[Python] Control Mitsubishi MAC-557IF-E airconditioning
peterpijpelink
- Target OS: OS X
Re: [Python] Control Mitsubishi MAC-557IF-E airconditioning
Is this plugin only for air based melcloud systems or also air/water systems?
SilverShaded
Hi im having some problems getting the plugin working and gave the following error messages, can anyone help?
2020-09-02 21:53:47.827 Error: (Heat Pump) 'onHeartbeat' failed 'KeyError'.
2020-09-02 21:53:47.827 Error: (Heat Pump) ----> Line 599 in '/home/pi/domoticz/plugins/Melcloud/plugin.py', function onHeartbeat
2020-09-02 21:53:47.827 Error: (Heat Pump) ----> Line 276 in '/home/pi/domoticz/plugins/Melcloud/plugin.py', function onHeartbeat
lepe
Continuing here with an issue like i have seen here before...
This is since a week.
Are the melcloud servers blocking my requests?
Meanwhile testing melcloud app and this works fine.
Maybe time to remove the wifi modules and integrate mitsubishi2MQTT...
thanks!
Most of the time every night between 00 and 06 it starts populating the log with these errors... then domoticz crashes (not responding) after a while... (monit restarts then domoticz)Sep 19 00:43:40 raspberrypidomo2 domoticz: (AC) MELCloud receive unknonw message with error code 404
Sep 19 00:43:40 raspberrypidomo2 domoticz: (AC) MELCloud has disconnected
Sep 19 00:43:40 raspberrypidomo2 domoticz: (AC) MELCloud connection OK
Sep 19 00:43:41 raspberrypidomo2 domoticz: (AC) MELCloud connection OK
Sep 19 01:13:45 raspberrypidomo2 domoticz: (AC) MELCloud receive unknonw message with error code 404
Sep 19 01:13:45 raspberrypidomo2 domoticz: (AC) MELCloud has disconnected
Sep 19 01:13:45 raspberrypidomo2 domoticz: (AC) MELCloud connection OK
Sep 19 01:13:45 raspberrypidomo2 domoticz: (AC) No transport, write directive to 'MELCloud' ignored.
Sep 19 01:13:45 raspberrypidomo2 domoticz: Domoticz(pid:931, tid:965('Plugin_ASIO')) received fatal signal 11 (Segmentation fault)
Sep 19 01:13:45 raspberrypidomo2 domoticz: siginfo address=0x3a3, address=(nil)
Sep 19 01:13:50 raspberrypidomo2 domoticz: MQTT: Topic: domoticz/in, Message: {"idx": 1220, "nvalue": 0, "svalue": "34"}
Sep 19 01:13:50 raspberrypidomo2 domoticz: Thread 27 (Thread 0x679f9220 (LWP 965)):
Sep 19 01:13:50 raspberrypidomo2 domoticz: #0 __waitpid (options=0, stat_loc=0x679f7dc8, pid=31886) at ../sysdeps/unix/sysv/linux/waitpid.c:30
Sep 19 01:13:50 raspberrypidomo2 domoticz: #1 __waitpid (pid=31886, stat_loc=0x679f7dc8, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
Sep 19 01:13:50 raspberrypidomo2 domoticz: #2 0x002dbc34 in dumpstack_gdb(bool) ()
Sep 19 01:13:50 raspberrypidomo2 domoticz: #3 0x002dc200 in signal_handler(int, siginfo_t*, void*) ()
Sep 19 01:13:50 raspberrypidomo2 domoticz: #4 <signal handler called>
Sep 19 01:13:50 raspberrypidomo2 domoticz: #5 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
Sep 19 01:13:50 raspberrypidomo2 domoticz: #6 <signal handler called>
Sep 19 01:13:50 raspberrypidomo2 domoticz: #7 0x6ec8ebc0 in ?? ()
Sep 19 01:13:50 raspberrypidomo2 domoticz: #8 0x76cd0d50 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
thanks!
cjb75
Have the same problem, any ideas?
How hard is it to use mqtt? Guide?
Nautilus
Hi, usually (or at least with some plugins) it has been possible to rename the generated switches and selector level names. But now I noticed when changing the name of the status mode switch (id = 1) that it does not update anymore. What would be the proper way to update it? E.g. the temperature sensor I can change for the same plugin and i keeps working.
Also, I noticed in the log something about energy consumption. Is there some setting to create a device for following up on that?
ricvee
- Domoticz version: Stable
I cannot get the plugin working....
It is not adding any device, and yes I allowed for new devices.
I us the latest stable domoticz on a Raspberry Pi.
Is there someone who can help me?
