XiaomiGateway: unable to write command - Invalid key Topic is solved
konix
Post by konix »
I use an Xiaomi Gateway since 2 years now it's the V2 version without Homekit.
This summer I have rebuild my domoticz installation with the last Stable version of domoticz :
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0].
I have never issue before this rebulding but now I have some time issues in the log like :
XiaomiGateway: unable to write command - Invalid key.
The Gateway and the Devices works but it's not stable .....
The switch works after two or three clik or double click or long clik ....
The motion detector work sometime, same for the motion detector and the doors switch .....
I have double check my password in my Xiaomi application and I have also try to change this password without succes
I have delete my xiaomi Gateway in Domoticz and add again without succes
I have delete the gateway in my xiaome application on the phone and add again without succes
If I deactivate and reactivate the gateway, it's okay for the moment, the errors come back later
To summarize it works when he wants :D
No issue when I check directly in the Xiaomi application in my phone.
If you knowsomething about that I take it !!
In the last version of Domoticz we have ID and Password when you add the Gateway but in my last version there was just Password, what is the ID, maybe it's the token of the Gateway ?
Have a good day.
Raspberry PI 2 whith Domoticz (Master)
Raspberry PI B+ whith Domoticz (Slave)
Raspberry PI B+ whith OSMC
RFLINK - ZWAVE - TELEINFO - 1 WIRE
konix
Re: XiaomiGateway: unable to write command - Invalid key
Post by konix »
Nobody have an idea for that :roll:
AntoonvdOetelaar
Post by AntoonvdOetelaar »
2020-11-26 00:10:15.731 Error: XiaomiGateway: unable to write command - Invalid key
2020-11-26 03:54:20.513 Error: XiaomiGateway: unable to write command - Invalid key
2020-11-26 03:54:20.764 Error: XiaomiGateway: unable to write command - Invalid key
So, I do see it also, but the xiaomi gateway does function at least in between, so I think this error code is more about a different error, maybe because of lost connection?
RPI3B, Z-WAVE AEOTEC GEN5, Zigbee2Mqtt, Xiaomi gateway, GPIO, I2C, 1-wire, DS18B20, P1 meter, Growatt, Buienradar, Harmony hub, Domoticz 2020.2
Domoticz version: 2026.3
Possibly related to this? viewtopic.php?f=68&t=34673
