I want to achieve the following. A hue lamp is on in a certain color. As soon as the doorbell rings, I switch on a different color for a minute. I want to go back to the first situation after that.
This works but restoring to the original color is not possible. Is there a way to save and restore the original color in dzvents?
set en restore a setting
- waaren
Re: set en restore a setting
Seems to be similar question as in this topickroonp wrote: Monday 24 August 2020 11:45 I want to achieve the following. A hue lamp is on in a certain color. As soon as the doorbell rings, I switch on a different color for a minute. I want to go back to the first situation after that.
kroonp
Ik viewed the topic.
What kind of devices are safeColor and getColor ??
on = { devices = { "safeColor","getColor"}} ,
- waaren
These are dummy switches to trigger the script. The script is a proof of concept and needs to be adjusted for your situation.kroonp wrote: Monday 24 August 2020 17:35 Ik viewed the topic.
The important parts are the data section and the functions in the execute section
Happy to help if you give me the name, type and subtype of the bel and light involved and the script you have so far.
kroonp
Thanks for helping me.
I used the script as shown above
Mijn colorwitch: Keuken idx 31
My bel is : Doorbell idx 265
-- KeepRestoreRGB
data = { previousColor = { initial = {} },
previousBrightness = { initial = -1 }},
logging = { level = domoticz.LOG_DEBUG,
marker = "KeepRestoreRGB" },
execute = function(dz, item)
local rgbLight = dz.devices(31) -- This is the light bulb
local function internalURL(url)
dz.openURL({
url = dz.settings['Domoticz url'] .. url,
method = "GET",
local function setColor(idx,color,brightness)
myUrl = "/json.htm?type=command¶m=setcolbrightnessvalue&" ..
"idx=" .. idx ..
"&color=" .. color ..
"&brightness=" .. brightness
internalURL(myUrl)
if item.name == 'safeColor' or dz.data.previousBrightness == -1 then
dz.data.previousColor = dz.utils.fromJSON(rgbLight.color) -- Safe current color in dzVents persistent data
dz.data.previousBrightness = rgbLight.level -- Safe current brightness in dzVents persistent data
elseif item.name == "getColor" then
setColor(rgbLight.idx, dz.utils.toJSON(dz.data.previousColor), dz.data.previousBrightness)
kroonp
It works, thankx
kroonp
I thought all the settings were good.
I made 2 dummy swichtes safeColor and getColor.
The script works. The current situation is saved when I push the switch safeColor and can be retrieved with i push the swicht getColor.
So fine. I now wanted to process it in the script below, but I make something wrong there. When the Keuken (31) is on and I push switch test nothing happens. The light does not show te new color.
devices = {
'test'
domoticz.devices('safeColor').swichtOn() -- save the color
domoticz.devices('Keuken').setRGB(255, 153, 153)-- set new color idx 31
domoticz.devices('getColor').swichtOn().afterSec(5) -- get saved color after 5 seconds.
}- waaren
You made a typo. the method is switchOn() and you typed switchtOn()kroonp wrote: Tuesday 25 August 2020 9:38 I now wanted to process it in the script below, but I make something wrong there. When the Keuken (31) is on and I push switch test nothing happens. The light does not show te new color.
