta .. ' (average)', dz.LOG_FORCE )
                dz.log('number of records in return: ' .. (#history + #lastYearHistory), dz.LOG_FORCE )
               -- dz.utils.dumpTable(history)
            dz.log('Could not get (good) data from domoticz!' ,dz.LOG_ERROR)
            dz.log(item,dz.LOG_DEBUG)
