I like to setup the system alive checker.
Because my domoticz system runs not as root i used the following command (in a Terminal session):
sudo setcap -v cap_net_raw+eip /home/pi/domoticz/domoticz
it gives me the following response:
/home/pi/domoticz/domoticz differs in [pie]
What does it mean ?
my domoticz executable is in /home/pi/domoticz/domoticz
Would be nice to have some help
Lanwizard
System alive Checker setup
- waaren
Re: System alive Checker setup
The setcap verify command gives you an answer to the verification request "does the domoticz binary have the e, i and p cap?" The answer is: NoLanWizard wrote: Wednesday 02 September 2020 14:42 /home/pi/domoticz/domoticz differs in [pie]
What does it mean ?
So what you probably want isThe -v tells setcap to verifiy that the capabilities requested match those of the file, it will report Ok if they match or tells you which of the three sets are different. Without -v setcap will try to change the capabilities of the file to that which you request. Your subsequent testing with -v after having set them will now report Ok as the file will now have those capabilities set.
sudo setcap cap_net_raw+eip /home/pi/domoticz/domoticz # add the e, i and p cap to domoticz binary
sudo setcap -v cap_net_raw+eip /home/pi/domoticz/domoticz # verifyif the setcap did what was requested
LanWizard
Thank you Waaren,
Have read your exlpanation and now everything is working as desired.
Greetings from Hamburg/Germany
LanWizard
LanWizard
Luckily I found this post but the documentation is wrong (it has -v) :
https://www.domoticz.com/wiki/System_Al ... ker_(Ping)
- Domoticz version: 2025.1
Thanks, I updated the wiki.Geronimoo wrote: Tuesday 07 March 2023 16:20 Luckily I found this post but the documentation is wrong (it has -v) :
Users browsing this forum: eddieb, Semrush [Bot] and 1 guest
