Zigate Bitron Door/Windows contact and errors in log
ahattink
Domoticz version: Stable
Post by ahattink »
Can somebody help/explain what these logentries mean?
Domoticz Error log:
2020-09-24 14:27:10.339 Error: (Zigate) 'onHeartbeat' failed 'TypeError':'type str doesn't define __round__ method'.
2020-09-24 14:27:10.339 Error: (Zigate) ----> Line 996 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-09-24 14:27:10.339 Error: (Zigate) ----> Line 668 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-09-24 14:27:10.339 Error: (Zigate) ----> Line 185 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoTools.py', function ResetDevice
2020-09-24 14:27:10.339 Error: (Zigate) ----> Line 97 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoTools.py', function RetreiveSignalLvlBattery
Domoticz Status log:
2020-09-24 14:25:50.996 Status: (Zigate) Device Announcement: Schuurdeur(9752, 00124b00062ac55f) Join Flag: 0x99 - Unknown value received. RSSI: 102 ChangeShortID: False
These logs appeared after a while after pairing the Door sensor. The model is: 90201021A and the sensor is working ok.
I guess the Bitron sensor is reporting battery level, but Zigate does not know this?
(i have already updated the plugin and Zigate firmware to latest version)
Pi 3B, latest stable
RFXCOM, Z-wave, Zigate, Hue, Harmony hub, Netatmo Weather station, Opentherm Gateway, EnOcean,P1 SmartMeter, Plugwise Anna & Adam, Xiaomi Roborock, Sonos One, Google Home, Philips Hue, Homey, D-link and Bitron Video camera.
pipiche
Re: Zigate Bitron Door/Windows contact and errors in log
Post by pipiche »
Could you kindly provide the export.json as described here https://github.com/pipiche38/Domoticz-Z ... -device.md
Thanks in advance
ahattink
Post by ahattink »
Hi pipiche,
Attached the Json.
export.json.txt
(22.77 KiB) Downloaded 43 times
(please rename to export.sjon)
Please take in consideration there could also be an connectivity issue... Could it?
Arthur
ahattink
Post by ahattink »
Hi @pipiche,
I just found out the door/windows contact stops working when the errors appear in the log. Unpair and pair again it works until the error is there again.
2020-09-28 12:31:26.468 Error: (Zigate) 'onMessage' failed 'TypeError':'type str doesn't define __round__ method'.
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 984 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 519 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 325 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 538 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 523 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 122 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 241 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8401
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 111 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoMaj.py', function MajDomoDevice
2020-09-28 12:31:26.468 Error: (Zigate) ----> Line 97 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoTools.py', function RetreiveSignalLvlBattery
I will unpair the door/windows contact and pair again in an location where i am shure it can connect directly to the Zigate stick. This to rule out an mesh issue. Does this make sense?
Arthur
pipiche
Post by pipiche »
Could you kindly try with the latest version of the plugin which has been pushed today ?
This error should have been addressed.
ahattink
Post by ahattink »
Hi pipiche,
Updated and error logs are gone. Super!
New is an battery warning! Issue closed. Thank you verry much!
Arthur
