Script not Working - Getting Temp from a Sensor  [Solved]
SiberianTiger
Domoticz version: 2020.1
Post by SiberianTiger »
Hi Guys (and Girls?)
I have a "MyStrom" Switch with integrated Temp-Sensor. I would like to get that Data from the Switch and pass it to a Virtual Sensor in Domoticz.
MyStrom Switch API: https://api.mystrom.ch/#982cf1bb-c873-4 ... dfa51e1afe
I have created a Dummy and a Virtual Temperatur Sensor called "Temp Balkon"
Then i searched trough the wiki an came out with this Script below:
It doesn't give me an error in the log, but also the Temperatur does not get Updated it shows only 0°C.
The Output of the Integrated Sensor looks like this:
{"measured":21.3125,"compensation":11,"compensated":10.3125}
My Script to get the Data is that:
		timer = {
			'every 5 seconds' -- just an example to trigger the request
		httpResponses = {
			'TempBalkon' -- must match with the callback passed to the openURL command
		if (item.isTimer) then
			domoticz.openURL({
				url = 'xxx.xxx.xxx.xxx',
				method = 'GET /temp',
				callback = 'TempBalkon', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
					local TempBalkon = item.json.compensated  -- just an example
					-- update some device in Domoticz
					domoticz.devices('TempBalkon').updatetemperatur(item.json.compensated)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
What did i wrong? Sorry im new to this whole scripting thing, but i tought that i could make this with reading trought the Wiki...
Thanks in Advance
Last edited by SiberianTiger on Monday 28 September 2020 23:24, edited 1 time in total.
Re: Script not Working - Getting Temp from a Sensor
SiberianTiger wrote: Monday 28 September 2020 22:14 Then i searched trough the wiki an came out with this Script below:
See my remarks in below script.
return
    on =
        timer =
            'every minute', -- timer can not be set to a higher frequency then once a minute.
        httpResponses =
            'TempBalkon', -- must match with the callback passed to the openURL command
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
        marker = 'Balcony temperature',
        if item.isTimer then
            domoticz.openURL(
                url = '192.168.178.30',
                method = 'GET', -- methods can only be GET, POST, PUT and DELETE
        elseif item.isHTTPResponse then
            if item.ok and item.isJSON then
                    domoticz.devices('TempBalkon').updateTemperature(item.json.compensated) -- methods are case sensitive
                domoticz.log(item, domoticz.LOG_DEBUG)
            domoticz.log('Kind of unexpected..', domoticz.LOG_ERROR)
SiberianTiger
Re: Script not Working - Getting Temp from a Sensor  [Solved]
Perfect! Simply Perfect! Thanks Man... With your Tips and the Error log i found the Problems!
The now working script is this:
return
    on =
        timer =
        httpResponses =
    logging =
        level = domoticz.LOG_ERROR, -- change to domoticz.LOG_ERROR when all ok
            domoticz.openURL(
                url = 'xxx.xxx.xxx.xxx/temp',
                    domoticz.devices(17).updateTemperature(item.json.compensated) -- methods are case sensitive
