Sebastian, as said in the e-mail I sent you a few minutes ago, I will test the "Stop command" with all type of blinds I have:
- Blinds
- blinds inverted
- Venezian Blinds EU
Currently it does not work anymore if I change the type of a switch through my Domoticz interface. Maybe Dromotica does not take my updates into account... Does the Switches lists refresh itself automaticaly ?
Moreover the widgets does not work anymore
https://drive.google.com/file/d/0B2CGM_ ... sp=sharing
The "Select scene" is empty
Finally,is it possible to suggest you some points to add to the wish list ?
I'm currently testing S.A.R.A.H in order to manage my domoticz server.
http://blog.encausse.net/s-a-r-a-h/
The Domoticz plugin for SARAH needs the IDX number of scenes and switches.
Would it be possible to get informations (as the IDX number) of items of a lists in dromotica ?
Eric
Raspberry 3b+
Debian GNU/Linux 11 (bullseye)
Mobile App :
Home made progressive web app
RFXTrx433E transceiver (for my RTS devices)
Somfy Tahoma Switch (for my IO devices)
Aeon Labs Z-Stick S2
