cant acces plugins folder and when i created script in demoticz they cannot be run.
what i do and what i install and order
1. default installation ubuntu 20.04 LTS
2.
sudo apt updateCode: Select all
sudo apt upgradeCode: Select all
sudo rebootCode: Select all
wget -qO - http://www.webmin.com/jcameron-key.asc | sudo apt-key add -
sudo sh -c 'echo "deb http://download.webmin.com/download/repository sarge contrib" > /etc/apt/sources.list.d/webmin.list'
sudo apt update
sudo apt install webminthen i install python.
7. then i run
sudo apt install python3Code: Select all
sudo apt install python3-dev9. sudo reboot
then i install domoticz:
10.
curl -sSL install.domoticz.com | sudo bashthen when i try to go to cd domoticz/plugins i get:
cd: domoticz/plugins: Permission denied
also when i make a dzvent script it cannot be run whatever i do.
i know the reboots prolly dont need to happen this often but after like 10 installs i tried allot all the same result.
als i tried to update to the beta. same result.
whats going wrong here?
Pictures:
https://imgshare.io/image/Nx6TWj
https://imgshare.io/image/Nx6qOt
https://imgshare.io/image/Nx6cKS
