DZ Vents Light timer Help Please [Solved]
Cndiann
Re: DZ Vents Light timer Help Please
Could you maybe share your final script? Looks useful to me also
- madpatrick
- Domoticz version: 2025.2
Sure
local PIR = 'PIR Sensor' -- change to name of your PIR
local light = 'Woonkamer' -- change to name of your light/group
local lux = 'PIR Lux' -- change to name of your lux device
local Sleep = '23:00' -- after sleep time switch off lamps unless PIR movement and LUX value < xx
local retrigger = 'Retrigger using customEvent'
local minutesBeforeSunset = 60 -- 45 min before sunset
return
on =
timer =
'at ' .. minutesBeforeSunset .. ' minutes before sunset', -- This will be concatenated to xx minutes before sunset
--'every minute', -- only for testing
'at ' .. Sleep,
customEvents =
retrigger,
logging =
level = domoticz.LOG_INFO, -- Logging suppressed
marker = '-=# light control #=- ',
execute = function(dz)
local PIR = dz.devices(PIR)
local light = dz.groups(light) -- groups instead of device
local lux = dz.devices(lux).lux
dz.log(' LUX = ' .. lux,dz.LOG_FORCE)
dz.log(PIR.name .. ' was last updated ' .. PIR.lastUpdate.secondsAgo .. ' seconds ago',dz.LOG_FORCE)
dz.log(light.name .. ' state is ' .. light.state ,dz.LOG_FORCE)
-- the text between quotes and the variables minutesBeforeSunset (60) and Sleep (23:00) will be concatenated to
-- between xx minutes before sunset and 23:00
if dz.time.matchesRule('between ' .. minutesBeforeSunset .. ' minutes before sunset and ' .. Sleep) and not(dz.time.matchesRule('at ' .. Sleep)) then
if lux < 16 then
light.switchOn().checkFirst()
dz.log(light.name .. ' switched On or already On',dz.LOG_FORCE)
dz.emitEvent(retrigger).afterSec(300) -- try again in 5 min.
dz.log('Script will start again in 5 minutes',dz.LOG_FORCE)
if PIR.lastUpdate.secondsAgo > 600 then
light.switchOff().checkFirst()
dz.log(light.name .. ' switched Off or already Off',dz.LOG_FORCE)
}-= HP server GEN11 =- ZwaveJS-=- Domoticz v2025.2 -=- Dashticz =-
