Help Install Domoticz on Odorid HC1
SavioThecnic
Domoticz version: 2022.1
Post by SavioThecnic »
Good morning
Sorry for my English but I'm Italian and I use google translate
I want to install Domoticz on an odroid HC1
i downloaded image ubuntu-20.04.1-5.4-mate-odroid-xu4-20200818.img
but it seems that on Odroid I have to start perforza from SD
and I cannot start from the SSD connected to it
shame because I wanted to speed up and avoid using SD
seen its RW limit
However now I have mesos this image on SD
and starting with SD with image ubuntu-20.04.1-5.4-mate-odroid-xu4-20200818.img now from pc win I am in ssh inside odroid
I downloaded the compressed file domoticz_linux_aarch64.tgz
and copied with WinSCP on the SD of the odoid but beyond this I stop :(
Now someone can tell me the sequence of commands to install domoticz on odroid
As ubuntu operating system - 20.04.1-5.4
All the guides and commands I see around are for raspian raspberry but I see that these commands on Ubuntu do not need to help me
Thank you
SavioThecnic
Re: Help Install Domoticz on Odorid HC1
nobody can help me :(
So for now I've done this
mkdir ~/domoticz
cd ~/domoticz
wget http://releases.domoticz.com/releases/r ... arch64.tgz
tar xzvf domoticz_linux_aarch64.tgz
rm domoticz_linux_aarch64.tgz
then I try to run the script but he gives me permission denied and I state that I started with a sudo su
./domoticz.sh
So I write it so it is also useful to others doing
./updaterelease
and then
./domoticz
Now it seems that it is installed but when I restart it does not start automatically how do you fix this?
sudo crontab -e
Added the line at the end of course instead of savio put your user where you have installed domoticz
@reboot / home / savio / domoticz / domoticz
you have to modify the premises of the domoticz script from inside the domoticz folder type
chmod + x domoticz
and it is also advisable to disable the firewall command
sudo systemctl disable ufw
No it seemed that it was working but it doesn't work if I turn it off and restart the service does not start automatically
I tried this one too but it's not very clear to me what and how to change :(
sudo nano /etc/init.d/domoticz.sh
The lines you usually need to change are USERNAME, DAEMON and DAEMON_ARGS
USERNAME = yourusername
DAEMON = / home / $ USERNAME / domoticz / $ NAME
DAEMON_ARGS = "- daemon -www 8080"
Abhor
Domoticz version: V2.2284
Post by Abhor »
Hello Savio and others,
I found this link and you probably got it already working at this moment...
...so I add this reply for future people who wanna install Domoticz on a ODROID too
This worked for me and my ODROID N2+
** It just happend to be a energy crisis so I replaced my Domoticz running on a desktop 24/7,
** so I step over to ODROID because due a chip shortage there are almost no Raspberry 4 to buy
But anyhow .. I find a easyer way (or in the meantime the developers made this script later then your message here)
I downloaded the link from where you described and typed the following commands as root :
First I made a new user :
adduser domo
usermod -a -G sudo domo
usermod -a -G dialout domo
wget https://releases.domoticz.com/releases/release/domoticz_linux_aarch64.tgz
(atm of this writing, but you always can upgrade Domoticz after this)
cd domoticz/scripts
chmod +x install.sh
./install
... and the script does the rest (with thanks to the one who wrote the script)
Have fun and I hope someone was helped with this !
May the sensors be with you ...
gizmocuz
Post by gizmocuz »
Could you not use the default installation command line ?
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
This worked on my C2, but these days I use docker-compose
Deali
Post by Deali »
That is on the download page.
I made an upgrade with it.
Worked fine
