Rain counter
tage
Rain counter
Hi. Is it possible to script like this :
viewtopic.php?t=15616
But update a rain sensor instead of a general counter ?
I have connect a tipping bucket rain gauge to an esp and set it up as a switch (on/off) if set it up like this it dosen't matter if the esp lose power or reboot the counting is still works..
/ tage
/ tage
tage
Re: Rain counter
Thx. But I don't think I'm able to make a script from scratch. I was hoping I could modify one..
- waaren
Re: Rain counter
Happy to get you started with a dzVents script but need some more info to work with;tage wrote: Tuesday 15 May 2018 17:10 Thx. But I don't think I'm able to make a script from scratch. I was hoping I could modify one..
Is my assumption correct that every time the bucket tips you send an On command to a domoticz switch ?
Do you do that via a json command or in another way ?
tage
Re: Rain counter
exacly every time the bucket tips it pass the magnet and make it "on" for a short time in the tipping moment or "off" it is possible to change.
on the esp (wemos d1) im using esp easy (letscontrolit) and using "Domoticz HTTP" im assume it is json.
- waaren
Re: Rain counter
Hope this dzVents script will get you going.tage wrote: Tuesday 15 May 2018 20:43 exacly every time the bucket tips it pass the magnet and make it "on" for a short time in the tipping moment or "off" it is possible to change.
on = { timer = { "at 00:01" },
devices = { "ESPTestSwitch" } }, -- Your switch device triggered by ESP bucket full
logging = { level = domoticz.LOG_DEBUG, -- INFO, ERROR or DEBUG
marker = "ESP test" }, --
execute = function(dz, trigger)
local rainDevice = dz.devices("ESPTestRain") -- Your (virtual) rain device
local rainSwitch = dz.devices("ESPTestSwitch") -- Your (triggered by bucket full) switch
local rainmm = 2 -- find out what 1 bucket full means in terms of mm
local rainTotal = 0
local timeSlice = math.min( (rainDevice.lastUpdate.secondsAgo / 3600), 10) -- at least 1 bucket in 10 hours
local rainAmountHour = dz.utils.round((rainmm / timeSlice),1)
-- Calc raintotal and reset raintotal at midnight
if trigger.isTimer then
rainDevice.updateRain(dz.utils.round(rainDevice.rainRate,0),0) -- reset rainTotal
rainSwitch.switchOff().silent()
dz.log("Reset raintotal to 0",dz.log_DEBUG)
rainTotal = dz.utils.round((rainmm + rainDevice.rain),1)
rainDevice.updateRain(rainAmountHour,rainTotal)
dz.log("One bucket full ==>> updating raindevice. rainrate: " .. rainAmountHour .. " mm/hr, " .. rainTotal .." mm in total today " ,dz.log_DEBUG)
}Debian buster, bullseye on RPI-4, Intel NUC.
tage
Re: Rain counter
thx !
got some trouble and this is what the log says :
i think i have edit and change that is needed...
/ tage
2018-05-16 05:53:27.027 Error: dzVents: Error: ESP test: An error occured when calling event handler rain_bucket
2018-05-16 05:53:27.027 Error: dzVents: Error: ESP test: ...moticz/scripts/dzVents/generated_scripts/rain_bucket.lua:16: attempt to index field 'utils' (a nil value)/ tage
- waaren
Re: Rain counter
What is your domoticz / dzVents version ?tage wrote: Wednesday 16 May 2018 6:06 thx !
got some trouble and this is what the log says : attempt to index field 'utils' (a nil value)
/ tage
the isTrigger method was introduced in dzVents 2.4.0
the utils round function was introduced in dzVents 2.4.0
the silent() option to switchOff() function was introduced in dzVents 2.3.0
if you really cannot update to a domoticz Beta version with dzVents 2.4.0 or higher you could try the script below where I worked around the new stuff introduced in later dzVents versions. But much better to go a later domoticz with all the new great dzVents stuff in.
execute = function(dz, trigger, triggerInfo)
function round(num, numDecimalPlaces)
return tonumber(string.format("%." .. (numDecimalPlaces or 0) .. "f", num))
local rainSwitch = dz.devices("ESPTestSwitch") -- Your (virtual) rain device
local rainFactor = 100 -- To get a realistic mm/hr value (adjust to your needs)
local rainTotal = 0
local rainAmountHour =round((rainmm / timeSlice * rainFactor),1)
if triggerInfo.type == dz.EVENT_TYPE_TIMER then
rainDevice.updateRain(round(rainDevice.rainRate,0),0) -- reset rainTotal
elseif rainSwitch.state ~= "Off" then
rainTotal = round((rainmm + rainDevice.rain),1)
tage
Re: Rain counter
Thx. The last one seems to work I have to do some test tonight.
My domoticz Version: 3.8153
Guess it is the latest stable.
I have not try the beta and don't know how stable they are that's why I'm on stable versions....
/ tage
/ tage
- waaren
Re: Rain counter
Just backup your current version, directories and most important database (and make sure you can restore
) before you install the latest Beta and enjoy all new features ..
tage
Re: Rain counter
Aah I'm maybe give it a try.
It act little strange when set the rain mm to 1 (one bucket is 1mm)
And rain factor I'm not sure what value to set. Gonna do some more test later
tage
Re: Rain counter
I just found that the script is counting both on and off.. the rain gauge is making the on switch and goes back to off again.
possble to make the script only count "on'" command ?
/ Tage
/ Tage
- waaren
Re: Rain counter
@tage,tage wrote: Wednesday 23 May 2018 4:55 I just found that the script is counting both on and off.. the rain gauge is making the on switch and goes back to off again.
/ Tage
the line
elseif rainSwitch.state ~= "Off" thenIn later versions of dzVents (> 2.2) you would change the line
to
rainSwitch.switchOff().silent()You could add
dz.log("Script triggered by rainSwitch state: " .. rainSwitch.state,dz.log_DEBUG)Debian buster, bullseye on RPI-4, Intel NUC.
snellejellep
- Domoticz version: 2020.2
Re: Rain counter
i wanted to try this out for my 3d printed rainmeter but i have one issue.
i have a raindevice in domoticz and a switch which switches when the bucket tips so all the same as above but now the following:
i get no errors and the rain device updates but only the rain rate and not the total fallen rain.
am i overlooking something?
this is my log:
this is my log:
2020-08-31 12:41:25.068 Status: User: Admin initiated a switch command (1126/tippingbucketrain/On)
2020-08-31 12:41:25.345 Status: dzVents: Info: Handling events for: "tippingbucketrain", value: "On"
2020-08-31 12:41:25.346 Status: dzVents: Info: ESP test: ------ Start internal script: regenmeter: Device: "tippingbucketrain (Dummy/virtual)", Index: 1126
2020-08-31 12:41:25.347 Status: dzVents: Debug: ESP test: Processing device-adapter for Regenmeter: Rain device
2020-08-31 12:41:25.348 Status: dzVents: Info: ESP test: One bucket full ==>> updating raindevice. rainrate: 133.3 mm/hr, 2.0 mm in total today
2020-08-31 12:41:25.348 Status: dzVents: Debug: ESP test: Constructed timed-command: Off
2020-08-31 12:41:25.348 Status: dzVents: Debug: ESP test: Constructed timed-command: Off NOTRIGGER
2020-08-31 12:41:25.348 Status: dzVents: Info: ESP test: ------ Finished regenmeterraspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
- waaren
Re: Rain counter
The value shown on the title row of a rain device shows the latest send value minus the first value of today. So if you have send the same value it will show 0snellejellep wrote: Monday 31 August 2020 12:44 i have a raindevice in domoticz and a switch which switches when the bucket tips so all the same as above but now the following:
The value will be reset to 0 at midnight.
snellejellep
Re: Rain counter
then i think i do not understand how it works. i thought the following:waaren wrote: Monday 31 August 2020 18:44 The value shown on the title row of a rain device shows the latest send value minus the first value of today. So if you have send the same value it will show 0
- the script adds the rainmm defined amount to the rain device every time the bucket tips and thus the device is activated
- that way each time the bucket tips by default it should add 2mm of rain to the upper right corner of the rain device?
- but the only thing i am seeing is the rain rate being updated?
correct me if i am wrong but i thought that it would update the total rain in mm in the upper right corner
- waaren
Re: Rain counter
Can you please share the script as you use it now?snellejellep wrote: Monday 31 August 2020 18:58 then i think i do not understand how it works. i thought the following:
snellejellep
Re: Rain counter
devices = { "tippingbucketrain" } }, -- Your switch device triggered by ESP bucket full
local rainDevice = dz.devices("Regenmeter") -- Your (virtual) rain device
local rainSwitch = dz.devices("tippingbucketrain") -- Your (triggered by bucket full) switch
local rainTotal = 0
}and for raindevice i use the domoticz dummy rain device
- waaren
Re: Rain counter
I tested with below script (the reset at 0:00 is not needed as domoticz does that anyway without a script) and the upper right corner does display the total rain in mm for todaysnellejellep wrote: Monday 31 August 2020 18:58 correct me if i am wrong but i thought that it would update the total rain in mm in the upper right corner
BUT: if the lowest value of today in database table RAIN is > 0, the calculation in the script fails because the value of rain is
current number - lowest number of today in database table RAIN for this device
return
on =
devices =
logging =
marker = "ESP test",
execute = function(dz, item)
local rainTotal = 0
if item.active then
rainDevice.updateRain(rainAmountHour, rainTotal)
dz.log("One bucket full ==>> updating raindevice. rainrate: " .. rainAmountHour .. " mm/hr, " .. rainTotal .." mm in total today ", dz.LOG_DEBUG )
snellejellep
Re: Rain counter
thank you verry much! this works like a charm!waaren wrote: Monday 31 August 2020 22:35 I tested with below script (the reset at 0:00 is not needed as domoticz does that anyway without a script) and the upper right corner does display the total rain in mm for today
return { on = { devices = { "tippingbucketrain", }, }, logging = { level = domoticz.LOG_DEBUG, -- INFO, ERROR or DEBUG marker = "ESP test", }, execute = function(dz, item) local rainDevice = dz.devices("Regenmeter") -- Your (virtual) rain device local rainSwitch = dz.devices("tippingbucketrain") -- Your (triggered by bucket full) switch local rainmm = 2 -- find out what 1 bucket full means in terms of mm local rainTotal = 0 local timeSlice = math.min( (rainDevice.lastUpdate.secondsAgo / 3600), 10) -- at least 1 bucket in 10 hours local rainAmountHour = dz.utils.round((rainmm / timeSlice),1) if item.active then rainTotal = dz.utils.round((rainmm + rainDevice.rain),1) rainDevice.updateRain(rainAmountHour, rainTotal) dz.log("One bucket full ==>> updating raindevice. rainrate: " .. rainAmountHour .. " mm/hr, " .. rainTotal .." mm in total today ", dz.LOG_DEBUG ) rainSwitch.switchOff().silent() end end }
Users browsing this forum: hemant5400z and 1 guest
