2020-10-18 17:39:00.182 Status: dzVents: Info: light control: ------ Start internal script: Test_Script:, trigger: "at 17:39"
2020-10-18 17:39:00.182 Status: dzVents: > 1: Memory Usage type:General, subType: Percentage
2020-10-18 17:39:00.182 Status: dzVents: > 2: HDD / type:General, subType: Percentage
2020-10-18 17:39:00.182 Status: dzVents: > 3: HDD /boot type:General, subType: Percentage
2020-10-18 17:39:00.182 Status: dzVents: > 4: HDD /var/flexshare/shares type:General, subType: Percentage
2020-10-18 17:39:00.182 Status: dzVents: > 5: CPU_Usage type:General, subType: Percentage
2020-10-18 17:39:00.182 Status: dzVents: > 6: Fibaro stekker type:Light/Switch, subType: Switch
2020-10-18 17:39:00.182 Status: dzVents: > 7: Fibaro stekker [W] type:Usage, subType: Electric
2020-10-18 17:39:00.182 Status: dzVents: > 8: Wnk - Keukenzijde type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 9: Wnk - Keukenzijde [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 10: Wnk - Tuinzijde type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 11: Wnk - Tuinzijde [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 12: Wnk - Erker type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 13: Wnk - Erker [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 14: Buitenlamp - Voordeur type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 15: Buitenlamp - Voordeur [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 16: Buitenlamp - Garage voor type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 17: Ventilatie Hoog [Q1] type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 18: Ventilatie Laag [Q2] type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 19: Ventilatie Hoog [Q1] [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 20: Ventilatie Laag [Q2] [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 21: Everspring TempHum type:Temp + Humidity, subType: WTGR800
2020-10-18 17:39:00.183 Status: dzVents: > 22: Hal - Lamp type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 23: Hal - Lamp [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 24: Sensor - Achterdeur type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 25: Sensor - Deur Garage type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 26: Sirene Alarm type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 27: Motion Sensor Sensor type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 28: Motion Sensor Burglar type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 29: Motion Sensor - Lux type:Lux, subType: Lux
2020-10-18 17:39:00.183 Status: dzVents: > 30: Alarm mode type:Light/Switch, subType: Selector Switch
2020-10-18 17:39:00.183 Status: dzVents: > 31: Domoticz Security Panel type:Security, subType: Security Panel
2020-10-18 17:39:00.183 Status: dzVents: > 32: RM1 Sensor type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 33: RM1 Smoke type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 34: RM1 Heat type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 35: Temperatuur Overloop type:Temp, subType: LaCrosse TX3
2020-10-18 17:39:00.183 Status: dzVents: > 36: CO Sensor type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 37: CO Carbon Monoxide type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 38: CO Heat type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 39: Temperatuur Zolder type:Temp, subType: LaCrosse TX3
2020-10-18 17:39:00.183 Status: dzVents: > 40: Toon Scenes type:Light/Switch, subType: Selector Switch
2020-10-18 17:39:00.183 Status: dzVents: > 41: Toon Thermostaat type:Thermostat, subType: SetPoint
2020-10-18 17:39:00.183 Status: dzVents: > 42: Temperatuur Kamer type:Temp, subType: LaCrosse TX3
2020-10-18 17:39:00.183 Status: dzVents: > 43: Toon Auto Program type:Light/Switch, subType: Selector Switch
2020-10-18 17:39:00.183 Status: dzVents: > 44: Ketelstand type:Light/Switch, subType: Selector Switch
2020-10-18 17:39:00.183 Status: dzVents: > 45: Ketel Temp IN type:Temp, subType: LaCrosse TX3
2020-10-18 17:39:00.183 Status: dzVents: > 46: Ketel Temp UIT type:Temp, subType: LaCrosse TX3
2020-10-18 17:39:00.183 Status: dzVents: > 47: Keteldruk type:General, subType: Pressure
2020-10-18 17:39:00.183 Status: dzVents: > 48: Tuinlamp - Licht type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 49: Tuinlamp - Stroom type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 50: Tuinlamp - Q1 [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 51: Tuinlamp - Q2 [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 52: Wnk - Openhaard type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 53: Wnk - Openhaard [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 54: SolarEdge kWh Meter type:General, subType: kWh
2020-10-18 17:39:00.183 Status: dzVents: > 55: P1 Gas type:P1 Smart Meter, subType: Gas
2020-10-18 17:39:00.183 Status: dzVents: > 56: P1 Elektra type:P1 Smart Meter, subType: Energy
2020-10-18 17:39:00.183 Status: dzVents: > 57: ModulationLevel type:General, subType: Percentage
2020-10-18 17:39:00.183 Status: dzVents: > 58: Ketel Setpoint type:Temp, subType: LaCrosse TX3
2020-10-18 17:39:00.183 Status: dzVents: > 59: HDD /media/camera1 type:General, subType: Percentage
2020-10-18 17:39:00.183 Status: dzVents: > 60: HDD /media/camera2 type:General, subType: Percentage
2020-10-18 17:39:00.183 Status: dzVents: > 61: HDD /media/backup type:General, subType: Percentage
2020-10-18 17:39:00.183 Status: dzVents: > 62: Process Usage type:General, subType: Custom Sensor
2020-10-18 17:39:00.183 Status: dzVents: > 63: Wnk - Studeerkamer type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 64: Wnk - Studeerkmer [W] type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 65: Hal-ES2 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 66: Hal-ES1 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 67: Hal-ES3 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 68: Hal-ES4 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 69: Hal-DS2 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 70: Hal-DS1 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 71: Hal-DS3 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 72: Hal-DS4 type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 73: Squeezebox Touch type:Lighting 2, subType: AC
2020-10-18 17:39:00.183 Status: dzVents: > 74: Buitenlamp - Garage achter type:Light/Switch, subType: Switch
2020-10-18 17:39:00.183 Status: dzVents: > 75: Buitenlamp - Garage achter type:Usage, subType: Electric
2020-10-18 17:39:00.183 Status: dzVents: > 76: Buienradar type:General, subType: Text
2020-10-18 17:39:00.183 Status: dzVents: > 77: RegenData type:Rain, subType: TFA
2020-10-18 17:39:00.183 Status: dzVents: !Info: light control: Motion Sensor Burglar
2020-10-18 17:39:00.183 Status: dzVents: !Info: light control: Wnk - Studeerkamer
2020-10-18 17:39:00.184 Status: dzVents: !Info: light control: Motion Sensor - Lux
2020-10-18 17:39:00.184 Status: dzVents: Info: light control: ------ Finished Test_Script
2020-10-18 17:39:00.184 Error: dzVents: Error: (3.0.2) light control: An error occurred when calling event handler Test_Script
2020-10-18 17:39:00.184 Error: dzVents: Error: (3.0.2) light control: ...moticz/scripts/dzVents/generated_scripts/Test_Script.lua:48: attempt to index a number value (local 'lux')
Not sure what happened, but i lost my configuration settings of the PIR in domoticz.
The sensor is still available, but no config settings.
