Because my readings where very slow (i am on a rpi 1) i modified some scripts and, just wanted to share these.
I did modify the script SolarEdge.perl (Timo Kokkonen) somewhat so i could run it as a service on the pi.
So my connection to the inverter stays open all the time, so no need to make a connection and compile the script at every run.
This is now working for 2 days as a charm
The code which follows i didn't clean it, it just a copy of my files.
#!/usr/bin/perl
# sunspec-monitor
# Copyright (C) 2017-2018 Timo Kokkonen <[email protected]>
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 3
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor,
# Boston, MA 02110-1301, USA.
# Modified by P.v.d. Linden 10-09-2020
# Created loop so script wil run as a service
# Added option --update=<sec>, -u <sec> this will generate output every xx sec
use Data::Dumper;
use Device::Modbus::TCP::Client;
use Getopt::Long;
use strict;
use LWP::Simple;
my $UPDATE_EVERY = 1 ;
my $TIMEOUT = 10;
my $PORT = 502;
my $SUNSPEC_I_COMMON_BLOCK_START = 40000;
my $SUNSPEC_I_MODEL_BLOCK_START = 40069;
my $SUNSPEC_M_COMMON_BLOCK_START = 40121;
my $SUNSPEC_M_MODEL_BLOCK_START = 40188;
# For Domoticz, please edit below to your own environment #
my $domoip ="192.168.0.5"; # Domoticz ipaddress.
my $dport = "8080"; #Domoticz port number.
#my $idxSEstat = 4; # idx value of SolarEdge Status, Text device
#my $idxActPwrAC = 89; # idx value of SolarEdge Actual Power, Electric (Instant+Counter, Computed)) device = Power Output (AC)
#my $idxActPwrDC=6; # idx value of SolarEdge Actual Power, Electric (Instant+Counter, Computed) device = Power Input (DC)
#my $idxACinv = 7; # idx value of AC Inverter, Voltage device = Voltage (AC)
#my $idxac_i = 8; # idx value of AC Inverter, Amp device = Current (AC)
#my $idxAC_f = 9; # idx value of AC Inverter, Frequency text device = Voltage (AC) (Hz)
#my $idxDCinv = 10; # idx value of DC Inverter, Voltage device = Voltage (DC)
#my $idxdc_i = 11; # idx value of DC Inverter, Amp device = Current (DC)
#my $idxEffin = 12; # idx value of SolarEdge Efficiency, Percentage device = Efficiency
my $idxTemp = 74; # idx value of SalorEdge Temperature, Temperature device = Temperature
my $idxTotPwr = 75; # idx value of Total LifeTime Production, Custom Sensor = Total Production
# Domoticz extra variables used #
my $version ="1.22";
my $url ="";
my $content="";
my $content="";
my $dwh=0;
my $deff=0;
my $dtemp=0;
my $dac_f=0;
my %I_STATUS = (
0=>'Unknown',
1=>'OFF',
2=>'SLEEPING',
3=>'STARTING',
4=>'ON (MPPT)',
5=>'THROTTLED',
6=>'SHUTTING DOWN',
7=>'FAULT',
8=>'STANDBY'
# get_inverter_common_block - return a hash containing Sunspec
# Common Block values
sub get_inverter_common_block(*) {
my ($ctx) = @_;
my $req = $ctx->read_holding_registers(unit=>1,
address=>$SUNSPEC_I_COMMON_BLOCK_START,
quantity=>69);
$ctx->send_request($req) || die("send_request(): failed");
my $adu = $ctx->receive_response();
die("Read of Common block registers failed (device does not support SunSpec?)")
unless ($adu->success);
my $data = pack("n*",@{$adu->values});
my $cb;
$cb->{C_SunSpec_ID} = unpack("a4",substr($data,0,4));
$cb->{C_SunSpec_DID} = unpack("n",substr($data,4,2));
$cb->{C_SunSpec_Length} = unpack("n",substr($data,6,2));
$cb->{C_Manufacturer} = unpack("a*",substr($data,8,32));
$cb->{C_Manufacturer} =~ s/\0+$//;
$cb->{C_Model} = unpack("a*",substr($data,40,32));
$cb->{C_Model} =~ s/\0+$//;
$cb->{C_Version} = unpack("a*",substr($data,88,16));
$cb->{C_Version} =~ s/\0+$//;
$cb->{C_SerialNumber} = unpack("a*",substr($data,104,32));
$cb->{C_SerialNumber} =~ s/\0+$//;
$cb->{C_DeviceAddress} = unpack("n",substr($data,136,2));
die("Non SunSpec common block received (not SunSpec compliant device?)")
unless ($cb->{C_SunSpec_ID} eq "SunS" && $cb->{C_SunSpec_DID} == 1);
return $cb;
# get_inverter_model_block - return a hash containing Sunspec Inverter
# Model Block values
sub get_inverter_model_block(*) {
my ($ctx) = @_;
address=>$SUNSPEC_I_MODEL_BLOCK_START,
quantity=>52);
die("Read of Inverter Model block registers failed (device does not support SunSpec?)")
my $mb;
$mb->{C_SunSpec_DID} = unpack("n",substr($data,0,2));
$mb->{C_SunSpec_Length} = unpack("n",substr($data,2,2));
$mb->{I_AC_Current} = unpack("n",substr($data,4,2));
$mb->{I_AC_CurrentA} = unpack("n",substr($data,6,2));
$mb->{I_AC_CurrentB} = unpack("n",substr($data,8,2));
$mb->{I_AC_CurrentC} = unpack("n",substr($data,10,2));
$mb->{I_AC_Current_SF} = unpack("n!",substr($data,12,2));
$mb->{I_AC_VoltageAB} = unpack("n",substr($data,14,2));
$mb->{I_AC_VoltageBC} = unpack("n",substr($data,16,2));
$mb->{I_AC_VoltageCA} = unpack("n",substr($data,18,2));
$mb->{I_AC_VoltageAN} = unpack("n",substr($data,20,2));
$mb->{I_AC_VoltageBN} = unpack("n",substr($data,22,2));
$mb->{I_AC_VoltageCN} = unpack("n",substr($data,24,2));
$mb->{I_AC_Voltage_SF} = unpack("n!",substr($data,26,2));
$mb->{I_AC_Power} = unpack("n!",substr($data,28,2));
$mb->{I_AC_Power_SF} = unpack("n!",substr($data,30,2));
$mb->{I_AC_Frequency} = unpack("n",substr($data,32,2));
$mb->{I_AC_Frequency_SF} = unpack("n!",substr($data,34,2));
$mb->{I_AC_VA} = unpack("n!",substr($data,36,2));
$mb->{I_AC_VA_SF} = unpack("n!",substr($data,38,2));
$mb->{I_AC_VAR} = unpack("n!",substr($data,40,2));
$mb->{I_AC_VAR_SF} = unpack("n!",substr($data,42,2));
$mb->{I_AC_PF} = unpack("n!",substr($data,44,2));
$mb->{I_AC_PF_SF} = unpack("n!",substr($data,46,2));
$mb->{I_AC_Energy_WH} = unpack("N",substr($data,48,4));
$mb->{I_AC_Energy_WH_SF} = unpack("n!",substr($data,52,2));
$mb->{I_DC_Current} = unpack("n",substr($data,54,2));
$mb->{I_DC_Current_SF} = unpack("n!",substr($data,56,2));
$mb->{I_DC_Voltage} = unpack("n",substr($data,58,2));
$mb->{I_DC_Voltage_SF} = unpack("n!",substr($data,60,2));
$mb->{I_DC_Power} = unpack("n!",substr($data,62,2));
$mb->{I_DC_Power_SF} = unpack("n!",substr($data,64,2));
# 40103 unused
$mb->{I_Temp_Sink} = unpack("n!",substr($data,68,2));
# 40105-40106 unused
$mb->{I_Temp_Sink_SF} = unpack("n!",substr($data,74,2));
$mb->{I_Status} = unpack("n",substr($data,76,2));
$mb->{I_Status_Vendor} = unpack("n",substr($data,78,2));
$mb->{I_Event_1} = unpack("N",substr($data,80,4));
$mb->{I_Event_2} = unpack("N",substr($data,84,4));
$mb->{I_Event_1_Vendor} = unpack("N",substr($data,88,4));
$mb->{I_Event_2_Vendor} = unpack("N",substr($data,92,4));
$mb->{I_Event_3_Vendor} = unpack("N",substr($data,96,4));
$mb->{I_Event_4_Vendor} = unpack("N",substr($data,100,4));
die("Non SunSpec Model block received (not SunSpec compliant device?)")
unless ($mb->{C_SunSpec_Length} == 50);
return $mb;
# Send URL to domoticz to update sensors
# para idx ,value, verbose
sub senddomo(***){
my ($idx, $value,$verbose) = @_;
$url = "http://$domoip:".$dport."/json.htm?type=command¶m=udevice&idx=$idx&svalue=$value";
$content = get($url);
if ($verbose) {
print "\n";
print ($url);
print "\n";
die "Can't GET $url" if (! defined $content);
# get_meter_common_block - return a has containing Sunspec
# Meter Common block values
# meter = 1..3
sub get_meter_common_block(**) {
my ($ctx,$meter) = @_;
$meter=1 if ($meter < 1);
$meter=3 if ($meter > 3);
my $offset = ($meter - 1) * 174;
address=>$SUNSPEC_M_COMMON_BLOCK_START + $offset,
quantity=>65);
die("Read of Meter $meter block registers failed (device does not support SunSpec?)")
my $cb;
$cb->{C_SunSpec_DID} = unpack("n",substr($data,0,2));
$cb->{C_SunSpec_Length} = unpack("n",substr($data,2,2));
$cb->{C_Manufacturer} = unpack("a*",substr($data,4,32));
$cb->{C_Model} = unpack("a*",substr($data,36,32));
$cb->{C_Option} = unpack("a*",substr($data,68,16));
$cb->{C_Option} =~ s/\0+$//;
$cb->{C_Version} = unpack("a*",substr($data,84,16));
$cb->{C_SerialNumber} = unpack("a*",substr($data,100,32));
die("Non SunSpec Meter Common block received (not SunSpec compliant device?)")
unless ($cb->{C_SunSpec_Length} == 65);
return $cb;
# get_meter_model_block - return a has containing Sunspec
# Meter Model block values
# meter = 1..3
sub get_meter_model_block(**) {
address=>$SUNSPEC_M_MODEL_BLOCK_START + $offset,
quantity=>107);
my $mb;
$mb->{M_AC_Current} = unpack("n!",substr($data,4,2));
$mb->{M_AC_Current_A} = unpack("n!",substr($data,6,2));
$mb->{M_AC_Current_B} = unpack("n!",substr($data,8,2));
$mb->{M_AC_Current_C} = unpack("n!",substr($data,10,2));
$mb->{M_AC_Current_SF} = unpack("n!",substr($data,12,2));
$mb->{M_AC_Voltage_LN} = unpack("n!",substr($data,14,2));
$mb->{M_AC_Voltage_AN} = unpack("n!",substr($data,16,2));
$mb->{M_AC_Voltage_BN} = unpack("n!",substr($data,18,2));
$mb->{M_AC_Voltage_CN} = unpack("n!",substr($data,20,2));
$mb->{M_AC_Voltage_LL} = unpack("n!",substr($data,22,2));
$mb->{M_AC_Voltage_AB} = unpack("n!",substr($data,24,2));
$mb->{M_AC_Voltage_BC} = unpack("n!",substr($data,26,2));
$mb->{M_AC_Voltage_CA} = unpack("n!",substr($data,28,2));
$mb->{M_AC_Voltage_SF} = unpack("n!",substr($data,30,2));
$mb->{M_AC_Freq} = unpack("n!",substr($data,32,2));
$mb->{M_AC_Freq_SF} = unpack("n!",substr($data,34,2));
$mb->{M_AC_Power} = unpack("n!",substr($data,36,2));
$mb->{M_AC_Power_A} = unpack("n!",substr($data,38,2));
$mb->{M_AC_Power_B} = unpack("n!",substr($data,40,2));
$mb->{M_AC_Power_C} = unpack("n!",substr($data,42,2));
$mb->{M_AC_Power_SF} = unpack("n!",substr($data,44,2));
$mb->{M_AC_VA} = unpack("n!",substr($data,46,2));
$mb->{M_AC_VA_A} = unpack("n!",substr($data,48,2));
$mb->{M_AC_VA_B} = unpack("n!",substr($data,50,2));
$mb->{M_AC_VA_C} = unpack("n!",substr($data,52,2));
$mb->{M_AC_VA_SF} = unpack("n!",substr($data,54,2));
$mb->{M_AC_VAR} = unpack("n!",substr($data,56,2));
$mb->{M_AC_VAR_A} = unpack("n!",substr($data,58,2));
$mb->{M_AC_VAR_B} = unpack("n!",substr($data,60,2));
$mb->{M_AC_VAR_C} = unpack("n!",substr($data,62,2));
$mb->{M_AC_VAR_SF} = unpack("n!",substr($data,64,2));
$mb->{M_AC_PF} = unpack("n!",substr($data,66,2));
$mb->{M_AC_PF_A} = unpack("n!",substr($data,68,2));
$mb->{M_AC_PF_B} = unpack("n!",substr($data,70,2));
$mb->{M_AC_PF_C} = unpack("n!",substr($data,72,2));
$mb->{M_AC_PF_SF} = unpack("n!",substr($data,74,2));
$mb->{M_Exported} = unpack("N",substr($data,76,4));
$mb->{M_Exported_A} = unpack("N",substr($data,80,4));
$mb->{M_Exported_B} = unpack("N",substr($data,84,4));
$mb->{M_Exported_C} = unpack("N",substr($data,88,4));
$mb->{M_Imported} = unpack("N",substr($data,92,4));
$mb->{M_Imported_A} = unpack("N",substr($data,96,4));
$mb->{M_Imported_B} = unpack("N",substr($data,100,4));
$mb->{M_Imported_C} = unpack("N",substr($data,104,4));
$mb->{M_Energy_W_SF} = unpack("n!",substr($data,108,2));
$mb->{M_Exported_VA} = unpack("N",substr($data,110,4));
$mb->{M_Exported_VA_A} = unpack("N",substr($data,114,4));
$mb->{M_Exported_VA_B} = unpack("N",substr($data,118,4));
$mb->{M_Exported_VA_C} = unpack("N",substr($data,122,4));
$mb->{M_Imported_VA} = unpack("N",substr($data,126,4));
$mb->{M_Imported_VA_A} = unpack("N",substr($data,130,4));
$mb->{M_Imported_VA_B} = unpack("N",substr($data,134,4));
$mb->{M_Imported_VA_C} = unpack("N",substr($data,138,4));
$mb->{M_Energy_VA_SF} = unpack("n!",substr($data,142,2));
$mb->{M_Import_VARh_Q1} = unpack("N",substr($data,144,4));
$mb->{M_Import_VARh_Q1A} = unpack("N",substr($data,148,4));
$mb->{M_Import_VARh_Q1B} = unpack("N",substr($data,152,4));
$mb->{M_Import_VARh_Q1C} = unpack("N",substr($data,156,4));
$mb->{M_Import_VARh_Q2} = unpack("N",substr($data,160,4));
$mb->{M_Import_VARh_Q2A} = unpack("N",substr($data,164,4));
$mb->{M_Import_VARh_Q2B} = unpack("N",substr($data,168,4));
$mb->{M_Import_VARh_Q2C} = unpack("N",substr($data,172,4));
$mb->{M_Import_VARh_Q3} = unpack("N",substr($data,176,4));
$mb->{M_Import_VARh_Q3A} = unpack("N",substr($data,180,4));
$mb->{M_Import_VARh_Q3B} = unpack("N",substr($data,184,4));
$mb->{M_Import_VARh_Q3C} = unpack("N",substr($data,188,4));
$mb->{M_Import_VARh_Q4} = unpack("N",substr($data,192,4));
$mb->{M_Import_VARh_Q4A} = unpack("N",substr($data,196,4));
$mb->{M_Import_VARh_Q4B} = unpack("N",substr($data,200,4));
$mb->{M_Import_VARh_Q4C} = unpack("N",substr($data,204,4));
$mb->{M_Energy_VAR_SF} = unpack("n!",substr($data,208,2));
$mb->{M_Events} = unpack("N",substr($data,210,4));
unless ($mb->{C_SunSpec_DID} >= 201 && $mb->{C_SunSpec_DID} <= 204);
return $mb;
# scale_value - scale input value using scale factor (SF)
sub scale_value(**) {
my ($val,$sf) = @_;
return $val * (10 ** $sf);
# main program
my $verbose_mode = 0;
my $debug_mode = 0;
my $numeric_mode = 0;
my $json_mode = 0;
my $meter = 1;
my $port = $PORT;
my $timeout = $TIMEOUT;
my $domoticz = 0;
my $update_every = $UPDATE_EVERY;
GetOptions("verbose|v" => \$verbose_mode,
"debug|d" => \$debug_mode,
"port|p=s" => \$port,
"meter|m=s" => \$meter,
"numeric|n" => \$numeric_mode,
"json|j" => \$json_mode,
"timeout|t=s" => \$timeout,
"domoticz|z" => \$domoticz,
"update|u=s" => \$update_every);
my $host = shift;
unless ($host) {
print STDERR "syntax: $0 [options] <host>\n\n",
"Options:\n",
" --port=<port>, -p <port> Use port (default $PORT)\n",
" --meter=<meter>, -m <meter> Query meter (default 1) \n",
" (meter = 1..3 or 0 = no meter)\n",
" --numeric, -n Numeric output mode (time, status)\n",
" --json, -j Output in JSON (instead of CSV) format\n",
" --timeout=<sec>, -t <sec> Timeout (default $TIMEOUT)\n",
" --verbose, -v Verbose mode\n",
" --domoticz, -z Domoticz mode\n",
" --update=<sec>, -u <sec> Update every (default $UPDATE_EVERY)\n",
" --debug, -d Debug mode\n";
print "Version : $version\n\n";
exit(1);
die("invalid port ($port) specified") unless ($port > 0 && $port < 65536);
die("invalid meter ($meter) specified") unless ($meter >= 0 && $meter <= 3);
my $c = Device::Modbus::TCP::Client->new(host=>$host,port=>$port,timeout=>$timeout);
if ($verbose_mode) {
print "Update interval = $update_every \n";
my $checktime = time() + $update_every;
while(1) {
if ( $checktime <= time() )
my $tstamp = time();
my $cb = get_inverter_common_block($c);
my $fw_ver = $cb->{C_Version};
$fw_ver =~ s/^0+//;
print "INVERTER:\n";
print " Model: $cb->{C_Manufacturer} $cb->{C_Model}\n";
print " Firmware version: $fw_ver\n";
print " Serial Number: $cb->{C_SerialNumber}\n";
print Dumper($cb) if ($debug_mode);
print "\n";
my $mb = get_inverter_model_block($c);
my $status = $I_STATUS{$mb->{I_Status}};
my $ac_power = scale_value($mb->{I_AC_Power},$mb->{I_AC_Power_SF});
my $dc_power = scale_value($mb->{I_DC_Power},$mb->{I_DC_Power_SF});
my $temp = scale_value($mb->{I_Temp_Sink},$mb->{I_Temp_Sink_SF});
my $eff = ($dc_power > 0 ? $ac_power/$dc_power*100 : 0);
my $dc_v = scale_value($mb->{I_DC_Voltage},$mb->{I_DC_Voltage_SF});
my $ac_v = scale_value($mb->{I_AC_VoltageAB},$mb->{I_AC_Voltage_SF});
my $ac_i = scale_value($mb->{I_AC_Current},$mb->{I_AC_Current_SF});
my $dc_i = scale_value($mb->{I_DC_Current},$mb->{I_DC_Current_SF});
my $ac_f = scale_value($mb->{I_AC_Frequency},$mb->{I_AC_Frequency_SF});
my $wh = scale_value($mb->{I_AC_Energy_WH},$mb->{I_AC_Energy_WH_SF});
print " Status: $status\n\n";
printf(" Power Output (AC): %12.0f W\n",$ac_power);
printf(" Power Input (DC): %12.0f W\n",$dc_power);
printf(" Efficiency: %12.2f %\n",$eff);
printf(" Total Production: %12.3f kWh\n",$wh/1000);
printf(" Voltage (AC): %12.2f V (%.2f Hz)\n",$ac_v,$ac_f);
printf(" Current (AC): %12.2f A\n",$ac_i);
printf(" Voltage (DC): %12.2f V\n",$dc_v);
printf(" Current (DC): %12.2f A\n",$dc_i);
printf(" Temperature: %12.2f C (heatsink)\n",$temp);
print Dumper($mb) if ($debug_mode);
print "\n";
# Domoticz update to sensor routine
# idx is the domoticz idx sensor value, value, verbose mode
if ($domoticz){
print ("********************************************\n");
print("domo update mode entered \n",);
## SolarEdge SolarEdge Status, Text device
#senddomo ($idxSEstat,$status,$verbose_mode);
## SolarEdge AC Inverter, Voltage device
#senddomo ($idxACinv ,$ac_v,$verbose_mode);
## SolarEdge AC Inverter, Amp device
#senddomo ($idxac_i ,$ac_i,$verbose_mode);
## SolarEdge AC Inverter, Hertz device
#$dac_f = sprintf("%.2f Hz", $ac_f);
#senddomo ($idxAC_f ,$dac_f,$verbose_mode);
## SolarEdge DC Inverter, Voltage device
#senddomo ($idxDCinv ,$dc_v,$verbose_mode);
## SolarEdge DC Inverter, Amp device
#senddomo ($idxdc_i ,$dc_i,$verbose_mode);
## SolarEdge Actual Power / Total Production, General, Kwh device
#senddomo ($idxActPwrAC ,$ac_power,$verbose_mode);
#senddomo ($idxActPwrDC, $dc_power,$verbose_mode);
## SolarEdge Efficiency, Percentage device
#$deff = sprintf("%.2f", $eff);
#senddomo ($idxEffin,$deff,$verbose_mode);
## SolarEdge Temperature, Temperature device
$dtemp = sprintf("%.2f", $temp);
senddomo ($idxTemp ,$dtemp,$verbose_mode);
## SolarEdge Total Production, General, Kwh device + incr. counter
$dwh = sprintf("%d;%d", $ac_power, $wh );
#senddomo ($idxTotPwr,$dwh,$verbose_mode);
$url = "http://$domoip:".$dport."/json.htm?type=command¶m=udevice&idx=$idxTotPwr&&nvalue=0&svalue=$dwh";
my ($m_i, $m_e);
if ($meter > 0) {
my $mcb = get_meter_common_block($c,$meter);
print "METER (#".$meter."):\n";
print " Model: $mcb->{C_Manufacturer} $mcb->{C_Model}\n";
print " Option: $mcb->{C_Option}\n";
print " Firmware version: $mcb->{C_Version}\n";
print " Serial Number: $mcb->{C_SerialNumber}\n";
print Dumper($mcb) if ($debug_mode);
print "\n";
my $mmb = get_meter_model_block($c,1);
$m_e = scale_value($mmb->{M_Exported},$mmb->{M_Energy_W_SF});
$m_i = scale_value($mmb->{M_Imported},$mmb->{M_Energy_W_SF});
my $m_c = scale_value($mmb->{M_AC_Current},$mmb->{M_AC_Current_SF});
my $m_f = scale_value($mmb->{M_AC_Freq},$mmb->{M_AC_Freq_SF});
my $m_v = scale_value($mmb->{M_AC_Voltage_AB},$mmb->{M_AC_Voltage_SF});
my $m_p = scale_value($mmb->{M_AC_Power},$mmb->{M_AC_Power_SF});
my $m_pa = scale_value($mmb->{M_AC_VA},$mmb->{M_AC_VA_SF});
my $m_pf = scale_value($mmb->{M_AC_PF}/100,$mmb->{M_AC_PF_SF});
printf(" Exported Energy: %12.3f kWh\n",$m_e/1000);
printf(" Imported Energy: %12.3f kWh\n",$m_i/1000);
printf(" Real Power: %12.0f W\n",$m_p);
printf(" Apparent Power: %12.0f VA\n",$m_pa);
printf(" Power Factor: %12.2f\n",$m_pf);
printf(" Voltage (AC): %12.2f V (%.2f Hz)\n",$m_v,$m_f);
printf(" Current (AC): %12.2f A\n",$m_c);
print Dumper($mmb) if ($debug_mode);
print "\n";
unless ($verbose_mode) {
print("timestamp,status,ac_power,dc_power,total_production,ac_voltage,ac_current,dc_voltage,dc_current,te
mperature,exported_energy,imporoted_energy\n") if ($debug_mode);
if ($numeric_mode) {
$status=$mb->{I_Status};
} else {
my($sec,$min,$hour,$day,$month,$year) = (localtime($tstamp))[0,1,2,3,4,5];
$tstamp=sprintf("%04d-%02d-%02d %02d:%02d:%02d",$year+1900,$month+1,$day,$hour,$min,$sec);
if ($json_mode) {
unless ($numeric_mode) {
$status="\"$status\"";
$tstamp="\"$tstamp\"";
printf("{\n" .
"\t\"timestamp\": %s,\n" .
"\t\"status\": %s,\n" .
"\t\"ac_power\": %d,\n" .
"\t\"dc_power\": %d,\n" .
"\t\"total_production\": %d,\n" .
"\t\"ac_voltage\": %.2f,\n" .
"\t\"ac_current\": %.2f,\n" .
"\t\"dc_voltage\": %.2f,\n" .
"\t\"dc_current\": %.2f,\n" .
"\t\"temperature\": %.2f,\n" .
"\t\"exported_energy\": %d,\n" .
"\t\"imported_energy\": %d\n" .
"}\n",
$tstamp,$status,$ac_power,$dc_power,$wh,
$ac_v,$ac_i,$dc_v,$dc_i,
$temp,$m_e,$m_i);
} else {
unless($domoticz){
printf("%s,%s,%d,%d,%d,%.2f,%.2f,%.2f,%.2f,%.2f,%d,%d\n",
$temp,$m_e,$m_i);
# DO SOMETHING ELSE
$c->disconnect;
# eof :-)
-- sourse code is from : https://www.domoticz.com/forum/viewtopic.php?t=16440#p224533
-- Modified bcause of faulty reading of P1 values.
-- Domoticz IDX and names of the needed devices
-- Script parameters
Delivery_L1 = 0 -- in Watt hours
Delivery_L2 = 0 -- in Watt hours
Delivery_L3 = 0 -- in Watt hours
Usage_L1 = 0 -- in Watt hours
Usage_L2 = 0 -- in Watt hours
Usage_L3 = 0 -- in Watt hours
CalculatedDelivered = 0 -- in Watt hours
CalculatedUsage = 0 -- in Watt hours
ac_power = 0 -- in Watt hours
debug = "NO" -- Turn debugging on ("YES") or off ("NO")
-- CommandArray
local function update(idx, value1, value2)
local cmd = string.format("%d|0|%.2f;%.2f", idx, value1, value2)
table.insert (commandArray, { ['UpdateDevice'] = cmd } )
local function isempty(s)
return s == nil or s == ''
if (devicechanged["Slimme Meter"]) then
--data from P1(usage1, usage2, return1, return2, cons, cons)
usage1, usage2, return1, return2, usage, usageDelivered = otherdevices_svalues["Slimme Meter"]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
local SE=otherdevices["Zonnepanelen"] -- Virtual Electricity device (usage, counter) in which the actual Solar Output will be stored
local SV=otherdevices["Stroom Verbruik"] -- Virtual Electricity device (usage, counter) in which the actual power consumption will be stored
local OT=otherdevices["Omvormer Temperatuur"] -- Virtual Temperature device, in which the inverter temperature will be stored
local Delivery_L1 = otherdevices["Delivery L1"] -- Delivered power in Fase L1 created by P1 meter
local Delivery_L2 = otherdevices["Delivery L2"] -- Delivered power in Fase L2 created by P1 meter
local Delivery_L3 = otherdevices["Delivery L3"] -- Delivered power in Fase L3 created by P1 meter
local Usage_L1 = otherdevices["Usage L1"] -- Used power in Fase L1 created by P1 meter
local Usage_L2 = otherdevices["Usage L2"] -- Used power in Fase L2 created by P1 meter
local Usage_L3 = otherdevices["Usage L3"] -- Used power in Fase L3 created by P1 meter
-- read values from solar Zonnepanelen
ac_power,total_production = SE:match("([^;]+);([^;]+)")
print ("Total Solar Production = "..total_production.."Wh Current Solar Power = "..ac_power.."Wh")
-- make sure there is no NIL value
if isempty(usage1) then usage1=0 end
if isempty(usage2) then usage2=0 end
if isempty(return1) then return1=0 end
if isempty(return2) then return2=0 end
if isempty(usage) then usage=0 end
if isempty(usageDelivered) then usageDelivered=0 end
if isempty(Delivery_L1) then Delivery_L1=0 end
if isempty(Delivery_L2) then Delivery_L2=0 end
if isempty(Delivery_L3) then Delivery_L3=0 end
if isempty(Usage_L1) then Usage_L1=0 end
if isempty(Usage_L2) then Usage_L2=0 end
if isempty(Usage_L3) then Usage_L3=0 end
if isempty(ac_power) then ac_power=0 end
if isempty(total_production) then total_production=0 end
-- now that we are sure there is no NIL value we can do the calculations
CalculatedDelivered=Delivery_L1+Delivery_L2+Delivery_L3
CalculatedUsage=Usage_L1+Usage_L2+Usage_L3
-- For debugging purposes: Log result
if (debug=="YES") then
print ("SM.usage1 = "..usage1.." SM.usage2 = "..usage2.." SM.return1 = "..return1.." SM.return2 = "..return2.." Current Power Usage = "..usage.." Current Power Delivery = "..usageDelivered)
print ("Usage L1 = "..Usage_L1.." Usage L2 = "..Usage_L2.." Usage L3 = "..Usage_L3.." Usage L1+L2+L3 = "..CalculatedUsage)
print ("Delivery L1 = "..Delivery_L1.." Delivery L2 = "..Delivery_L2.." Delivery L3 = "..Delivery_L3.." Total L1+L2+L3 = "..CalculatedDelivered)
print ("Total Solar Production = "..total_production.." Current Solar Power = "..ac_power)
end -- end if : Debug
-- calculate real energy consumption
local virtuelemeterstand=total_production+usage1+usage2-return1-return2
local vermogen=CalculatedUsage-CalculatedDelivered+ac_power
-- update real actual usage sensor
print("Stroom Verbruik("..vermogen..","..virtuelemeterstand..")")
update(otherdevices_idx["Stroom Verbruik"],vermogen,virtuelemeterstand)
end --end if : devicechanged
for example : solar.service
Place in this file :
[Unit]
Description=Solar service
After=domoticz.service
StartLimitIntervalSec=0
[Service]
Type=simple
Restart=always
RestartSec=1
User=pi
ExecStart=/usr/bin/env perl /home/pi/SolarEdge2_service.perl -m=0 192.168.0.3 -z
[Install]
WantedBy=multi-user.target
set the proper path to your script in ExecStart=
That’s it. We can now start the service:
$ systemctl start solar
And automatically get it to start on boot:
$ systemctl enable solar
More on this can be found on : https://medium.com/@benmorel/creating-a ... 1b5c8b91d6
I hope this helps someone or gives some a idea.
