i have a little problem i have an Zwave remote added to my network, i need to control a double relais with the remote,
so i added on the remote on group 2 the nodeid of the qubino flush relay, but the problem is, that is an double relais connected to two lamps.
now when i press on the remte the on switch, always wil be both lamps switched on, how i can manage it so, if i press the button on the remote that only one lamp wil be switched on and off not both ?
Zwave Reote and Qubino flush 2 relay
Re: Zwave Reote and Qubino flush 2 relay
i finaly get it woirking
im added that lines in srzv9001k12dimz4.xml
</CommandClass>
<CommandClass id="142">
<Compatibility>
<ForceInstances>true</ForceInstances>
</Compatibility>
</CommandClass>
<CommandClass id="96">
<Compatibility>
<MapRootToEndpoint>true</MapRootToEndpoint>
</Compatibility>
</CommandClass>
now it is possible to set groups like 21.1 and 21.2 and it is working
</CommandClass>
<Compatibility>
</Compatibility>
</CommandClass>
<Compatibility>
</Compatibility>
</CommandClass>
I have the same remote and I was wondering where you got this CommandClass infromation from? I mean the IDs..
