How to catch an asynchronous HTTP not responding
Number8
- Domoticz version: 2022.1
In case a web server does not respond to an asynchronous HTTP request, as expected there is a timeout and dzVents logs in red full details of the calling url (including sensitive information). Is there a way to catch the timeout before it is logged by dzVents runtime?
Thank you
Running dzVents 3.0.9
Thank you
Debian buster on NUC and three RPi with buster.
- waaren
Re: How to catch an asynchronous HTTP not responding
If you mean the error message like 2020-09-04 17:31:00.559 Error: Error opening url: http: //somedomain/someAPI?param=1Number8 wrote: Friday 04 September 2020 16:46 In case a web server does not respond to an asynchronous HTTP request, as expected there is a timeout and dzVents logs in red full details of the calling url (including sensitive information). Is there a way to catch the timeout before it is logged by dzVents runtime?
then the message you see is not generated by dzVents but in core domoticz. Messages from dzVents will show the text "dzVents" somewhere in the logline.
Number8
Yes I mean this message, no way to catch it?
- waaren
You will have to modify the domoticz source code and compile locally to achieve that.
A workaround could be to check the url (ping or another tool) before sending the real thing.
Number8
At first place I had the idea to use ping. But it does not answer the case where the network is up and the service is down. I might give a shot to modify the module that send the error message. Any direction to search for?
- waaren
In latest BetaNumber8 wrote: Saturday 05 September 2020 9:45 At first place I had the idea to use ping. But it does not answer the case where the network is up and the service is down. I might give a shot to modify the module that send the error message. Any direction to search for?
main/SQLHelper.cpp:3516: _log.Log(LOG_ERR, "Error opening url: %s", itt->_sValue.c_str());
zicht
- Domoticz version: 2023.1+
No need to modify files.
In Lua and DZ :
You could use curl, but be aware it could freeze domoticz for a couple of seconds.
WIth curl you can set max time to open and max time to wait for the request to finisch.
If you set both at max 9 seconds you will never see the error.
See curl documentation depending on you platform, this can be done on linux AND windows systems
windows example :
"start /b /realtime curl.exe --connect-timeout 5 --max-time 9"
Works fine for me on most http requests. The Start /b / realtime is just to get highest priority on windows curl.
Also you need to implement a check on valid data, you could endup with a empty response or a partial response.
Imagination is the limit. good luck with your approach.
In Lua and DZ :
windows example :
- kiddigital
Do you have a few example loglines showing what you are trying to catch?Number8 wrote:Yes I mean this message, no way to catch it?
Most Domoticz hardware devices that talk to some API over http do this in a synchronous way. Errors like time-outs or other failures have to be handled within the implementation code of the devices themselves.
- waaren
This question is about the (async) openURL call in dzVentskiddigital wrote: Sunday 06 September 2020 10:14 Most Domoticz hardware devices that talk to some API over http do this in a synchronous way. Errors like time-outs or other failures have to be handled within the implementation code of the devices themselves.
- kiddigital
Ah.. okwaaren wrote:...
