PiZiGate not working
Got my PiZiGate in yesterday and installed it today in my Raspberry. Installed the plugin and had some issues figuring some of the settings out for the plugin for the PiZiGate (what port to use etc). I can not seem to get the hardware/plugin to work. Maybe i am missing steps or i am doing something wrong?
Below is the logging i get from my Domoticz setup. Serial port has been enabled with raspi-config as well.
Thanks in advance for the help!
2020-10-10 00:57:30.326 Status: (PiZigate) Started.
2020-10-10 00:57:33.637 Status: (PiZigate) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-10-10 00:57:33.639 Status: (PiZigate) Entering work loop.
2020-10-10 00:57:33.653 Status: (PiZigate) Zigate plugin stable-4.11.003 started
2020-10-10 00:57:33.653 Status: (PiZigate) Debug: 0
2020-10-10 00:57:33.654 Status: (PiZigate) load PluginConf
2020-10-10 00:57:33.665 Status: (PiZigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-06.json
2020-10-10 00:57:33.666 Status: (PiZigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 00:57:33.666 Status: (PiZigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 00:57:33.666 Status: (PiZigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-10 00:57:33.666 Status: (PiZigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-10-10 00:57:33.667 Status: (PiZigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-10 00:57:33.669 Status: (PiZigate) Switching Heartbeat to 5 s interval
2020-10-10 00:57:33.669 Status: (PiZigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2020-10-10 00:57:33.669 [GCC 8.3.0]
2020-10-10 00:57:33.670 Status: (PiZigate) DomoticzVersion: 2020.2
2020-10-10 00:57:33.670 Status: (PiZigate) DomoticzHash: b63341bc0
2020-10-10 00:57:33.670 Status: (PiZigate) DomoticzBuildTime: 2020-04-26 13:47:55
2020-10-10 00:57:33.671 Status: (PiZigate) Opening DomoticzDB in raw
2020-10-10 00:57:33.744 Status: (PiZigate) Plugin Database: DeviceList-6.txt
2020-10-10 00:57:33.786 Status: (PiZigate) DeviceConf loaded
2020-10-10 00:57:34.496 Status: (PiZigate) load ListOfDevice
2020-10-10 00:57:35.405 Status: (PiZigate) ==> Transport Mode: auto
2020-10-10 00:57:35.475 Status: (PiZigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial0
2020-10-10 00:57:35.476 Status: (PiZigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
Re: PiZiGate not working
I don't really see any problem from the log you provided.
Here are some information which might help you:
https://github.com/pipiche38/Domoticz-Z ... ng/Home.md
Wiki is available here.
Zigbee for Domoticz FAQ
I got the same problem, no errors but webserver is not accesible. Connection refused, it was working until upgrade domoticz. (Crashed)
Verstuurd vanaf mijn SM-G960F met Tapatalk
Please provide logs in order to see what happen.
And make sure to do Erase Pdm/initialise as described in the wiki , the first time to get the zigate unit with the plugin
Thanks for all the replies. Just to be safe i removed the plugin and added it again. Made sure it was set to erase the PDM. My problem is also that i am not able to access the web UI for the Zigate after adding the plugin. I have added the logs below again that i see after adding it.
Am i doing something wrong maybe?
I also see this error coming up in the error log:
Error log:
2020-10-10 12:48:36.335 Error: (PiZigate) onMessage : we have probably lost some datas, zero1 = 17
Status log:
2020-10-10 12:48:17.582 Status: (PiZigate) Started.
2020-10-10 12:48:20.893 Status: (PiZigate) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-10-10 12:48:20.895 Status: (PiZigate) Entering work loop.
2020-10-10 12:48:20.923 Status: (PiZigate) Zigate plugin stable-4.11.003 started
2020-10-10 12:48:20.929 Status: (PiZigate) Debug: 0
2020-10-10 12:48:20.930 Status: (PiZigate) load PluginConf
2020-10-10 12:48:20.958 Status: (PiZigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-06.json
2020-10-10 12:48:20.958 Status: (PiZigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 12:48:20.958 Status: (PiZigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 12:48:20.958 Status: (PiZigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-10 12:48:20.959 Status: (PiZigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-10 12:48:20.963 Status: (PiZigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-10 12:48:20.963 Status: (PiZigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-10 12:48:20.963 Status: (PiZigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-10-10 12:48:20.963 Status: (PiZigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-10 12:48:20.965 Status: (PiZigate) Switching Heartbeat to 5 s interval
2020-10-10 12:48:20.965 Status: (PiZigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2020-10-10 12:48:20.965 [GCC 8.3.0]
2020-10-10 12:48:20.966 Status: (PiZigate) DomoticzVersion: 2020.2
2020-10-10 12:48:20.966 Status: (PiZigate) DomoticzHash: b63341bc0
2020-10-10 12:48:20.966 Status: (PiZigate) DomoticzBuildTime: 2020-04-26 13:47:55
2020-10-10 12:48:20.967 Status: (PiZigate) Opening DomoticzDB in raw
2020-10-10 12:48:21.107 Status: (PiZigate) Plugin Database: DeviceList-6.txt
2020-10-10 12:48:21.150 Status: (PiZigate) DeviceConf loaded
2020-10-10 12:48:21.747 Status: (PiZigate) load ListOfDevice
2020-10-10 12:48:21.836 Status: (PiZigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-6.txt
2020-10-10 12:48:21.837 Status: (PiZigate) Transport mode: PI
2020-10-10 12:48:22.041 Status: (PiZigate) Python version: ['3.7.3 (default, Jul 25 2020, 13:03:44) ', '[GCC 8.3.0]'] dist: ('debian', '10.6', '') linux_distribution: ('debian', '10.6', '') system: Linux machine: armv6l platform: Linux-5.4.51+-armv6l-with-debian-10.6 uname: uname_result(system='Linux', node='raspberrypi', release='5.4.51+', version='#1333 Mon Aug 10 16:38:02 BST 2020', machine='armv6l', processor='') version: #1333 Mon Aug 10 16:38:02 BST 2020 mac_ver: ('', ('', '', ''), '')
2020-10-10 12:48:22.670 Status: (PiZigate) ==> Transport Mode: auto
2020-10-10 12:48:22.710 Status: (PiZigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial0
2020-10-10 12:48:22.711 Status: (PiZigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-10-10 12:48:36.338 Status: (PiZigate) Major Version Num: 0003
2020-10-10 12:48:36.338 Status: (PiZigate) Installer Version Number: 031a
2020-10-10 12:48:41.307 Status: (PiZigate) Erase Zigate PDM
Error log:
Status log:
The logs you provided looks good . The Web UI is available only after 2 or 3 minutes after the start of the plugin.lostodos wrote: ↑Saturday 10 October 2020 12:53 Thanks for all the replies. Just to be safe i removed the plugin and added it again. Made sure it was set to erase the PDM. My problem is also that i am not able to access the web UI for the Zigate after adding the plugin. I have added the logs below again that i see after adding it.
Error log:
Status log:
But so far so good
Thanks Pipiche!
I tried again just now but still no luck:(
Oopen the browser on the IP address of my Domoticz server with port 9440 should do it right?
Thanks.
Thanks.
yes, that is correct. You don't have any firewall on your server ?
from log perspective, don't you have any more after
I dont think so, its the default image from Domoticz for my Raspberry...
I do not see port 9440 on the list of listening ports either:
sshd 375 root 3u IPv4 14401 0t0 TCP *:22 (LISTEN)
sshd 375 root 4u IPv6 14412 0t0 TCP *:22 (LISTEN)
domoticz 381 root 19u IPv6 14492 0t0 TCP *:8080 (LISTEN)
domoticz 381 root 26u IPv6 14499 0t0 TCP *:8443 (LISTEN)
domoticz 381 root 33u IPv6 14508 0t0 TCP *:6144 (LISTEN)
sshd 1705 pi 10u IPv6 256249 0t0 TCP [::1]:6010 (LISTEN)
sshd 1705 pi 11u IPv4 256250 0t0 TCP 127.0.0.1:6010 (LISTEN)
Re: PiZiGate werkt niet
ive got this, error in python module??
hope you understand this,
2020-10-10 14:02:11.609 Error: (Zigate) Error while importing run from python module subprocess, fall back to os module
2020-10-10 14:04:43.440 Error: CConnection_disconnect, disconnection request from 'Zigate' ignored. Transport does not exist.
2020-10-10 14:04:44.719 Error: (Zigate) Error while importing run from python module subprocess, fall back to os module
2020-10-10 14:04:44.425 Status: (Zigate) Entering work loop.
2020-10-10 14:04:44.426 Status: (Zigate) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-10-10 14:04:44.432 Status: (Zigate) Zigate plugin stable-4.11.003 started
2020-10-10 14:04:44.432 Status: (Zigate) Debug: 0
2020-10-10 14:04:44.432 Status: (Zigate) load PluginConf
2020-10-10 14:04:44.436 Status: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-27.json
2020-10-10 14:04:44.436 Status: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-10-10 14:04:44.436 Status: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 14:04:44.436 Status: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-10-10 14:04:44.436 Status: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-10 14:04:44.436 Status: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-10 14:04:44.436 Status: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-10 14:04:44.436 Status: (Zigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-10 14:04:44.436 Status: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-10 14:04:44.437 Status: (Zigate) Switching Heartbeat to 5 s interval
2020-10-10 14:04:44.437 Status: (Zigate) Python Version - 3.4.4 (default, Aug 20 2019, 08:42:52)
2020-10-10 14:04:44.437 [GCC 8.3.0]
2020-10-10 14:04:44.437 Status: (Zigate) DomoticzVersion: 2020.2
2020-10-10 14:04:44.437 Status: (Zigate) DomoticzHash: b63341bc0
2020-10-10 14:04:44.437 Status: (Zigate) DomoticzBuildTime: 2020-04-26 13:47:55
2020-10-10 14:04:44.437 Status: (Zigate) Opening DomoticzDB in raw
2020-10-10 14:04:44.460 Status: (Zigate) Plugin Database: DeviceList-27.txt
2020-10-10 14:04:44.477 Status: (Zigate) DeviceConf loaded
2020-10-10 14:04:44.608 Status: (Zigate) load ListOfDevice
2020-10-10 14:04:44.671 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-27.txt
2020-10-10 14:04:44.671 Status: (Zigate) Transport mode: PI
2020-10-10 14:04:44.713 Status: (Zigate) Python version: ['3.4.4 (default, Aug 20 2019, 08:42:52) ', '[GCC 8.3.0]'] dist: ('debian', '10.6', '') linux_distribution: ('debian', '10.6', '') system: Linux machine: armv7l platform: Linux-5.4.51-v7+-armv7l-with-debian-10.6 uname: uname_result(system='Linux', node='raspberrypi', release='5.4.51-v7+', version='#1333 SMP Mon Aug 10 16:45:19 BST 2020', machine='armv7l', processor='') version: #1333 SMP Mon Aug 10 16:45:19 BST 2020 mac_ver: ('', ('', '', ''), '')
2020-10-10 14:04:44.957 Status: (Zigate) ==> Transport Mode: auto
2020-10-10 14:04:44.967 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyAMA0
2020-10-10 14:04:44.967 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address:
can you try ?
And then restart the plugin .
How does the PiZiGate blue Led looks like ? Is that a low blue, or high intensity Blue ?
Domoticz-Zigate/Tools/pi-zigate.sh run
you might install subprocess module2020-10-10 14:02:11.609 Error: (Zigate) Error while importing run from python module subprocess, fall back to os module
I don't know which RPI you have, but did you check against https://github.com/pipiche38/Domoticz-Z ... ookbook.md ?
Ive got a pi3b, it was working before a crash with domoticz. Ill try to install submodule.
This seems to have done the trick! I thought i did this already but maybe had another reboot in between....I can access the web interface now!pipiche wrote: ↑Saturday 10 October 2020 14:59 can you try ?
And then restart the plugin .Code: Select all
Thanks for the help!
To give you more details, the script you run , basically did what the plugin should be doing on its own. But due to the missing subprocess module, it failed.
Normally there is way to handle but it seems that it didn't succeed.
the pi-zigate.sh run (or what should be done inside the plugin) as to be done at least after each reboot. You will notice that the PiZiGate Led is not with the same intensity
Thank you for the details! The plugin looks great, going to explore it now:)
Provided a small donation through paypal for a beer:) I think the plugin is a great addition and i appreciate the support!
Thanks for the donation, will allow to buy news devices for integration
Got my problem Solved,
installed python 3-dev, no more errors,
installed plugin, en tested it with the test program, my problem was in the dt overlay, because in the pierre gielen documents it says,
dtoverlay = pi3-disable-bt but is has to be > dtoverlay=pi3-disable-bt to many space between the=did not notice that. Maybe you can correct that for the noobs like me. But working again, Happy customer.
Is that not covered on the Wiki ?Nivekamoud wrote: ↑Saturday 17 October 2020 13:28 Hi,
dtoverlay = pi3-disable-bt but is has to be > dtoverlay=pi3-disable-bt to many space between the=did not notice that. Maybe you can correct that for the noobs like me. But working again, Happy customer.![]()
