Python Plugin: PWS (Personal Weather Station)
Aroby
Re: Python Plugin: PWS (Personal Weather Station)
Thanks Xorfor, somehow I didn't found https://github.com/Xorfor/Domoticz-PWS-Plugin/issues/8.
Awesome! The Garni 2055 Arcus is sending it's data to Domoticz now with the iptables rule in between.
Very nice plugin!
Very nice plugin!
atlantica
I've a question about installing this nice PWS plugin for my Ventus W830 ver 1.1.4. I've made a DNS record for wow.metoffice.gov.uk pointed to my domoticz server. (I cannont use Wunderground becase this is in use). The data is actualy into domoticz according to the log:
2020-10-15 12:49:02.304 (Ventus W830) Processing 'onConnectCallback' message
2020-10-15 12:49:02.304 (Ventus W830) Calling message handler 'onConnect'.
2020-10-15 12:49:02.304 (Ventus W830) onConnect IP_PWS:18840=IP_PWS:18840 0-Success
2020-10-15 12:49:02.304 (Ventus W830) Name: 'IP_PWS:18840', Transport: 'TCP/IP', Protocol: 'HTTP', Address: 'IP_PWS', Port: '18840', Baud: 0, Bytes: 325, Connected: True, Last Seen: 2020-10-15 12:49:02, Parent: 'Server'
2020-10-15 12:49:02.304 (Ventus W830) Processing 'ReadEvent' message
2020-10-15 12:49:02.304 (Ventus W830) Received 325 bytes of data
2020-10-15 12:49:02.305 (Ventus W830) 47 45 54 20 68 74 74 70 3a 2f 2f 77 6f 77 2e 6d 65 74 6f 66 GET.http://wow.metof
2020-10-15 12:49:02.305 (Ventus W830) 66 69 63 65 2e 67 6f 76 2e 75 6b 2f 61 75 74 6f 6d 61 74 69 fice.gov.uk/automati
2020-10-15 12:49:02.305 (Ventus W830) 63 72 65 61 64 69 6e 67 3f 73 69 74 65 69 64 3d 63 26 73 69 creading?siteid=c&si
2020-10-15 12:49:02.305 (Ventus W830) 74 65 41 75 74 68 65 6e 74 69 63 61 74 69 6f 6e 4b 65 79 3d teAuthenticationKey=
2020-10-15 12:49:02.305 (Ventus W830) 64 26 64 61 74 65 75 74 63 3d 32 30 32 30 2d 31 30 2d 31 35 d&dateutc=2020-10-15
2020-10-15 12:49:02.305 (Ventus W830) 25 32 30 31 30 3a 34 39 3a 30 26 77 69 6e 64 64 69 72 3d 33 %2010:49:0&winddir=3
2020-10-15 12:49:02.305 (Ventus W830) 31 30 26 77 69 6e 64 73 70 65 65 64 6d 70 68 3d 30 2e 30 26 10&windspeedmph=0.0&
2020-10-15 12:49:02.305 (Ventus W830) 77 69 6e 64 67 75 73 74 6d 70 68 3d 30 2e 30 26 68 75 6d 69 windgustmph=0.0&humi
2020-10-15 12:49:02.305 (Ventus W830) 64 69 74 79 3d 37 35 26 64 65 77 70 74 66 3d 34 35 2e 35 26 dity=75&dewptf=45.5&
2020-10-15 12:49:02.305 (Ventus W830) 74 65 6d 70 66 3d 35 33 2e 32 26 64 61 69 6c 79 72 61 69 6e tempf=53.2&dailyrain
2020-10-15 12:49:02.305 (Ventus W830) 69 6e 3d 30 2e 30 30 26 62 61 72 6f 6d 69 6e 3d 33 30 2e 31 in=0.00&baromin=30.1
2020-10-15 12:49:02.305 (Ventus W830) 38 26 73 6f 66 74 77 61 72 65 74 79 70 65 3d 45 61 73 79 57 8&softwaretype=EasyW
2020-10-15 12:49:02.305 (Ventus W830) 65 61 74 68 65 72 56 31 2e 31 2e 34 20 48 54 54 50 2f 31 2e eatherV1.1.4.HTTP/1.
2020-10-15 12:49:02.305 (Ventus W830) 30 0d 0a 41 63 63 65 70 74 3a 20 2a 2f 2a 0d 0a 48 6f 73 74 0..Accept:.*/*..Host
2020-10-15 12:49:02.305 (Ventus W830) 3a 20 77 6f 77 2e 6d 65 74 6f 66 66 69 63 65 2e 67 6f 76 2e :.wow.metoffice.gov.
2020-10-15 12:49:02.305 (Ventus W830) 75 6b 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 43 6c 6f 73 uk..Connection:.Clos
2020-10-15 12:49:02.306 (Ventus W830) 65 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. e....
2020-10-15 12:49:02.306 (Ventus W830) Pushing 'onMessageCallback' on to queue
2020-10-15 12:49:02.306 (Ventus W830) Processing 'onMessageCallback' message
2020-10-15 12:49:02.306 (Ventus W830) Calling message handler 'onMessage'.
2020-10-15 12:49:02.306 (Ventus W830) onMessage IP_PWS:18840=IP:18840
2020-10-15 12:49:02.306 (Ventus W830) HTTP Details (3):
2020-10-15 12:49:02.306 (Ventus W830) 'Verb: 'GET'
2020-10-15 12:49:02.306 (Ventus W830) 'URL: 'http://wow.metoffice.gov.uk/automaticre ... therV1.1.4'
2020-10-15 12:49:02.306 (Ventus W830) 'Headers' (3):
2020-10-15 12:49:02.306 (Ventus W830) 'Accept': '*/*'
2020-10-15 12:49:02.306 (Ventus W830) 'Host': 'wow.metoffice.gov.uk'
2020-10-15 12:49:02.306 (Ventus W830) 'Connection': 'Close'
2020-10-15 12:49:02.306 (Ventus W830) Request GET
2020-10-15 12:49:02.307 (Ventus W830) strData: siteid=c&siteAuthenticationKey=d&dateutc=2020-10-15%2010:49:0&winddir=310&windspeedmph=0.0&windgustmph=0.0&humidity=75&dewptf=45.5&tempf=53.2&dailyrainin=0.00&baromin=30.18&softwaretype=EasyWeatherV1.1.4
2020-10-15 12:49:02.307 (Ventus W830) data: {'siteid': 'X', 'siteAuthenticationKey': 'X', 'dateutc': '2020-10-15%2010:49:0', 'winddir': '310', 'windspeedmph': '0.0', 'windgustmph': '0.0', 'humidity': '75', 'dewptf': '45.5', 'tempf': '53.2', 'dailyrainin': '0.00', 'baromin': '30.18', 'softwaretype': 'EasyWeatherV1.1.4'}
2020-10-15 12:49:02.307 Error: (Ventus W830) 'onMessage' failed 'TypeError':'unsupported operand type(s) for *: 'int' and 'NoneType''.
2020-10-15 12:49:02.307 Error: (Ventus W830) ----> Line 402 in '../domoticz/plugins/Domoticz-PWS-Plugin/plugin.py', function onMessage
2020-10-15 12:49:02.307 Error: (Ventus W830) ----> Line 173 in '../domoticz/plugins/Domoticz-PWS-Plugin/plugin.py', function onMessageroot
2020-10-15 12:49:04.712 (Ventus W830) Queued asynchronous read aborted (IP_PWS:18840), [2] End of file.
2020-10-15 12:49:04.712 (Ventus W830) Pushing 'DisconnectedEvent' on to queue
2020-10-15 12:49:04.714 (Ventus W830) Processing 'DisconnectedEvent' message
The following Errors occours:
Can this error in de plugin.py be corected in the next version?
Kind regards
David
Kind regards
David
Xorfor
@atlantica: should be fixed in the current version
atlantica
@Xorfor Thanks for the quick response and fix!
It's working now only that there are still errors in the log:
2020-10-15 20:50:22.161 Error: (Ventus W830) 'onMessage' failed 'TypeError':'unsupported operand type(s) for *: 'NoneType' and 'int''.
2020-10-15 20:50:22.161 Error: (Ventus W830) ----> Line 406 in '/domoticz/plugins/Domoticz-PWS-Plugin/plugin.py', function onMessage
2020-10-15 20:50:22.161 Error: (Ventus W830) ----> Line 353 in '/domoticz/plugins/Domoticz-PWS-Plugin/plugin.py', function onMessage
Xorfor
@atlantic: I made a quick fix. Hopefully this prevents the errors in your log.
atlantica
Thank Xorfor!!!Xorfor wrote: Thursday 15 October 2020 22:19 @atlantic: I made a quick fix. Hopefully this prevents the errors in your log.
The data is importing now; only 3 records are still empty:
atlantica
For all Ventus W830 user with version 1.1.4 (First version) is working when youy add the following DNS record in your Router/DNS server:
- wow.metoffice.gov.uk pointed to my domoticz server.
- Linux (Raspberry PI, etc)
iptables -t nat -A PREROUTING -s [IP of PWS] -p tcp --dport 80 -j DNAT --to-destination [IP of Domoticz]:5000
Windows
netsh interface portproxy add v4tov4 connectaddress=[IP of PWS] connectport=80 listenaddress=[IP of Domoticz] listenport=5000 NOT TESTED YET!!!
eddieb
Hi, is it possible to modify this plugin to work with ObserverIP software ?
That units run a web service which can be read locally. I can produce screendumps if neccesary.
I run a dzevents custom made script that does the job, but it might be usefull to add this to this plugin.
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Xorfor
That is correct that these sensors are still empty: according to your log, your pws is not sending this data!!!atlantica wrote: Friday 16 October 2020 7:38
Xorfor
Can you send me more information? Something like the json(?) message from your PWS. your dzevents script, etc!eddieb wrote: Friday 16 October 2020 8:58 Hi, is it possible to modify this plugin to work with ObserverIP software ?
If it is possible to fit this in the plugin, do you want to test this?
eddieb
Of course I will, but, I will probably do that tomorrow. Testing is no problem either.Xorfor wrote: Friday 16 October 2020 18:28 Can you send me more information? Something like the json(?) message from your PWS. your dzevents script, etc!
The ObserverIP unit is NOT producing json. It produces a web page which can be read with a http get ...
like this, (I can supply a html dump of the page ...)
Xorfor
Please send me the information by pm.eddieb wrote: Friday 16 October 2020 18:39 Of course I will, but, I will probably do that tomorrow. Testing is no problem either.
And yes, a html dump, url, etc will help.
atlantica
Thanks for that understandig. In that case i have to use the wundergroud..... And I can confirm that is working then
Is it possible make an option to forward the incoming request from the weatherstation to the url from wundergorund in your pluging? All the correct data for wunderround is already in there....
If I will use this plugin, will Domoticz update my devices every 60 seconds?
I understand Wunderground will only update every 10 minutes or longer, as there is a limit for downloads (500) a day.
My old weatherstation (433mhz) updated every 16 seconds the devices in Domoticz.
Hope someone can explain this to me. As I will use the windsensor for screens, so when the windspeed increases I can't wait for 10 minutes to have 'actual' readings
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
eddieb
I stopped using this plugin and went to wudirect ...Melissen wrote: Sunday 10 April 2022 21:32 Hi
Because sensors are only updated by this plugin when they change it is a little bit difficult to see but in my setup sensors are updated a lot faster. I see wind every 30 seconds...
Xorfor
The update interval is specified by the setting in WS View. There is a parameter 'Upload Interval' with a default of 60 seconds. If you want, you can change this value.Melissen wrote: Sunday 10 April 2022 21:32 Hi
The data is pushed to the plugin, so by default each 60 sec. the data will be changed in Domoticz.
If you want to have the data updated every 10 seconds, please change the parameter in WS View in 10!
bas1502
- Domoticz version: 2022.1
I am new here and have a look around.
I am trying to let te plugin work, but I can't find the type PWS (see screenshot)? Do someone else have the same problem?
Thanks for helping me!
Bas
Bas
- Domoticz version: 2026.3
Check if python and more important if all necessary module are installed for using python plugins. See wiki page https://www.domoticz.com/wiki/Using_Python_pluginsbas1502 wrote: Friday 26 August 2022 18:12 Hi,
bas1502
Thanks for your quick reaction. I will check and read the wiki!waltervl wrote: Friday 26 August 2022 21:32Check if python and more important if all necessary module are installed for using python plugins. See wiki page https://www.domoticz.com/wiki/Using_Python_pluginsbas1502 wrote: Friday 26 August 2022 18:12 Hi,
bas1502
Thanks it works, now I can find 'PWS'.
After I added new hardware (PWS), my Domoticz environment isn't stable any more. The language turns into Albanian and I get the message 'Problem saving settings!' when I try to change the settings.
I don't know how to solve. Search the internet but no solution.
Thanks for helping me.
