Passing system temp to Domoticz using a bash script Topic is solved
All kinds of 'OS' scripts
pgielen
Post by pgielen »
I am trying to read the system temperature from my RPi and send it to Domoticz, using the following bash script:
#! /bin/sh
temp=$(vcgencmd measure_temp | egrep -o '[0-9]*\.[0-9]*')
echo "System temperature: $temp"
url="http://192.168.1.52:8080/json.htm?type=command&param=udevice&idx=571&nvalue=0&svalue=$temp"
echo "$curl"
curl "$url"
Lines 3 and 5 are only there for testing if the values passed on to the url are correct.
However, this does not work; curl answers (3) URL using bad/illegal format or missing URL, because it apparently expects double quotes arount the url (if I directly type in something like: curl "http://192.168.1.52:8080/json.htm?type= ... &svalue=77" in the cli, the value is passed on to Domoticz without problems).
Changing line 4 to:
url="\"http://192.168.1.56:8088/json.htm?type=command&param=udevice&idx=571&nvalue=0&svalue=$temp\""
does not work either, because the url string will get a leading double quote, but the double quote at the end of the string still gets lost for some reason.
I tried the same with wget in stead of curl, with the same results...
Is there another way to pass such a value from bash to Domoticz or should I switch to PHP or Python for this relatively simple task?
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
felix63
Domoticz version: 2020.1
Re: Passing system temp to Domoticz using a bash script
Post by felix63 »
did you try this?
curl $url
pgielen
Post by pgielen »
felix63 wrote: Saturday 22 August 2020 12:03 did you try this?
curl $url
Yes, same problem
pgielen wrote: Saturday 22 August 2020 11:31 I am trying to read the system temperature from my RPi and send it to Domoticz
I normally use the bash shell.
sh is behaving different.
I tested below script and it does the job.
#!/bin/bash
echo $url
curl $url
pgielen
Post by pgielen »
Yes it does. Remarkably enough the problem were -once more- CRLF characters in the script. I dit not see this coming, since the CR's ended up not in the variable names, but in the values of the variables $temp and $url. No idea how this can happen, but after I removed the CR from the end of every line in the script, the problem was solved.
gizmocuz
Post by gizmocuz »
Could you try beta 12268, when you add the motherboard hardware to your domoticz (from the hardware setup page), you should see your motherboard temperature. (double check if accept new hardware/devices is enabled in your settings)
(I think this should also with with previous beta's already as It's working on my RPi4)
