Plugwise Adam
eddieb
Re: Plugwise Adam
Post by eddieb »
Nice to have you back !
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
schj
Re: Plugwise Adam
Post by schj »
Dr8072 wrote: Wednesday 26 August 2020 10:45 Apologies to all who have been following this topic. I started to extend the Anna plugin for the ADAM, however as stated before, life got in the way and haven't had the change to do private coding until now.
I fear i have to start again if i would pick this up again completely from scratch as the repository i used for this has been corrupted - read hard disk crash.
I'm focusing on bug fixing the base Anna plugin for now.
If you need testing let me know.
koenkooi
Domoticz version: 3.7439
Re: Plugwise Adam
Post by koenkooi »
I had a go at extending support for Adam in the domoticz plugin: https://github.com/koenkooi/domoticz/commits/plugwise
The changes so far:
  • Read out all appliances and push supported measurements to domoticz, so you get separate devices for Tom/Lisa/Anna
  • Add support for heater pressure, valve position and battery level
  • Change log to "Plugwise" instead of "AnnaTherm"
The first change both renames and renumbers all current Anna/Adam devices, so beware. The battery level is also implemented in a quick, but very un-domoticz like way. The structure of the XML combined with the current code makes it hard for me to add it in a non-wasteful way.
I want to add more items, like all the different heater/boiler temperatures reported over opentherm, but the holidays are almost over and the schools wil l be closed for another 2 weeks here :/
Feel free to add more things yourself and PR it to my repo, hopefully all this can get sent as a PR to the main domoticz repo soon.
ervine
Re: Plugwise Adam
Post by ervine »
Do you have any updates on this? I would really love to integrate the Adam into my domoticz environment. I am not a programmer, so don't know how to do it myself.
Thx!
Yougo
Domoticz version: v2022.1
Re: Plugwise Adam
Post by Yougo »
I installed an ADAM HA gateway and I added the "Plugwise Anna Thermostat via LAN interface"
In the ADAM 5 heating zones are configured.
Following devices show up on the Hardware tab:
Only 1 thermostat and 1 temperature device show up.
How can I add the other temperature and thermostat devices to the list?
Alain
Domoticz version: 2022.1
Re: Plugwise Adam
Post by Alain »
Has this gotten any further development? Can you see and control all zones now?
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Alain
Re: Plugwise Adam
Post by Alain »
Has anyone managed to connect the Plugwise Lisa thermostat? I want one in each room but would like to read and set the temperature in each room through Domoticz.
