How to display graphs on dashboard
Gurgeh
Post by Gurgeh »
i am new to this and would like this specific solution: I would like to see the "air quality last 24 hours" and "Temperature Last 24 Hours" on the same page. Ideally even in the same graph.
How do I do that? Do i install another theme and look there, or do i custom write an html file and somehow use that?
Just point me in the right direction and i will do the rest... Thank you!
HansieNL
Re: How to display graphs on dashboard
Post by HansieNL »
Maybe you can take a look at Dashticz https://github.com/Dashticz/dashticz
Blah blah blah
Gurgeh
Post by Gurgeh »
Thank you. I will install it anyway because i am curious. (Is it possible to install it on windows? I only see linux instructions...)
However it seem a little like overkill to install this, just to display a graph with the 3 inputs, no?
gizmocuz
Post by gizmocuz »
Another option is to push the required data to influxDB and use grafana for charting (via a docker container for example)
Gurgeh
Post by Gurgeh »
Wow, all that sound really complicated.
Cant i just cut the html or php sections which display the Air and the CO2 out and put them in the same php or html page and just display that?
Gurgeh
Post by Gurgeh »
How do I install the Aurora Theme on windows?
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Gurgeh wrote: Wednesday 23 September 2020 15:17 How do I install the Aurora Theme on windows?
You can download the .zip file from github page
https://github.com/flatsiedatsie/domoticz-aurora-theme
copied the content to "domoticz/www/styles" or where your styles directory is located
Othe roption is the with the Domoticz Theme manager plugin:
https://github.com/galadril/domoticz-theme-manager
madpatrick
madpatrick wrote: Thursday 24 September 2020 20:49
Gurgeh
Post by Gurgeh »
Thank you that worked and taught me more about the domo file structure!
Users browsing this forum: BarryT and 1 guest
