[Solved] Difficulties with Curl in a script  [Solved]
Diplo95
Domoticz version: 2021.1
Post by Diplo95 »
I try to send a curl message to change a parameter to a device Xiaomi via a Conbee 2.
I've found the correct command :
curl -H 'Content-Type: application/json' -X PUT -d '{"duration": 500}' http://192.168.1.1:80/api/A********/sensors/20/config
I know it's ok because I tested it on a command line directly on my Pi
So I tired to integrate it in a script :
os.execute('curl -H \'Content-Type: application/json\' -X PUT -d \'{"duration": 500}\' http://192.168.1.1:80/api/A********/sensors/20/config ')
And then, no effect and I've got an error in my logs :
Error: (CONBEE II) This device don't support action
Anyone can help me ? I'm stuck on this without any idea where to look at.
Domoticz v2021.1 on Raspberry Pi 3B+
Raspbian Buster
ConBee II + Xiaomi devices
Zwave
Re: Difficulties with Curl in a script
Diplo95 wrote: Saturday 24 October 2020 15:13 Anyone can help me ? I'm stuck on this without any idea where to look at.
If you update to latest stable or latest beta you could use dzVents native openURL. In these versions PUT is supported.
Check this wiki chapter to see how
Diplo95
Re: Difficulties with Curl in a script  [Solved]
Post by Diplo95 »
Thanks for the help.
I finally did it with this command :
dz.openURL({
                url = 'http://192.168.1.**:80/api/Axxxxxxxxx/sensors/20/config',
                method = 'PUT',
                headers = { ['Content-Type']= 'application/json' },
		postData = { ['duration'] = '500'},
If it can help
Raspbian Buster
Zwave
