Configure PIR
no66
Configure PIR
Post by no66 »
new setup and long time since I've dabbeled in Domoticz.
I used to have a Coolcam NAS-PD02Z Battery Powered PIR Sensor V2+ associated with a wall plug and was happy with the set up.
New pi setup and no association, but using a blocky to trigger the wall plug, but want less than 30 seconds that seem coded into the PIR.
Howver, when I try to update the ON time, that setting just reverts to 30 seconds.
Any ideas?
2. Motion detection ON time:
30
(second) (actual: 30)
This parameter can be determined how long the associated devices should stay ON status. For instance, this parameter is set to 30(second), the PIR detector will send a BASIC_SET Command to an associated device with value basic set level if PIR detector is triggered and the associated device will be turned on 30(second) before it is turned off. This Parameter value must be large than Parameter 6#. If user set this parameter to default by Configure CC, the parameter #6 will be set to default value. Available Settings:5 to 600(second).
Last Update: 2020-09-26 11:20:30
Domoticz | RPi2 | RFXCom 433 | Nexa switches, dimmers, doorbell |
