Everything is working fine: no problems. Seems to run very stable.
I've added the possibility to recalibrate from within Domoticz, just to be sure ...
I'm running it with Domoticz 2021.1herbod wrote: ↑Wednesday 29 December 2021 15:32 https://github.com/lokonli/slide-domoticz does this only work with the beta version of Domotics? Not in the stable?
My Domotics will not start after installing in stable.
I've tested the Slide plugin with the latest Domoticz stable version (2022.1).
2022-03-22 11:46:00.754 Error: Gordijnen: (iim-slide) failed to load 'plugin.py', Python Path used was ':/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2022-03-22 11:46:00.791 Error: Gordijnen: Exception: 'ModuleNotFoundError'. No traceback available.
On my Debian 10 Buster system I just installed the latest Domoticz Docker container. Created a docker-compose.yml file. And a config folder. Started the docker container with docker-compose up.Vollervo wrote: ↑Tuesday 22 March 2022 11:52 Hi,
Has anyone succesfully used the iim-slide plugin inside a Docker container? I migrated from a debian 11 to the offical Docker image and installed the plugin inside the Docker container as per instructions https://github.com/lokonli/slide-domoti ... stallation, but it doesn't work. On start up it produces an error:
Any ideas what's wrong?Code: Select all
2022-03-22 11:46:00.754 Error: Gordijnen: (iim-slide) failed to load 'plugin.py', Python Path used was ':/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'. 2022-03-22 11:46:00.791 Error: Gordijnen: Exception: 'ModuleNotFoundError'. No traceback available.
I did notice that the Docker image python version Python 3.7.3, while the machine I migrated from has version Python 3.9.2 and the wiki says version 3.4 - 3.8 need to be installed. The Docker image is an older Debian version which doesn't have a higher version of Python.
Thanks,
Vollervo
2024-05-18 15:23:53.072 Slide: {"ip": "192.168.101.112", "code": "BuarGvJ5", "nonce": "", "nc": 37, "checkMovement": 0, "slide_id": "slide_246F28482084"}
2024-05-18 15:23:53.072 Slide: connect called
2024-05-18 15:23:53.072 Slide: {"device": {"ip": "192.168.101.112", "code": "BuarGvJ5", "nonce": "", "nc": 37, "checkMovement": 0, "slide_id": "slide_246F28482084"}, "uri": "/rpc/Slide.GetInfo", "data": "", "delay": 0, "authorizationError": false}
2024-05-18 15:23:53.072 Slide: Deallocating connection object 'Slide_36' (192.168.101.112:80).
2024-05-18 15:23:53.072 Slide: Pushing 'ProtocolDirective' on to queue
2024-05-18 15:23:53.072 Slide: Pushing 'ConnectDirective' on to queue
2024-05-18 15:23:53.072 Slide: Acquiring GIL for 'onHeartbeatCallback'
2024-05-18 15:23:53.072 Slide: Processing 'ProtocolDirective' message
2024-05-18 15:23:53.072 Slide: Acquiring GIL for 'ProtocolDirective'
2024-05-18 15:23:53.072 Slide: Protocol set to: 'HTTP'.
2024-05-18 15:23:53.072 Slide: Processing 'ConnectDirective' message
2024-05-18 15:23:53.072 Slide: Acquiring GIL for 'ConnectDirective'
2024-05-18 15:23:53.073 Slide: Transport set to: 'TCP/IP', 192.168.101.112:80.
2024-05-18 15:23:53.073 Slide: Connect directive received, action initiated successfully.
2024-05-18 15:23:53.073 Slide: Acquiring GIL for 'ConnectDirective'
2024-05-18 15:23:53.073 Slide: Acquiring GIL for 'CPluginTransportTCP::handleAsyncResolve'
2024-05-18 15:23:53.079 Slide: Acquiring GIL for 'CPluginTransportTCP::handleAsyncResolve'
2024-05-18 15:23:53.080 Slide: Pushing 'onConnectCallback' on to queue
2024-05-18 15:23:53.123 Slide: Processing 'onConnectCallback' message
2024-05-18 15:23:53.123 Slide: Acquiring GIL for 'onConnectCallback'
2024-05-18 15:23:53.123 Slide: Calling message handler 'onConnect' on 'module' type object.
2024-05-18 15:23:53.123 Slide: onConnect called
2024-05-18 15:23:53.123 Slide: Slide connected successfully.
2024-05-18 15:23:53.123 Slide: sendMessage called
2024-05-18 15:23:53.123 Slide: Part 1: a3ea0503d2b99f964c81c8ea530ceb3b
2024-05-18 15:23:53.123 Slide: Part 2: 2a1d40aaaaebce6dcad24434199dae66
2024-05-18 15:23:53.124 Slide: {"Verb": "POST", "Headers": {"Content-Type": "application/json", "Accept": "application/json", "Authorization": "Digest username=\"user\", realm=\"iim\", nonce=\"\", uri=\"/rpc/Slide.GetInfo\", algorithm=\"MD5\", qop=auth, nc=00000037, cnonce=\"abcdef0123456789\", response=\"75f2b5eba185a128168b35019a61a670\""}, "URL": "/rpc/Slide.GetInfo", "Data": ""}
2024-05-18 15:23:53.124 Slide: Pushing 'WriteDirective' on to queue
2024-05-18 15:23:53.124 Slide: Acquiring GIL for 'onConnectCallback'
2024-05-18 15:23:53.124 Slide: Processing 'WriteDirective' message
2024-05-18 15:23:53.124 Slide: Acquiring GIL for 'WriteDirective'
2024-05-18 15:23:53.124 Slide: Sending 339 bytes of data
2024-05-18 15:23:53.124 Slide: 50 4f 53 54 20 2f 72 70 63 2f 53 6c 69 64 65 2e 47 65 74 49 POST./rpc/Slide.GetI
2024-05-18 15:23:53.124 Slide: 6e 66 6f 20 48 54 54 50 2f 31 2e 31 0d 0a 55 73 65 72 2d 41 nfo.HTTP/1.1..User-A
2024-05-18 15:23:53.124 Slide: 67 65 6e 74 3a 20 44 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a gent:.Domoticz/1.0..
2024-05-18 15:23:53.124 Slide: 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 Content-Type:.applic
2024-05-18 15:23:53.124 Slide: 61 74 69 6f 6e 2f 6a 73 6f 6e 0d 0a 41 63 63 65 70 74 3a 20 ation/json..Accept:.
2024-05-18 15:23:53.124 Slide: 61 70 70 6c 69 63 61 74 69 6f 6e 2f 6a 73 6f 6e 0d 0a 41 75 application/json..Au
2024-05-18 15:23:53.124 Slide: 74 68 6f 72 69 7a 61 74 69 6f 6e 3a 20 44 69 67 65 73 74 20 thorization:.Digest.
2024-05-18 15:23:53.124 Slide: 75 73 65 72 6e 61 6d 65 3d 22 75 73 65 72 22 2c 20 72 65 61 username="user",.rea
2024-05-18 15:23:53.125 Slide: 6c 6d 3d 22 69 69 6d 22 2c 20 6e 6f 6e 63 65 3d 22 22 2c 20 lm="iim",.nonce="",.
2024-05-18 15:23:53.125 Slide: 75 72 69 3d 22 2f 72 70 63 2f 53 6c 69 64 65 2e 47 65 74 49 uri="/rpc/Slide.GetI
2024-05-18 15:23:53.125 Slide: 6e 66 6f 22 2c 20 61 6c 67 6f 72 69 74 68 6d 3d 22 4d 44 35 nfo",.algorithm="MD5
2024-05-18 15:23:53.125 Slide: 22 2c 20 71 6f 70 3d 61 75 74 68 2c 20 6e 63 3d 30 30 30 30 ",.qop=auth,.nc=0000
2024-05-18 15:23:53.125 Slide: 30 30 33 37 2c 20 63 6e 6f 6e 63 65 3d 22 61 62 63 64 65 66 0037,.cnonce="abcdef
2024-05-18 15:23:53.125 Slide: 30 31 32 33 34 35 36 37 38 39 22 2c 20 72 65 73 70 6f 6e 73 0123456789",.respons
2024-05-18 15:23:53.125 Slide: 65 3d 22 37 35 66 32 62 35 65 62 61 31 38 35 61 31 32 38 31 e="75f2b5eba185a1281
2024-05-18 15:23:53.125 Slide: 36 38 62 33 35 30 31 39 61 36 31 61 36 37 30 22 0d 0a 43 6f 68b35019a61a670"..Co
2024-05-18 15:23:53.125 Slide: 6e 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 30 0d 0a 0d 0a .. ntent-Length:.0....
2024-05-18 15:23:53.125 Slide: Acquiring GIL for 'WriteDirective'
2024-05-18 15:23:53.155 Slide: Acquiring GIL for 'CPluginTransportTCP::handleRead'
2024-05-18 15:23:53.155 Slide: Pushing 'ReadEvent' on to queue
2024-05-18 15:23:53.155 Queued asynchronous read aborted (192.168.101.112:80), [2] End of file.
2024-05-18 15:23:53.155 Slide: Pushing 'DisconnectedEvent' on to queue
2024-05-18 15:23:53.175 Slide: Processing 'ReadEvent' message
2024-05-18 15:23:53.175 Slide: Acquiring GIL for 'ReadEvent'
2024-05-18 15:23:53.175 Slide: Received 367 bytes of data
2024-05-18 15:23:53.175 Slide: 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d 0a 53 65 72 HTTP/1.1.200.OK..Ser
2024-05-18 15:23:53.176 Slide: 76 65 72 3a 20 4d 6f 6e 67 6f 6f 73 65 2f 36 2e 31 38 0d 0a ver:.Mongoose/6.18..
2024-05-18 15:23:53.176 Slide: 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 Content-Type:.applic
2024-05-18 15:23:53.176 Slide: 61 74 69 6f 6e 2f 6a 73 6f 6e 0d 0a 41 63 63 65 73 73 2d 43 ation/json..Access-C
2024-05-18 15:23:53.176 Slide: 6f 6e 74 72 6f 6c 2d 41 6c 6c 6f 77 2d 4f 72 69 67 69 6e 3a ontrol-Allow-Origin:
2024-05-18 15:23:53.176 Slide: 20 2a 0d 0a 41 63 63 65 73 73 2d 43 6f 6e 74 72 6f 6c 2d 41 .*..Access-Control-A
2024-05-18 15:23:53.176 Slide: 6c 6c 6f 77 2d 48 65 61 64 65 72 73 3a 20 2a 0d 0a 43 6f 6e llow-Headers:.*..Con
2024-05-18 15:23:53.176 Slide: 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 31 38 38 0d 0a 43 6f tent-Length:.188..Co
2024-05-18 15:23:53.176 Slide: 6e 6e 65 63 74 69 6f 6e 3a 20 63 6c 6f 73 65 0d 0a 0d 0a 7b nnection:.close....{
2024-05-18 15:23:53.176 Slide: 22 73 6c 69 64 65 5f 69 64 22 3a 20 22 73 6c 69 64 65 5f 32 "slide_id":."slide_2
2024-05-18 15:23:53.176 Slide: 34 36 46 32 38 34 38 32 30 38 34 22 2c 20 22 6d 61 63 22 3a 46F28482084",."mac":
2024-05-18 15:23:53.176 Slide: 20 22 32 34 36 46 32 38 34 38 32 30 38 34 22 2c 20 22 62 6f ."246F28482084",."bo
2024-05-18 15:23:53.176 Slide: 61 72 64 5f 72 65 76 22 3a 20 31 2c 20 22 64 65 76 69 63 65 ard_rev":.1,."device
2024-05-18 15:23:53.176 Slide: 5f 6e 61 6d 65 22 3a 20 22 53 6c 69 64 65 22 2c 20 22 7a 6f _name":."Slide",."zo
2024-05-18 15:23:53.176 Slide: 6e 65 5f 6e 61 6d 65 22 3a 20 22 22 2c 20 22 63 75 72 74 61 ne_name":."",."curta
2024-05-18 15:23:53.176 Slide: 69 6e 5f 74 79 70 65 22 3a 20 30 2c 20 22 63 61 6c 69 62 5f in_type":.0,."calib_
2024-05-18 15:23:53.176 Slide: 74 69 6d 65 22 3a 20 2d 32 34 30 35 38 2c 20 22 70 6f 73 22 time":.-24058,."pos"
2024-05-18 15:23:53.177 Slide: 3a 20 30 2e 31 32 2c 20 22 74 6f 75 63 68 5f 67 6f 22 3a 20 :.0.12,."touch_go":.
2024-05-18 15:23:53.177 Slide: 74 72 75 65 7d 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. true}..
2024-05-18 15:23:53.177 Slide: Pushing 'onMessageCallback' on to queue
2024-05-18 15:23:53.177 Slide: Acquiring GIL for 'ReadEvent'
2024-05-18 15:23:53.177 Slide: Processing 'DisconnectedEvent' message
2024-05-18 15:23:53.177 Slide: Acquiring GIL for 'DisconnectedEvent'
2024-05-18 15:23:53.177 Slide: Disconnect event received for '192.168.101.112:80'.
2024-05-18 15:23:53.177 Slide: Pushing 'onDisconnectCallback' on to queue
2024-05-18 15:23:53.177 Slide: Processing 'onMessageCallback' message
2024-05-18 15:23:53.177 Slide: Acquiring GIL for 'onMessageCallback'
2024-05-18 15:23:53.177 Slide: Calling message handler 'onMessage' on 'module' type object.
2024-05-18 15:23:53.177 Slide: onMessage called
2024-05-18 15:23:53.178 Slide: Good Response received from IIM
2024-05-18 15:23:53.181 (Slide - $status) Updating device from 1:'On' to have values 1:'On'.
2024-05-18 15:23:53.185 Slide: Searching for device slide_246F28482084
2024-05-18 15:23:53.185 Slide: Device exists
2024-05-18 15:23:53.185 Slide: setStatus called
2024-05-18 15:23:53.185 Slide: Acquiring GIL for 'onMessageCallback'
2024-05-18 15:23:53.186 Slide: Processing 'onDisconnectCallback' message
2024-05-18 15:23:53.186 Slide: Acquiring GIL for 'onDisconnectCallback'
2024-05-18 15:23:53.186 Slide: Calling message handler 'onDisconnect' on 'module' type object.
2024-05-18 15:23:53.186 Slide: onDisconnect called
def onHeartbeat(self):
if self.hb == 20:
Domoticz.Debug("onHeartbeat called")
self.getAllSlidesInfo()
self.hb = 1
else:
self.hb = self.hb + 1
