Error in log (Solved)
leby
Post by leby »
Hi, my script's is running but I get this error in the log
Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:823: bad argument #1 to 'find' (string expected, got table)
Any ideas on whats wrong, was not there some month ago... cant find any script with error..
EDIT, I can see it appear on both sunset and sunrise but also a few other times.
/lennart
Re: Error in log
leby wrote: Friday 18 September 2020 17:25 Hi, my script's is running but I get this error in the log
I am on a different version so not 100% sure what line 823 is in your version. Can you please share line 810-830 of your /home/pi/domoticz/dzVents/runtime/EventHelpers.lua ?
leby
Re: Error in log
Post by leby »
		local modules
		-- only search for named and wildcard triggers,
		-- id is done later
		for scriptTrigger, scripts in pairs(allEventScripts) do
			if (string.find(scriptTrigger, '*')) then -- a wild-card was used
				scriptTrigger = ('^' .. scriptTrigger:gsub("[%^$]","."):gsub("*", ".*") .. '$')
				local function sMatch(text, match) -- specialized sanitized match function to allow combination of Lua magic chars in wildcards
					local sanitizedMatch = match:gsub("([%%%(%)%[%]%+%-%?])", "%%%1") -- escaping all 'magic' chars except *, ., ^ and $
					return text:match(sanitizedMatch)
				if sMatch(target, scriptTrigger) then
					if modules == nil then modules = {} end
					for i, mod in pairs(scripts) do
						table.insert(modules, mod)
line 823 is this
/lennart
Re: Error in log
leby wrote: Friday 18 September 2020 17:25 cant find any script with error..
can you replace line 823 in /home/pi/domoticz/dzVents/runtime/EventHelpers.lua with
            if type(scriptTrigger) == 'table' then
                utils.log('Script name: ' .. scripts[1].name  .. '.lua, has a malformed on-section. The trigger = ' .. _.str(scriptTrigger) , utils.LOG_ERROR)
            elseif string.find(scriptTrigger, '*') then -- a wild-card was used
It will not solve the error but will write a line in the log showing which event script triggers the error.
leby
Re: Error in log
Post by leby »
Thx @waaren I deleted a number of old inactive scripts last night and today there are no errors! It seems to be solved at least for now.
/lennart
Re: Error in log
leby wrote:I deleted a number of old inactive scripts last night and today there are no errors!
Good to read!
Would be great if you could share these old scripts (via PM) It might help to make dzVents more resilient and/or catching the error and send a useful message to the log.
