New Python plugin: Domoticz SolarEdge_ModbusTCP
Sjonnie2017
Domoticz version: Latest ß
Re: Just a tiny little problem
Post by Sjonnie2017 »
AddieJanssen wrote: Sunday 04 October 2020 15:13
Hi Sjonnie,
The plugin is not able to connect with your inverter.
This is probably not an issue with your software.
Did you enable Modbus on your inverter and if so: do the ip address and ports match?
Hi Addie,
Thanks for your support!
Could it have to do with the fact that I only got the panels yesterday and I have not received the login information for the SolarEdge as of yet?
Since I have no login information I cannot check if modbus is enabled. Unless of course you have some sneaky hack I can use to access the device ;)
Greetz,
Sjonnie
YouLess Energy meter
AddieJanssen
Post by AddieJanssen »
Sjonnie2017 wrote: Sunday 04 October 2020 16:41
Hi Sjonnie,
Hi Addie,
Greetz,
Sjonnie
Well, I am not into the "sneaky hacks"; my inverter has some good old fashion buttons that I can push to enable modbus :D
Which inverter do you have?
eddieb
Re: New Python plugin: Domoticz SolarEdge_ModbusTCP
Post by eddieb »
My supplier enable modbus_tcp for me the day he installed the inverter ... :mrgreen:
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Sjonnie2017
AddieJanssen wrote: Sunday 04 October 2020 17:00
I have a SE4000H. No display or control buttons unfortunately. I have to rely on an app (and have to endure the fact that my supplier can monitor my usage as well :shock: ). I have not have received the login information so I guess I'll just have to wait :(
Greetz,
Sjonnie
@eddieb: lucky you! My Polish technicians did not give me the opportunity (of which I did not know it existed :()
eddieb
Post by eddieb »
Sjonnie2017 wrote: Sunday 04 October 2020 17:28 I have a SE4000H. No display or control buttons unfortunately. I have to rely on an app (and have to endure the fact that my supplier can monitor my usage as well :shock: ). I have not have received the login information so I guess I'll just have to wait :(
Greetz,
Sjonnie
modbus_tcp is default DISABLED . It has to be enabled by your technician. By default it listens on tcp/1502 on the inverter (if enabled !).
My SE3500H also does not have buttons, you can only configure it with the Solaredge Setapp.
It needs the admin password installed by your technician ...
Sjonnie2017
eddieb wrote: Sunday 04 October 2020 17:36
Thanks for the info! I have contacted my supplier to ask to enable modbus_tcp. Expect I will have to wait till Monday to get a response ;)
Greetz,
Sjonnie
AddieJanssen
AddieJanssen wrote: Sunday 04 October 2020 15:10
McMelloW wrote: Saturday 03 October 2020 12:29 Getting regular the following errors in the log.
What can I do about this?
2020-10-03 11:58:54.790 Error: (SolarEdge) 'onHeartbeat' failed 'KeyError'.
2020-10-03 11:58:54.790 Error: (SolarEdge) ----> Line 522 in '/home/pi/domoticz/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py', function onHeartbeat
2020-10-03 11:58:54.790 Error: (SolarEdge) ----> Line 335 in '/home/pi/domoticz/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py', function onHeartbeat
Nice!
Looks like your inverter is returning a status that is not supported by the solaredge_modbus library that is used by the plugin.
I will update the plugin to catch the error so we can find out what that status is.
Will get back to you when this is in place.
New version available which should fix this error.
For upgrade instructions have a look at here: https://github.com/addiejanssen/domotic ... the-plugin
@McMellow: would you be so kind to update your plugin and share the results?
You should not see error messages in the log anymore, but instead you will see something allong the line of:
Key not found in lookup table:
in the log of the Status device.
We then need to find out what that status means.
eddieb
Post by eddieb »
I just updated the plugin. did NOT have errors before, NOW I see
Screenshot 2020-10-09 at 16.28.55.png (36.41 KiB) Viewed 34073 times
Where should I look for more info ?
Before it said "producing"
AddieJanssen
Oops..... Uploaded the wrong version to GitHub...
Will fix it now.
eddieb
Post by eddieb »
looks OK now here ;-) thanks for fixing
Screenshot 2020-10-09 at 17.06.58.png (31.05 KiB) Viewed 34070 times
AddieJanssen
eddieb wrote: Friday 09 October 2020 16:29 Hi,
Uploaded the correct version to GitHub now.
If you would be so kind to upgrade one more time.
It should then work fine again.
Sorry for the mixup....
AddieJanssen
eddieb wrote: Wednesday 30 September 2020 7:16 Running for 2 days now and I am very pleased with this plugin.
I notice something in I can not explain ...
Why do these events occur with different users ?
Why are some events caused by "timer" ???
I have been trying to replicate this, but can't get it to show usernames; no matter what I do.
I looked at the database and found that the data is stored in a table named "LightingLog".
That table has a "User" column; but for my tests, never shows a value in that column.
It's another Domoticz-thingie; no clue why a device subtype "sTypeTextStatus" ends up in a "LightingLog" table.
Also interesting to see that there is no hardware type that looks anything like that table name.
The plugin is not doing anything with users in any shape or form.
There might be a device configured in your setup that uses that table as well and that might be using the "User" column.
It feels to me as a cosmetic issue only, but to find out what is going on, we need more information....
What would help, is to have a peek in the database to see what is in the "LightingLog" table.
Do you have an option to peek into that table?
Addie
eddieb
Post by eddieb »
AddieJanssen wrote: Monday 12 October 2020 14:07
Sure,
let me know what query you want to see ...
Currently there are approx 2500 lines in that table
Eddie
AddieJanssen
I would like to know if there is a value in the "User" column for the devices that are managed by the plugin.
If possible, it would be great if you could export the table to a text file and attach it here.
I wonder if there is a relationship between the entries generated by the plugin and other devices that you have configured....
eddieb
Post by eddieb »
AddieJanssen wrote: Monday 12 October 2020 14:44
my inverter devices are 826 and up ...
sqlite> select * from LightingLog where DeviceRowID > 825;
826|0|Producing (Throttled)|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 08:09:28
826|0|Producing|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 08:10:38
826|0|Producing (Throttled)|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 08:15:51
826|0|Producing|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 08:16:36
826|0|Producing (Throttled)|MQTT|2020-10-07 15:16:55
826|0|Producing|MQTT|2020-10-07 15:17:00
826|0|Producing (Throttled)|MQTT|2020-10-07 15:17:05
826|0|Producing|MQTT|2020-10-07 15:17:10
826|0|Producing (Throttled)|MQTT|2020-10-07 15:17:25
826|0|Producing|MQTT|2020-10-07 15:17:35
826|0|Producing (Throttled)|MQTT|2020-10-07 15:54:35
826|0|Producing|MQTT|2020-10-07 15:54:39
826|0|Producing (Throttled)|timer|2020-10-07 18:36:01
826|0|Producing|timer|2020-10-07 18:36:46
826|0|Producing (Throttled)|MQTT|2020-10-07 18:41:57
826|0|Producing|MQTT|2020-10-07 18:42:38
826|0|Producing (Throttled)|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:47:53
826|0|Producing|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:48:33
826|0|Producing (Throttled)|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:53:45
826|0|Sleeping|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:14:39
826|0|Producing (Throttled)|MQTT|2020-10-08 08:37:15
826|0|Producing|MQTT|2020-10-08 08:38:25
826|0|Producing (Throttled)|MQTT|2020-10-08 08:43:37
826|0|Producing|MQTT|2020-10-08 08:44:22
826|0|Producing (Throttled)|MQTT|2020-10-08 08:49:33
826|0|Producing|MQTT|2020-10-08 08:50:18
826|0|Producing (Throttled)|MQTT|2020-10-08 08:55:29
826|0|Producing|MQTT|2020-10-08 08:56:11
826|0|Producing (Throttled)|MQTT|2020-10-08 09:01:35
826|0|Producing|MQTT|2020-10-08 09:12:35
826|0|Producing (Throttled)|MQTT|2020-10-08 09:17:47
826|0|Producing|MQTT|2020-10-08 09:18:32
826|0|Producing (Throttled)|MQTT|2020-10-08 09:23:43
826|0|Producing|MQTT|2020-10-08 09:24:28
826|0|Producing (Throttled)|MQTT|2020-10-08 09:51:33
826|0|Producing|MQTT|2020-10-08 09:52:19
826|0|Producing (Throttled)|MQTT|2020-10-08 09:57:29
826|0|Producing|MQTT|2020-10-08 09:58:14
826|0|Producing (Throttled)||2020-10-08 16:58:48
826|0|Producing||2020-10-08 16:59:33
826|0|Producing (Throttled)|MQTT|2020-10-08 17:47:34
826|0|Producing|MQTT|2020-10-08 17:48:19
826|0|Producing (Throttled)|MQTT|2020-10-08 17:53:29
826|0|Producing|MQTT|2020-10-08 17:54:14
826|0|Producing (Throttled)|Admin|2020-10-08 17:59:25
826|0|Producing|Admin|2020-10-08 18:00:13
826|0|Producing (Throttled)|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 18:17:32
826|0|Producing|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 18:18:32
826|0|Producing (Throttled)|timer|2020-10-08 18:23:43
826|0|Producing|timer|2020-10-08 18:35:23
826|0|Producing (Throttled)|timer|2020-10-08 18:40:34
826|0|Sleeping|timer|2020-10-08 19:10:33
826|0|Producing (Throttled)|MQTT|2020-10-09 08:24:50
826|0|Producing|MQTT|2020-10-09 08:26:05
826|0|Producing (Throttled)|MQTT|2020-10-09 08:31:16
826|0|Producing|MQTT|2020-10-09 08:32:01
826|0|Producing (Throttled)|MQTT|2020-10-09 08:37:12
826|0|Producing|MQTT|2020-10-09 08:37:57
826|0|Producing (Throttled)|MQTT|2020-10-09 08:43:05
826|0|Producing|MQTT|2020-10-09 08:43:51
826|0|Key not found in lookup table: 4||2020-10-09 16:28:21
826|0|Producing||2020-10-09 17:06:28
826|0|Producing (Throttled)|MQTT|2020-10-09 18:42:53
826|0|Producing|MQTT|2020-10-09 18:43:38
826|0|Producing (Throttled)|MQTT|2020-10-09 18:48:49
826|0|Sleeping|MQTT|2020-10-09 19:11:06
826|0|Producing (Throttled)|MQTT|2020-10-10 08:13:25
826|0|Producing|MQTT|2020-10-10 08:14:35
826|0|Producing (Throttled)|MQTT|2020-10-10 08:19:45
826|0|Producing|MQTT|2020-10-10 08:20:30
826|0|Producing (Throttled)|MQTT|2020-10-10 08:29:01
826|0|Producing|MQTT|2020-10-10 08:29:46
826|0|Producing (Throttled)|MQTT|2020-10-10 15:38:46
826|0|Producing|MQTT|2020-10-10 15:39:51
826|0|Producing (Throttled)|MQTT|2020-10-10 15:45:07
826|0|Producing|MQTT|2020-10-10 15:45:49
826|0|Producing (Throttled)|MQTT|2020-10-10 15:53:14
826|0|Producing|MQTT|2020-10-10 15:58:59
826|0|Producing (Throttled)|MQTT|2020-10-10 16:04:11
826|0|Producing|MQTT|2020-10-10 16:04:56
826|0|Producing (Throttled)|MQTT|2020-10-10 16:10:07
826|0|Producing|MQTT|2020-10-10 16:10:52
826|0|Producing (Throttled)|MQTT|2020-10-10 16:56:33
826|0|Producing|MQTT|2020-10-10 16:57:18
826|0|Producing (Throttled)|MQTT|2020-10-10 17:02:27
826|0|Producing|MQTT|2020-10-10 17:10:17
826|0|Producing (Throttled)|MQTT|2020-10-10 17:33:51
826|0|Producing|MQTT|2020-10-10 17:50:08
826|0|Producing (Throttled)|MQTT|2020-10-10 17:55:20
826|0|Producing|timer|2020-10-10 18:28:56
826|0|Producing (Throttled)|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-10 18:46:09
826|0|Sleeping|MQTT|2020-10-10 19:15:04
826|0|Producing (Throttled)|MQTT|2020-10-11 08:19:32
826|0|Producing|MQTT|2020-10-11 08:20:42
826|0|Producing (Throttled)|MQTT|2020-10-11 08:25:58
826|0|Producing|MQTT|2020-10-11 08:26:38
826|0|Producing (Throttled)|timer|2020-10-11 18:40:24
826|0|Producing|timer|2020-10-11 18:41:05
826|0|Producing (Throttled)|timer|2020-10-11 18:46:20
826|0|Sleeping|MQTT|2020-10-11 19:14:10
826|0|Producing (Throttled)|MQTT|2020-10-12 08:12:11
826|0|Producing|MQTT|2020-10-12 08:13:26
826|0|Producing (Throttled)|MQTT|2020-10-12 08:18:33
826|0|Producing|MQTT|2020-10-12 08:19:18
826|0|Producing (Throttled)|MQTT|2020-10-12 08:24:34
826|0|Producing|MQTT|2020-10-12 08:25:14
826|0|Producing (Throttled)|MQTT|2020-10-12 08:30:24
826|0|Producing|MQTT|2020-10-12 08:31:14
AddieJanssen
Weird....
Can you run one more query: don't filter on DeviceRowID, but select a timeframe.
Looking at your log I am interested to see what is in the table starting at 2020-10-07 18:41:57 and stopping at 2020-10-08 08:38:25.
I would like to see the sequence of entries; so please don't filter anything and sort it by date if possible.
Can you share those results?
Thanks,
Addie
eddieb
Post by eddieb »
AddieJanssen wrote: Monday 12 October 2020 15:15
sqlite> select * from LightingLog where Date > "2020-10-07 18:41:57" and Date < "2020-10-08 08:38:25" order by Date;
220|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:44:31
190|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:45:12
150|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:46:15
166|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:46:19
166|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:52:03
150|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 18:52:16
190|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:00:14
166|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:03:00
150|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:03:16
190|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:05:14
166|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:08:12
150|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:08:16
190|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:10:15
220|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:14:28
190|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:15:16
166|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:20:12
150|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-07 19:20:17
250|1|0|MQTT|2020-10-07 19:25:13
150|0|0|MQTT|2020-10-07 19:25:17
190|1|0|MQTT|2020-10-07 19:25:17
166|0|0|MQTT|2020-10-07 19:25:24
190|0|0|MQTT|2020-10-07 19:30:17
213|0|Off|MQTT|2020-10-07 19:33:18
213|1|On|MQTT|2020-10-07 19:33:33
184|1|0|MQTT|2020-10-07 19:35:18
166|1|0|MQTT|2020-10-07 19:36:22
150|1|15|MQTT|2020-10-07 19:36:47
166|0|0|MQTT|2020-10-07 19:42:06
150|0|0|MQTT|2020-10-07 19:42:17
150|1|15|MQTT|2020-10-07 19:51:47
166|1|0|MQTT|2020-10-07 19:51:59
184|0|0|MQTT|2020-10-07 19:55:20
166|0|0|MQTT|2020-10-07 19:57:13
150|0|0|MQTT|2020-10-07 19:57:18
166|1|0|MQTT|2020-10-07 20:07:41
150|1|15|MQTT|2020-10-07 20:07:48
150|0|0|MQTT|2020-10-07 20:13:18
166|0|0|MQTT|2020-10-07 20:13:24
250|0|0|MQTT|2020-10-07 20:19:59
166|1|0|MQTT|2020-10-07 20:23:17
150|1|15|MQTT|2020-10-07 20:23:18
150|0|0|MQTT|2020-10-07 20:29:19
166|0|0|MQTT|2020-10-07 20:29:32
213|0|Off|MQTT|2020-10-07 20:35:02
213|1|On|MQTT|2020-10-07 20:35:47
150|1|15|MQTT|2020-10-07 20:39:19
166|1|0|MQTT|2020-10-07 20:39:25
150|0|0|MQTT|2020-10-07 20:45:19
166|0|0|MQTT|2020-10-07 20:45:40
190|1|0|MQTT|2020-10-07 20:55:28
150|1|15|MQTT|2020-10-07 20:55:49
166|1|0|MQTT|2020-10-07 20:56:08
150|0|0|MQTT|2020-10-07 21:01:20
166|0|0|MQTT|2020-10-07 21:01:20
190|0|0|MQTT|2020-10-07 21:05:29
166|1|0|MQTT|2020-10-07 21:12:15
150|1|15|MQTT|2020-10-07 21:12:20
150|0|0|MQTT|2020-10-07 21:18:20
166|0|0|MQTT|2020-10-07 21:18:32
150|1|15|MQTT|2020-10-07 21:29:20
166|1|0|MQTT|2020-10-07 21:29:27
148|0|0|MQTT|2020-10-07 21:31:20
149|1|15|MQTT|2020-10-07 21:31:20
278|0|Off|MQTT|2020-10-07 21:32:35
148|1|15|MQTT|2020-10-07 21:39:51
149|0|0|MQTT|2020-10-07 21:39:51
150|0|0|MQTT|2020-10-07 21:40:51
166|0|0|MQTT|2020-10-07 21:40:57
166|1|0|MQTT|2020-10-07 21:45:40
150|1|15|MQTT|2020-10-07 21:45:51
150|0|0|MQTT|2020-10-07 21:53:21
166|0|0|MQTT|2020-10-07 21:53:28
166|1|0|MQTT|2020-10-07 22:00:14
150|1|15|MQTT|2020-10-07 22:00:21
148|0|0|MQTT|2020-10-07 22:02:21
149|1|15|MQTT|2020-10-07 22:02:21
148|1|15|MQTT|2020-10-07 22:02:51
149|0|0|MQTT|2020-10-07 22:02:51
150|0|0|MQTT|2020-10-07 22:02:51
166|0|0|MQTT|2020-10-07 22:02:51
150|1|15|MQTT|2020-10-07 22:03:21
166|1|0|MQTT|2020-10-07 22:03:22
148|0|0|MQTT|2020-10-07 22:04:21
149|1|15|MQTT|2020-10-07 22:04:21
148|1|15|MQTT|2020-10-07 22:04:51
149|0|0|MQTT|2020-10-07 22:04:51
150|0|0|MQTT|2020-10-07 22:04:51
166|0|0|MQTT|2020-10-07 22:04:56
203|0||MQTT|2020-10-07 22:11:05
202|0||MQTT|2020-10-07 22:11:13
166|1|0|MQTT|2020-10-07 22:11:41
150|1|15|MQTT|2020-10-07 22:11:52
278|1|On|MQTT|2020-10-07 22:12:26
208|0|0|Admin|2020-10-07 22:13:10
142|0|0|Admin|2020-10-07 22:13:52
148|0|0|Admin|2020-10-07 22:14:22
149|1|15|Admin|2020-10-07 22:14:22
149|0|0|Admin|2020-10-07 22:14:52
150|0|0|Admin|2020-10-07 22:14:52
166|0|0|Admin|2020-10-07 22:15:20
166|1|0|Admin|2020-10-07 22:18:29
149|1|15|Admin|2020-10-07 22:18:52
150|1|15|Admin|2020-10-07 22:18:52
166|0|0|Admin|2020-10-07 22:20:03
150|0|0|Admin|2020-10-07 22:20:22
149|0|0|Admin|2020-10-07 22:20:52
149|1|15|Admin|2020-10-07 22:22:22
150|1|15|Admin|2020-10-07 22:22:52
166|1|0|Admin|2020-10-07 22:23:10
166|0|0|Admin|2020-10-07 22:23:41
150|0|0|Admin|2020-10-07 22:23:52
149|0|0|Admin|2020-10-07 22:24:22
203|0|100|timer|2020-10-07 22:30:02
175|0|30|timer|2020-10-07 22:30:26
208|0|100|timer|2020-10-07 22:35:01
202|0|100|timer|2020-10-07 22:40:01
250|1|0|MQTT|2020-10-07 23:25:11
149|1|15|MQTT|2020-10-07 23:47:55
150|1|15|MQTT|2020-10-07 23:47:55
149|0|0|MQTT|2020-10-07 23:48:25
150|0|0|MQTT|2020-10-07 23:48:25
250|0|0|MQTT|2020-10-08 00:14:30
149|1|15|MQTT|2020-10-08 01:11:59
150|1|15|MQTT|2020-10-08 01:11:59
149|0|0|MQTT|2020-10-08 01:12:29
150|0|0|MQTT|2020-10-08 01:12:29
149|1|15|MQTT|2020-10-08 02:35:38
150|1|15|MQTT|2020-10-08 02:35:38
150|0|0|MQTT|2020-10-08 02:36:08
149|0|0|MQTT|2020-10-08 02:36:38
250|1|0|MQTT|2020-10-08 02:48:51
212|0|Off|MQTT|2020-10-08 03:10:52
210|0|Off|MQTT|2020-10-08 03:10:54
213|0|Off|MQTT|2020-10-08 03:10:54
210|1|On|MQTT|2020-10-08 03:10:56
213|1|On|MQTT|2020-10-08 03:10:56
212|1|On|MQTT|2020-10-08 03:10:57
190|1|0|MQTT|2020-10-08 03:47:06
190|0|0|MQTT|2020-10-08 03:52:07
190|1|0|MQTT|2020-10-08 03:57:07
149|1|15|MQTT|2020-10-08 04:00:07
149|0|0|MQTT|2020-10-08 04:00:37
184|1|0|MQTT|2020-10-08 04:52:56
190|0|0|MQTT|2020-10-08 05:02:58
184|0|0|MQTT|2020-10-08 05:12:58
166|1|0|MQTT|2020-10-08 05:23:57
149|1|15|MQTT|2020-10-08 05:24:10
150|1|15|MQTT|2020-10-08 05:24:10
166|0|0|MQTT|2020-10-08 05:24:28
149|0|0|MQTT|2020-10-08 05:24:40
150|0|0|MQTT|2020-10-08 05:24:40
190|1|0|MQTT|2020-10-08 05:33:01
93|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 05:42:15
93|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 05:42:20
190|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 05:43:25
184|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 05:53:26
184|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:13:28
190|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:28:30
149|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:48:12
150|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:48:12
190|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:48:32
149|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:48:42
150|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:48:42
184|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:53:32
190|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:53:33
142|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:55:12
148|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:55:42
166|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:56:09
150|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:56:12
190|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 06:58:33
190|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:03:34
150|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:10:42
166|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:10:43
202|1||EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:14:19
278|0|Off|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:14:40
148|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:14:43
149|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:14:43
150|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:14:43
166|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:14:53
148|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:15:13
149|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:15:13
150|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:15:13
166|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:15:24
220|1|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:21:01
821|1|10|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:21:01
220|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:29:32
142|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:29:43
148|0|0|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:29:43
149|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:29:43
150|1|15|EventSystem//home/pi/domoticz/dzVents/runtime/dzVents.lua|2020-10-08 07:29:43
166|1|0|Admin|2020-10-08 07:29:59
220|1|0|Admin|2020-10-08 07:29:59
22|2|21|Admin|2020-10-08 07:30:23
166|0|0|Admin|2020-10-08 07:30:31
149|0|0|Admin|2020-10-08 07:30:43
150|0|0|Admin|2020-10-08 07:30:43
23|1|1|Admin|2020-10-08 07:30:57
22|2|35|Admin|2020-10-08 07:31:03
22|2|28|Admin|2020-10-08 07:31:05
22|2|33|Admin|2020-10-08 07:31:07
22|2|34|Admin|2020-10-08 07:31:08
22|2|35|Admin|2020-10-08 07:31:09
22|2|21|Admin|2020-10-08 07:37:09
22|2|24|Admin|2020-10-08 07:37:12
22|2|26|Admin|2020-10-08 07:37:13
23|0|0|Admin|2020-10-08 07:43:49
220|0|0|Admin|2020-10-08 07:44:33
190|0|0|Admin|2020-10-08 07:48:39
213|0|Off|Admin|2020-10-08 07:49:59
250|0|0|MQTT|2020-10-08 08:06:15
166|1|0|MQTT|2020-10-08 08:08:06
149|1|15|MQTT|2020-10-08 08:08:14
150|1|15|MQTT|2020-10-08 08:08:14
166|0|0|MQTT|2020-10-08 08:09:08
149|0|0|MQTT|2020-10-08 08:09:14
150|0|0|MQTT|2020-10-08 08:09:14
190|1|0|MQTT|2020-10-08 08:13:42
AddieJanssen
Looking at that log, it looks like Domoticz is using the last used user in the entries that are added by the plugin.
The plugin is using the Update function as documented here: https://www.domoticz.com/wiki/Developin ... in#Devices
There is no option to provide a user in that call and I would expect the user column to show nothing for the entries added by the plugin.
We either have found a "hidden feature" or a "bug" in Domoticz.
It will probably take a substantial amount of time to find out what is causing it and I don't want to investigate that any further now.
I don't think there is any harm in this, so for now, I will close this issue and document what we found. Perhaps it will be fixed in the future.
Thanks for your time.
Sjonnie2017
Hi Addie et all,
No luck so far enabling "modbus". The company that installed it told me it can only be activated using the set app near the device (silly since it is connected by wire and has no WiFi ;)). I did however get a manual so I can adjust settings with the control buttons that are hidden behind the fascia. Unfortunately I do not know which setting in the menu I should alter. Does anyone have any clue?
Greetz,
Sjonnie
eddieb
Post by eddieb »
Sjonnie2017 wrote: Thursday 15 October 2020 18:47
in https://www.solaredge.com/sites/default ... l-note.pdf is a paragraph on how to enable modbus over tcp.
In my case that was only possible with the setapp over wifi close to the inverter.
My supplier came by and did that within 5 minutes ...
