Is it possible to use Aeotec radiator thermostat (z-wave) in Domoticz? I use Domoticz with the Aeon labz z-wave stick.
I've added the thermostate in the z-wave control panel (thats works just fine) and I see the "Dry air" device for thermostat. I've added that device in Domoticz and try to set the value (temperature), but it seems it not sent to the thermostat.
What can be wrong?
Does anyone use this thermostat with domoticz?
In the z-wave control panel I can see its current value. On the configuration tab, it's just empty. Is this thermostat not compatible with openzwave?
Possible to use Aeotec Thermostate?
jvgaal
Re: Possible to use Aeotec Thermostate?
Hi, I'm also trying to get the Aeotec Radiator Thermostat working with Domoticz.
I' using a AEON Labs ZW090 Z-Stick Gen5 EU on my Synology.
- Annotation 2020-02-08 194324.png (46.54 KiB) Viewed 823 times
u20p17
any news on this topic?
I am thinkingof buying the Aeotec thermostate, but if its not fully working with Domoticz I might buy other thermosate.
Best regards
Best regards
- a3vd
Raspberry 3+ / 4
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12/Conbee2 (zigbee)
Several Kaku switches/ Weather Underground / Hue
