Script KWh month whit a especific date  [Solved]
Nefsolive
Post by Nefsolive »
I need help in creating a script that gives me the total cost per month of KWh, but with a date starting on the day (ex 13 of each month and ending on 12 of each month).
I have OWL CM 180.
Can anyone help me?
Thank you
Re: Script KWh month whit a especific date
Nefsolive wrote: Tuesday 25 August 2020 10:32 I need help in creating a script that gives me the total cost per month of KWh, but with a date starting on the day (ex 13 of each month and ending on 12 of each month).
I have OWL CM 180.
What is the name / deviceType and devicesubType in domoticz of this device as seen on the device tab ?
Nefsolive
Post by Nefsolive »
waaren wrote: Tuesday 25 August 2020 10:44
I have OWL CM 180.
Hello Waaren,
The deviceType is "general" and devicesubType is "kWh".
Working whit Hardware "RFXtrx433E".
Nefsolive wrote: Tuesday 25 August 2020 10:55 The deviceType is "general" and devicesubType is "kWh".
Can you check with this one?
For now it only reports the costs to the domoticz log. If you want it in a device or variable let me know.
        script calculates the cost of energy of one kwH device
        KwH costs need to be set in domoticz meters / coiunters settings
local scriptVar = 'getCosts'
return
    on =
        timer =
            'at 08:00' , --- change to your liking
        devices =
            scriptVar,
        httpResponses =
            scriptVar .. '_*',
    data =
        KwHCost = { initial = 0 },
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all on
        marker = scriptVar,
    execute = function(dz, item)
        local sourceDeviceIndex = 2872 -- change to device you want to measure
        local startDayOfMonth = 13
        if item.isTimer or item.isDevice then
            costURL = dz.settings['Domoticz url'] .. '/json.htm?type=settings' -- to get cost setting
            countURL = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=year&idx=' .. sourceDeviceIndex -- to get cost setting
            dz.openURL(
                url = costURL,
                callback = scriptVar .. '_costs',
            dz.openURL(
                url = countURL,
                callback = scriptVar .. '_logCount',
            }).afterSec(5)
            return
        local function makeMonth(delta)
			if math.floor(delta) ~= delta or delta  < - 11 or delta > 11 then
                dz.log('Only integers -11 - +11 allowed',dz.LOG_ERROR)
                return
            local year = dz.time.year
            if delta < 0 and dz.time.month + delta < 0 then year = dz.time.year - 1 end
            if delta > 0 and dz.time.month + delta > 12 then year = dz.time.year + 1 end
			return ( dz.time.month + delta) % 12, year
        local function getCost(t, day)
            local startMonth, startYear = makeMonth(-1)
            if dz.time.day < day then startMonth, startYear = makeMonth(-2) end
            startDate =  startYear .. '-' .. dz.utils.leadingZeros(startMonth, 2) .. '-' .. dz.utils.leadingZeros(day, 2)
            endDate =  dz.time.year .. '-' .. dz.utils.leadingZeros(( startMonth + 1 ) % 12 , 2) .. '-' .. dz.utils.leadingZeros((day - 1), 2)
            local minCounter = 10^32
            local maxCounter = 0
            for _,r in ipairs(t) do
                if tonumber(r.c) > maxCounter and r.d >= startDate and r.d <= endDate then maxCounter = tonumber(r.c) end
                if tonumber(r.c) < minCounter and r.d >= startDate and r.d <= endDate then minCounter = tonumber(r.c) end
            return dz.utils.round( ( maxCounter - minCounter ) * dz.data.KwHCost, 2 ), startDate, endDate
        if item.ok and item.isJSON then
            if item.trigger:find('_costs') then
                dz.data.KwHCost = item.json.CostEnergy
                local energyCost, startDate, endDate = getCost(item.json.result, startDayOfMonth)
                dz.log('Energycost for device ' .. dz.devices(sourceDeviceIndex).name .. ' between ' .. startDate ..' and ' .. endDate .. ' is: € ' .. energyCost, dz.LOG_FORCE  )
            dz.log('There was a problem handling' .. item.trigger, dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
Nefsolive
Post by Nefsolive »
waaren wrote: Tuesday 25 August 2020 14:37
return
    on =
        timer =
        devices =
            scriptVar,
        httpResponses =
            scriptVar .. '_*',
    data =
    logging =
        marker = scriptVar,
            dz.openURL(
                url = costURL,
            dz.openURL(
                url = countURL,
            }).afterSec(5)
            return
                return
Hello Waaren
thank you very much for the script, works good!
Yes, I really wanted to pass the values to a device, dummy text, and see current month in between the days! you can help me how?
ty
Last edited by Nefsolive on Wednesday 26 August 2020 12:08, edited 1 time in total.
Nefsolive wrote: Wednesday 26 August 2020 10:54 I really wanted to pass the values to a device dummy text, you can help me how.
This one should do that
        KwH costs need to be set in domoticz meters / counters settings
return
    on =
        timer =
        devices =
            scriptVar,
        httpResponses =
            scriptVar .. '_*',
    data =
    logging =
        marker = scriptVar,
        local textDevice = dz.devices('getCosts' )  -- change to devicename you want to see the text message (virtual text device)
            dz.openURL(
                url = costURL,
            dz.openURL(
                url = countURL,
            }).afterSec(5)
            return
                return
                textDevice.updateText('Energycost for device ' .. dz.devices(sourceDeviceIndex).name .. '\n between ' .. startDate ..' and ' .. endDate .. '\n is: € ' .. energyCost)
Nefsolive
Post by Nefsolive »
waaren wrote: Wednesday 26 August 2020 11:31
return
    on =
        timer =
        devices =
            scriptVar,
        httpResponses =
            scriptVar .. '_*',
    data =
    logging =
        marker = scriptVar,
            dz.openURL(
                url = costURL,
            dz.openURL(
                url = countURL,
            }).afterSec(5)
            return
                return
Works perfect Waaren!
Thank u!
And how i make for the current month like beetwin, August 13 and September 12?
ty
Nefsolive
Post by Nefsolive »
I've managed to place the script between the days of the current month and the next.
My thanks for all the support Waaren.
Nefsolive
Post by Nefsolive »
return
    on =
        timer =
        devices =
            scriptVar,
        httpResponses =
            scriptVar .. '_*',
    data =
    logging =
        marker = scriptVar,
            dz.openURL(
                url = costURL,
            dz.openURL(
                url = countURL,
            }).afterSec(5)
            return
                return
Hi waaren,
The script is working, but it is not giving me the correct values ​​between the 13th and 12th of the following month! If you check the switch report, the cost values ​​do not correspond to the script cost values!
I would like him to sum the values to me from the 13th to the 12th of the next month! Like today is 15, so sum the values 13th too 15th, and next day show me the total cost, like 13th too 16th...and finish too cost 0 on 12th day next month ;)
On my log i see;
2020-09-15 17:51:00.333 Status: dzVents: Debug: getCosts: Processing device-adapter for Custo Mensal: Text device
2020-09-15 17:51:00.334 Status: dzVents: Debug: getCosts: OpenURL: url = http://*******/json.htm?type=settings
2020-09-15 17:51:00.334 Status: dzVents: Debug: getCosts: OpenURL: method = GET
2020-09-15 17:51:00.334 Status: dzVents: Debug: getCosts: OpenURL: post data = nil
2020-09-15 17:51:00.334 Status: dzVents: Debug: getCosts: OpenURL: headers = nil
2020-09-15 17:51:00.334 Status: dzVents: Debug: getCosts: OpenURL: callback = getCosts_costs
2020-09-15 17:51:00.334 Status: dzVents: Debug: getCosts: OpenURL: url = http://*******/json.htm?type=graph&sensor=counter&range=year&idx=1384
2020-09-15 17:51:00.334 Status: dzVents: Debug: getCosts: OpenURL: callback = getCosts_logCount
2020-09-15 17:51:00.336 Status: dzVents: Info: getCosts: ------ Finished mensal.lua
2020-09-15 17:51:00.338 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-09-15 17:51:00.348 Status: Incoming connection from: 127.0.0.1
2020-09-15 17:51:02.305 Status: dzVents: Info: Handling httpResponse-events for: "getCosts_costs"
2020-09-15 17:51:02.305 Status: dzVents: Info: getCosts: ------ Start external script: mensal.lua: HTTPResponse: "getCosts_costs"
2020-09-15 17:51:02.322 Status: dzVents: Debug: getCosts: Processing device-adapter for Custo Mensal: Text device
2020-09-15 17:51:02.323 Status: dzVents: Info: getCosts: ------ Finished mensal.lua
2020-09-15 17:51:05.581 Status: dzVents: Info: Handling httpResponse-events for: "getCosts_logCount"
2020-09-15 17:51:05.581 Status: dzVents: Info: getCosts: ------ Start external script: mensal.lua: HTTPResponse: "getCosts_logCount"
2020-09-15 17:51:05.619 Status: dzVents: Debug: getCosts: Processing device-adapter for Custo Mensal: Text device
2020-09-15 17:51:05.620 Status: dzVents: !Info: getCosts: 2020-09-13 e 2020-10-12 é de: € 3.0
2020-09-15 17:51:05.622 Status: dzVents: Info: getCosts: ------ Finished mensal.lua
2020-09-15 17:51:05.622 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Can you help me whit, please?
Ty
Nefsolive wrote: Tuesday 15 September 2020 13:01 The script is working, but it is not giving me the correct values ​​between the 13th and 12th of the following month! If you check the switch report, the cost values ​​do not correspond to the script cost values!
I can't see any issue with the script. It just sum up the relevant values and calculate the total by multiplying it with the cost / kWh.
Maybe you can show the report and point out what you expect and where the difference is?
Nefsolive
Re: Script KWh month whit a especific date  [Solved]
Post by Nefsolive »
waaren wrote: Wednesday 16 September 2020 20:47
Hi Waaren,
Thanks for all the support.
I made some changes to the script and found another way to get the calculation, including the relative taxes of energy consumption.
I submit the changed script.
kind regards
return
    on =
        timer =
            'at 07:00' , --- change to your liking
        devices =
            scriptVar,
        httpResponses =
            scriptVar .. '_*',
    data =
		potencia = { initial = 0},
		IEC = { initial = 0}
    logging =
        marker = scriptVar,
        local sourceDeviceIndex = 1384 -- change to device you want to measure
        local textDevice = dz.devices('Custo Mensal' )  -- change to devicename you want to see the text message (virtual text device)
            dz.openURL(
                url = costURL,
            dz.openURL(
                url = countURL,
            }).afterSec(5)
            return
                return
            local startMonth, startYear = makeMonth(0)
            if dz.time.day < day then startMonth, startYear = makeMonth(-1) end
			local accu = 0
			local daysCounter = 0
				if r.d >= startDate and r.d <= endDate then
					accu = accu + r.v
					daysCounter = daysCounter + 1
			local potenciaKWH = daysCounter * dz.data.potencia
			local IECCost = accu * dz.data.IEC
			local accuCost = dz.utils.round( (accu * dz.data.KwHCost) + potenciaKWH + 0.0861 + IECCost + 3.02, 2)
			return accuCost, startDate, endDate
				dz.data.potencia = item.json.CostEnergyT2
				dz.data.IEC = item.json.CostEnergyR1
                dz.log('' .. startDate ..' e ' .. endDate .. ' é de: € ' .. energyCost, dz.LOG_FORCE  )
                textDevice.updateText(' entre ' .. startDate ..' e ' .. endDate .. ' é de: € ' .. energyCost)
Users browsing this forum: jjnh and 1 guest
