[Solved] Dots under floorplan in case multiple floorplans disappeared. Topic is solved
FireWizard
Post by FireWizard »
Usually, in case of multiple Floor plans, you are able to switch to another Floor plan by clicking the dot under the Floor plan.
After a recent update only under the first Floor plan, the dots are visible. As soon as you click on one of the dots, you move to the selected Floor plan, but the dots have disappeared. So it is impossible to select another Floor plan.
You have to go to the tab on the top menu in order to go back to the first plan and then select another.
Currently running 2020.2 (build 12451)
Raspberry Pi 2
Browsers: Firefox, Waterfox and Chrome,
Has anyone seen the same behavior?
Last edited by FireWizard on Sunday 11 October 2020 11:59, edited 1 time in total.
FireWizard
Re: Dots under floorplan in case multiple floorplans disappeared.
Updated to v12453 and the result is the same
Krueggel
Post by Krueggel »
currently, since a few days, I do have the same issue. Can somebody help us, or did you already solve the issue?
thanks and regards
FireWizard
HI,
@Krueggel
Currently running 12461 and the problem has not been solved. You are the first one that indicate to have a similar issue.
I really think, it has something to do with changes in the GUI, now about a week ago.
Created an issue on Github
See: https://github.com/domoticz/domoticz/issues/4388
Best regards
Last edited by FireWizard on Saturday 10 October 2020 18:03, edited 1 time in total.
Krueggel
Post by Krueggel »
yes, I'm using domoticz for some years, and i guess it occurs approx 1 week ago. Most of the ime I'm using my mobile Phone and webbrowser to control domoticz, now its hard to use. As you already mentioned, scrolling/navigation is no longer possible...
FireWizard
This issue has been solved in version 12.467.
I have tested it and can confirm.
Do not forget to clear the webbrowser cache and app cache.
Thanks @gizmocuz :D
Krueggel
Re: [Solved] Dots under floorplan in case multiple floorplans disappeared.
Post by Krueggel »
I also can confirm that after a update to 12.467 and clearing the browser cache the issue has been solved.
Many thanks @gizmocuz!
Krueggel
